1 Reply Latest reply on Oct 19, 2011 8:09 PM by Mister MUX
    create lists on the fly from a field
    wfzen Level 1
      I have a text memeber with the following content. I'd like to convert the text in each line into its own global list that will be used in another place.
      rightAnsL1 = [1, 2, "text here"];
      rightAnsL2 = [1, 1, "none"];
      rightAnsL3 = [1, 1, "none"];
      rightAnsL4 = [2, 1, "none"];
      rightAnsL5 = [1, 1, "none"];
      rightAnsL6 = [2, 2, "text 2 here"];
      How can I create multiple lists based on a total number?
      repeat with i = 1 to totalIneOfAMember -- 6 in this case
      global "myList"&(i) = [] -- initialize and make them global
      -- text manipulate to get 1, 2, "text here" in the first line, etc.
      -- assign that string to myList1, myList2, etc. to the end
      end repeat
      How do I make that work?
        • 1. Re: create lists on the fly from a field
          Mister MUX
          You don't need to create a separate global variables in cases like this. You can use a single list variable and add as many elements to the list as needed. Of course the list elements can be lists themselves (as is the case in your example).
          So all you really need now is an algorithm to parse the text of your member to extract the individual list. As long as your lines are always formatted in the manner of your example, this handler will do the trick.
          on createAnswerListFromTextMember textMember
            answerList = []
            numLines = textMember.line.count
            repeat with lineNum = 1 to numLines
              answerList.add(value(textMember.line[lineNum].char[14..textMember.line[lineNum].char.coun t-1]))
            end repeat
            return answerList
          Now you can assign the return value of the handler to a global variable. For example, if the text member that has the data in it is called answerList
          myList = createAnswerListFromTextMember(member "answerList")
          Instead of myList1, you can use myList[1], myList[2], etc
