0 Replies Latest reply on Oct 20, 2011 1:26 AM by roestigraben
    Change in database structure (adding fields to tables)
    roestigraben
      Hello,
      this question is about optimal workflow.
      My application running well today, I now need to add more stuff. This requires that I add more fields to some tables in the MySQL database and exploit them accordingly inside the application.
      step 1 :
      change the database
      step 2 :
      the services do not work anymore and need to be adapted.
      Here is my question:
      Should I edit the xyzservices.php manually to reflect the new fields (as these services are basically CRUD services, I would need to change several places inside the file),
      or,....
      Should I regenerate the services automatically with the wizard, however risking that other things brake in the application.
      step 3:
      adapt the application take advantage of the new fields: no problem here
      I feel this is quite a tricky thing and would appreciate some opinions from the gurus.
      BR
      peter
