2 Replies Latest reply on Nov 3, 2011 8:16 AM by JohnDevlon
    [AS][CS5] How to check if a book file has missing documents?
    JohnDevlon Level 1
      Does anyone know how to check a active book file for missing documents using Applescript?
      Thanx
      John
        • 1. Re: [AS][CS5] How to check if a book file has missing documents?
          riddifog Level 1
          Hi
          I have not been able to access all the properties of the book contents of a book such as status, but I can get the "full name" of each of the book contents. As this is the full file path to where InDesign thinks the file is, you can try to make it into an alias, if the file is not there it will fail. If you use a try statement you can catch which file paths failed.
          tell application "Adobe InDesign CS3"
                set missingBookFiles to {}
               repeat with x from 1 to count of book content of book 1
                    set bookPath to full name of book content x of book 1
                    try
                         set bookPath to bookPath as alias
                    on error
                         copy bookPath  to end of missingBookFiles
                    end try
               end repeat
          end tell
          return missingBookFiles
          I hope that is of help.
          Gareth
          • 2. Re: [AS][CS5] How to check if a book file has missing documents?
            JohnDevlon Level 1
            Hi Gareth,
            Thanks for your great feedback. It works super.
            John
