2 Replies Latest reply on Oct 24, 2011 6:41 AM by xandout
    how to export data from datagrid to openoffice excel sheet in flex 4 mxml web application.
    Venkatesan Balasubramanian Level 1
      Hello friends,
      I am having one data grid it having 9 columns and 10 rows, now i want to export this data into to excel,how to creat new excel and export this data into a excel
      to that excel,
      i am using openoffice, as3xls 1.0.0,flashplayer,
      i created excel sheet but it not showing all my records, it showing only one record,that also not in alingnment.
      how to created a new and export data to that openoffice excel file.
      my code is:
      Reportgrid denote the id of the datagrid.
      [Bindable]
                  private var fields: Array = new Array ();
                  private function generateXLS(e:MouseEvent):void{
                      sheet = new Sheet ();
                      var dataProviderCollection: ArrayCollection = Reportgrid.dataProvider as ArrayCollection;
                      var rowCount: int = dataProviderCollection.length;
                      sheet.resize (rowCount+1,Reportgrid.columnCount);
                      var columns: Array = Reportgrid.columns;
                      var i: int = 0;
                      for each (var field: DataGridColumn in columns)
                          fields.push (field.dataField.toString());
                          sheet.setCell (0, i, field.dataField.toString());
                          i++;
                      for (var r:int = 0; r<rowCount; r++)
                              var record:Object = dataProviderCollection.getItemAt (r);
                              insertRecordInSheet (r +1,sheet,record);
                          var xls:ExcelFile = new ExcelFile ();
                      xls.sheets.addItem (sheet);
                      var bytes:ByteArray = xls.saveToByteArray ();
                      var fr:FileReference = new FileReference ();
                      fr.save(bytes, "Reports.xls");
                      private function insertRecordInSheet (row:int, sheet:Sheet, record:Object): void
                          var colCount: int = Reportgrid.columnCount;
                          for (var c:int; c<colCount; c++)
                                  var i:int = 0;
                                  for each (var field: String in fields)
                                      for each (var value: String in record)
                                          if (record [field].toString()== value)
                                              sheet.setCell (row, i, value);
                                      i++;
      Please give any useful suggession or snippet sample.
      Thanks in advance,
      cheers,
      B.venkatesan,
