1. Re: The Folio Builder panel, design-wise...
Peter Villevoye Oct 22, 2011 3:30 PM (in response to Peter Villevoye) -
2. Re: The Folio Builder panel, design-wise...
Johannes Eckert Oct 22, 2011 3:48 PM (in response to Peter Villevoye)very good. these all need to be addressed. the experience of the folio
builder panel is bad... I have so many ideas of a redesign in my mind, but
I'm not in charge. maybe this thread can turn into a design ideaas for the
Panel.
good start, Peter!
(mobil gesendet)
Am 23.10.2011 00:30 schrieb "Peter Villevoye" <forums@adobe.com>:
Re: The Folio Builder panel, design-wise... created by Peter Villevoye<http://forums.adobe.com/people/Peter+Villevoye>in
Digital Publishing Suite - View the full discussion<http://forums.adobe.com/message/3985568#3985568>
3. Re: The Folio Builder panel, design-wise...
EvBurk Oct 22, 2011 7:24 PM (in response to Johannes Eckert)Looking for advice on logging in to the Folio Builder. Error: [svr.Unknown]
Do I need more than a 'normal' Adobe account? (is there a publishing group I need to belong to?)
Thanks in advacne for help/advice - self learning this in Malaysia.
Cheers,
Ev
4. Re: The Folio Builder panel, design-wise...
Bob Levine Oct 23, 2011 5:51 AM (in response to EvBurk)Have you updated all tools to the most recent version? Do you have a verified Adobe account?
Bob
5. Re: The Folio Builder panel, design-wise...
Johannes Eckert Oct 23, 2011 6:12 AM (in response to EvBurk)to make sure your account works with DPS log into
digitalpublishing.Acrobat.com. then a few flags might be set, but in fact
there is no special trick or group.
—Johannes
(mobil gesendet)
6. Re: The Folio Builder panel, design-wise...
EvBurk Oct 23, 2011 7:17 PM (in response to Bob Levine)Thanks to you both,
I do have an account (I can log into the DigitalPublishing site, as well as the general Adobe site)
I am running CS5 and have updated with:
AdobeDigitalPublishing-All.dmg as well as
AdobeDigitalPublishing-Tools.dmg
All of the DP panels open and the features work, still trouble loggin in.
Maybe there's another patch or update that I'm needing?
Thanks again,
Ev
7. Re: The Folio Builder panel, design-wise...
EvBurk Oct 23, 2011 7:55 PM (in response to EvBurk)Just double checked, have not installed the "FolioPanel.dmg" although I can open the panel, so will retry.
And that fixed it!
Thanks for the patience and help.
Ev
8. Re: The Folio Builder panel, design-wise...
Peter Villevoye Oct 24, 2011 1:12 AM (in response to EvBurk)Don't trust the "Update" button in the Folio Builder panel (another buggy and therefore useless feature...) It points to a page where only 'fresh' and not 100% up-to-date complete installs can be found. For now, use, trust, and refer to this URL and especially the "Update" section (halfway the page):
http://help.adobe.com/en_US/digitalpubsuite/using/WS67cb9e293e2f1f60-21ba9a4512e5e5e0b8d-7 ffe.html
This separate/modular installing and updating of extensions, tools and apps is necessary. It prevents that users who already work with ADPS, inadvertedly produce folio's that don't run on older viewers (which they need to update first, before updating all tools inside of InDesign).
Getting it to work can be Rocket Science...
9. Re: The Folio Builder panel, design-wise...
vividi Oct 24, 2011 3:53 AM (in response to Johannes Eckert)To Johannes Henseler,
"I have so many ideas of a redesign in my mind, but
Panel".
USERS SPEAK UP LET ADOBE KNOW
Regards
Vividi
10. Re: The Folio Builder panel, design-wise...
Peter Villevoye Oct 24, 2011 4:11 AM (in response to vividi)I think - no, I'm SURE, Adobe "knows" most of this.
But limited time and resources urges them to prioritize.
So it's necessary to help them set priorities - by yelling !
Some development is a matter of ideas and inspriration;
some development is done by sheer democratics...
11. Re: The Folio Builder panel, design-wise...
John J Metzger Oct 24, 2011 2:48 PM (in response to Peter Villevoye)Feel free to openly discuss any improvements or behavior changes you'd like to see made to the folio builder panel. We value comments and suggestions from people actively using the products in the field. I have several usability improvements I'd like to see made to the panel, it just becomes a tradeoff between increasing stability, usability and new features. Input on these forums does get listened to and acted on.
12. Re: The Folio Builder panel, design-wise...
Peter Villevoye Oct 26, 2011 2:42 AM (in response to John J Metzger)I think one very tiny change might already help (both new and routined) users to distinguish quickly between the several states of the panel: make the article bars less high. There are not only more than enough articles in a regular pub to be happy with more entries in the panel's view size, it also helps to instantly see that you're in the 'other' state. And maybe the Layout state might sport a different ordering of the two obvious thumbnails, leaving a tinted gap in the pane for the missing layout(s). In that way all states are easier to distinguish and understand.
It also frees up some space to design a bit more explanantory and helpful navigational bar at the top of the panel. It's clumsy, having to navigate so often and carefully through such a cryptic interface.
