0 Replies Latest reply on Oct 20, 2011 11:22 AM by SilentChris
    Generate build_config.xml / configuration equivalent to Flash Builder
    SilentChris
      I develop an AIR app where we code/debug within Flash Builder but when we generate publicly downloadable builds, it is done via command-line scripts. I'm currently seeing a bug which shows up in the command-line builds but that I cannot reproduce inside Flash Builder. Is there a way to generate a build_config.xml and air-config.xml file that would be equivalent to what is being used by Flash Builder to see if the issue is due to a compilation difference?
