4 Replies Latest reply on Oct 25, 2011 12:17 PM by pantelis224466
    How to vertical align a .swf in html
    pantelis224466
      Hi there.
      I use the following code to horizontically align my swf on screen. How about vertical align?
      Thank you in advance
        • 1. Re: How to vertical align a .swf in html
          google:  css vertical align
          • 2. Re: How to vertical align a .swf in html
            pantelis224466 Level 1
            Ok i found the solution.
            In html file i have this code:
            <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN"
            "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
            <html lang="en" xml:lang="en" xmlns="http://www.w3.org/1999/xhtml">
            <head>
                <title>Title</title>
                <link type="text/css" rel="stylesheet" href="align.css" media="screen" />
            </head><body>
                <object type="application/x-shockwave-flash" data="main.swf">
                    <param name="movie" value="main.swf" />
                </object>
            </body></html>
            and in align.css this:
            html, body {
                width:100%;
                height:100%;
                margin:0px;
                padding:0px;
                border-left:0px;
                border-right:0px;
            html {
                overflow:hidden;
            body {
                top:50%;
                position:absolute;
            object {
                top:-455px; /* 50% of height */
                width:910px;  /* swf width */
                height:910px; /* swf height */
                margin:0px auto 0px auto;
                display:block;
                position:relative;
            and it really works!
            • 3. Re: How to vertical align a .swf in html
              adninjastrator Level 4
              Have you tried this at several different screen resolutions/sizes?
              Using CSS like "position:absolute" can really screw things up unless you really know what you are doing... and "overflow:hidden" will remove the scroll bars and not allow viewing of content if viewer resized screen to smaller than yuor content.
              Post a link if you would like feedback on how well your solution works.
              Best wishes,
              Adninjastrator
              • 4. Re: How to vertical align a .swf in html
                Basically, i have an index.html which loads first. In this, i have a script like this:
                <script language="javascript">
                w = screen.width;
                h = screen.height;
                if ((w <= 1400) || (h <= 1050)){
                window.location.href="http://www.mysite.com/index-s.html";
                } else if ((w > 1400) || (h > 1050)){
                window.location.href="http://www.mysite.com/index-l.html";
                </script>
                This happened because firstly, i was asked to design a .swf in 900 x 585 then they wanted bigger (1400 x 910) and finally they wanted both depending on the resolution.
                I have tested my html files in different resolutions and they work fine!
