3 Replies Latest reply on Oct 22, 2011 10:30 AM by kglad
    Help..... Its attaching to the centre!!!!!!
    LukeElChul Level 1
      well im making a game like asteroids so far everything is working. then i decided to make a wall and create a script to make that wall fall down when hit by a roket that works also when it gets hit by a bullet. the problam is that the roket explotion and the bullet decal attach to the centre of the wall, when i want them to attach to where ever the Bullet/Roket Hits.
      heres my script.
      onClipEvent(load){
      var broken:Boolean = false
      onClipEvent(enterFrame){
      for(i=0;i<_root.RoketArray.length;i++){
      if(this.hitTest(_root.RoketArray[i])){
      if(broken == false){
      removeMovieClip(_root.RoketArray[i])
      attachMovie("Explosion1","E",_root.getNextHighestDepth(),{_x:Roket._x,_y:Roket._y})
      gotoAndPlay(2);
      broken = true;
      }else if
      (broken == true)
      gotoAndStop(14);
      broken = true;
      for(i=0;i<_root.bulletArray.length;i++){
      if(this.hitTest(_root.bulletArray[i])){
      removeMovieClip(_root.bulletArray[i])
      attachMovie("BulletDecal","BD",_root.getNextHighestDepth(),{_x:Bullet._x,_y:Bullet._y})
      thanks in advance (:
        • 1. Re: Help..... Its attaching to the centre!!!!!!
          you probably want:
          onClipEvent(load){
          for(i=_root.RoketArray.length-1;i>=0;i--){
          var mc:MovieClip=_root.RoketArray[i];
          mc._parent.attachMovie("Explosion1","E",_root.getNextHighestDepth(),{_x:mc._x, _y:mc._y})
          _root.RoketArray.splice(i,1);
          mc._parent.removeMovieClip(mc)
          gotoAndPlay(2);
          broken = true;
          }else if
          (broken == true)
          gotoAndStop(14);
          broken = true;
          for(i=root.bulletArray.length-1;i>=0;i--){
          var mc:MovieClip=_root.bulletArray[i];
          mc._parent.attachMovie("BulletDecal","BD",_root.getNextHighestDepth(),{_x:mc. _x,_y:mc._y})
          _root.bulletArray.splice(i,1);
          mc._parent.removeMovieClip(mc);
          • 2. Re: Help..... Its attaching to the centre!!!!!!
            LukeElChul Level 1
            thanks. your the best (:
            it had errors so i worked it out intill i got this.
            onClipEvent(load){
            mc._parent.attachMovie("Explosion1","E",_root.getNextHighestDepth(),{_x:mc._x,_y:mc._y})
            gotoAndPlay(2);
            broken = true;
            }else if
            (broken == true)
            gotoAndStop(14);
            broken = true;
            mc._parent.attachMovie("BulletDecal","BD",_root.getNextHighestDepth(),{_x:mc._x,_y:mc._y} )
            THANKS!!!!!!!!!!!!!!!!!
            • 3. Re: Help..... Its attaching to the centre!!!!!!
              you're welcome.
              (but, you should be looping through both for-loops from the end to the beginning.)
