3 Replies Latest reply on Oct 25, 2011 3:07 AM by rlloyd9
    CS5 - default settings for Quick Apply menu
    rlloyd9 Level 1
      I need to set the defaults for Quick Apply to just Paragraph p: and Text c:
      How do I access the preferences for Quick Apply in javascript ?  (CS5)
      thanks in advance
      René
        • 1. Re: CS5 - default settings for Quick Apply menu
          rlloyd9 Level 1
          it seems to be something like this ( if the menus are in Danish, that is )
          var Anvend = app.menus.itemByName( 'Menuen Indstillinger for Anvend hurtigt').menuItems;
          for(var myCounter1 = 0; myCounter1 < Anvend.length; myCounter1 ++){
               if (Anvend[myCounter1].name== 'Medtag tegnformater (c:)' ) {
                   try {
                          Anvend[myCounter1].select()
                   catch (myError)
                          // select fails if already set
               else if  (Anvend[myCounter1].name== 'Medtag afsnitsformater (p:)' ) {
                  try {
                  catch (myError)
               else
                  try {
                          Anvend[myCounter1].remove()
                  catch (myError)
                          // remove fails if already gone
                   } // end if
                   } // end for
          • 2. Re: CS5 - default settings for Quick Apply menu
            rlloyd9 Level 1
            Except, this wasn't exactly what I wanted.  I want to uncheck the menuitems, not remove them. But checked is a readonly attribute. Is this not possible then ?
            • 3. Re: CS5 - default settings for Quick Apply menu
              rlloyd9 Level 1
              I have also looked at defining a custom workspace with a menu setup - this allows me to hide menuitems - but it doesn't let me set a default for checked / unchecked...
