3 Replies Latest reply on Oct 20, 2011 1:59 PM by Franck Payen
    InDesign 7.5.2 is out
    John Hawkinson Level 5
      InDesign CS5.5 revision 7.5.2 came out yesterday. According to the release notes, it addresses:
      Architecture / Document
      Error code: 5 when trying to open many files on Mac OS [2922941]
      ID quits unexpectedly when saving (as) a document with name containing illegal shift-JIS/MacEncodingJapan byte sequences [2885535]
      InDesign quits unexpectedly when opening a document containing installed fonts with unrecognized font family [2923724]
      Some extension panels won't open when documents titled with certain characters are open [2917124]
      Some extension panels cease to function when documents titled with Russian characters are open [2932558]
      Address instability in layers panel [2923714, 2923725]
      epub
      InDesign quits unexpectedly when exporting a document containing composite fonts to EPUB. [2832559]
      Error in epub opened on ibooks if a discretionary hyphen is in the story [2889349]
      An extra space is in the DTD declaration in the HTML file for ebooks [2889353]
      Graphics
      Document installed fonts not used in placed EPS when exporting to PDF [2917336]
      Unable to place PNG files containing large color profiles, giving error "Cannot place this file. Invalid PNG file" [2880720]
      InDesign quits unexpectedly after copying a graphic and scheduling a close document command. [2923717]
      Print / PDF
      Inset text frames near page borders may be mispositioned when exported to PDF [2874266]
      InDesign quits unexpectedly after PDF export. [2873782]
      InDesign quits unexpectedly when printing separations with accented characters in spot color name [2934118]
      Text
      Text subscript/superscript sizes set to zero and can't be changed in Turkish version [2895926]
      InDesign may hang when multiple font groups with the same name are installed [2919511]
      InDesign quits unexpectedly when importing tagged text with missing hyperlink name [2923721]
      InDesign quits unexpectedly when text focus crosses outside text model range during table operation [2923728]
      XML
      XML links lose format information on relink [2917351]
      Also, these issues fixed in CS5.5 7.5.1 were still in the release notes but are not newly fixed:
      Unable to insert a line break with the Return key in the Swedish version [2884727]
      Background PDF export fails for certain files if preflight is enabled. [2824068]
      Can't change XSLT file when relinking XML files [2823961]
      Excel-specific import prefs are not retained when placing Excel file into a graphic frame [2808639]
      Problem accessing shared linked file from multiple InDesign instances running on different machines [2851854]
      CS5 plug-ins can be loaded in CS5.5, leading to code conflicts and instability  [2867833]
