2 Replies Latest reply on Oct 23, 2011 5:13 PM by sonofmrsnak
    Object/image selection toggle issue
    sonofmrsnak Level 1
      Went from CS3 to CS5 and discovered that they retooled image selection. Never can tell whether I'm cropping the image or resizing it. With the object selection tool selected, the circle graphic seems to indicate that it's safe to crop, but this is always an uncertain when working quickly. Is there anyway to disable this so I can go back to the more intuitive object select and direct select as separate functions. (in other words, the CS3 default)
      Really a pain when you are importing, cropping and resizing. Those rolleover object frames only compound the problem. Glad they allow you to disable those in 5.5.
      TIA
