1 Reply Latest reply on Oct 22, 2011 6:45 AM by Ned Murphy
    Need help: input text
      I would like to design an application that allows me to do:
      1- write a website link in an input text
      2- click on a button, so the link is saved into a an variable
      3- by using geturl, the application opens the website in a new window
      I tried this:
      on (release) {
           ch= _root.da;
           getURL(ch, "_blank");
      // "da" the name of the input text
      by using this, when I click on this movieclip, firefox is opened in my homepage, not the written website of the input text.
      pleaze help.
        • 1. Re: Need help: input text
          If da is the instance name of the textfield, then you need to target its text property...   ch= _root.da.text;
          You should learn to not place code on objects and use timeline code instead.  If you give your button an instance name (btn), then in the timeline you would use:
          btn.onRelease = function(){
               ch= _root.da.text;
          Note: The _root reference is not needed if you are coding in the main timeline
