4 Replies Latest reply on Oct 24, 2011 8:11 PM by Jeffery Paul2nd
    Dynamic link confusing two separate AE compositions in PPro from different projects
    Jeffery Paul2nd
      I am using CS5 Master Collection for Windows 7 (64 bit) on an HP Pro desktop (Intel core 2 duo, 6Gb RAM). The tower has two hard drives installed (no RAID). CS5 is installed on the original C drive along with the OS, but the working files, footage etc are all on the larger, secondary F drive.
      I am working on a DVD project consisting of several seperate PPro projects. Each project has been colour corrected in AE using dynamic linking. Recently two of my projects suddenly became mixed up, by which I mean the video (not the audio) from one AE composition in one project has taken the place of another in another project. The clip remains the same length, but the link apears to be referencing the wrong clip during playback. Interestingly, there are two clips on the track above the affected clip that fade out and in at either end, during the dissolves between clips, the correct footage plays. It is only when the clip plays by itself that the problem occurs. The next clip also has the same error, though the problem only occurs for half the clip and then suddenly corrects itself. Just to be clear, All clips have been rendered, there are no more than two video tracks on the sequence, and I have tried replacing the composition from the asset menu (in which the clip plays back correctly), but the problem remains in the sequence.
      I hope that descrition is clear enough. My guess is some kind of file path error in the dynamic link, perhaps due to the separate hard drive. But I really wouldn't know. I'm very pressed for time right now and I'd prefer not to go against workflow and re-edit a new composition in AE, I would also like to understand what is going on in case it happens again.
      Any help with ths problem would be appreciated,
      J
        • 1. Re: Dynamic link confusing two separate AE compositions in PPro from different projects
          lasvideo Level 4
          It could be naming conventions. I had that happen doing dynamic links at first. I would Make Clip 1 an AE Composition which would open up an AE Project. Then I would select clip 2 and Make Clip 2 an AE composition which would open ANOTHER AE Project. This confused PrP when it later looked for the media, it got those 2 files mixed up when it accessed them.. What I should have done is selected Edit Original when working with Clip 2 and that clip would be a part of the Original Project file (which now had a comp for Clip 1 and a comp for Clip 2).
          • 2. Re: Dynamic link confusing two separate AE compositions in PPro from different projects
            Jeffery Paul2nd Level 1
            Thanks for your reply,
            I suspect you're right about the naming conventions. However, every Premier project has 1 corresponding After Effects project each, in which all compositions for that project are contained. Also each clip in PPro, and subsequently in AE, is from a separate footage file, ie these compositions aren't referencing parts of the same original footage file.So I think I'm already doing what you are suggesting. BUT these compositions could be getting confused between projects because the naming conventions are the same for each. There are 12 Premier projects in total, each with around 15 compositions each. I would really prefer not to have to combine all of these AE projects into one just so all the comps have different names. I hope there is another answer...
            Date: Mon, 24 Oct 2011 18:47:03 -0600
            To: jeffjpaul@hotmail.com
            Subject: Dynamic link confusing two separate AE compositions in PPro from different projects
                created by lasvideo in Premiere Pro CS5 & CS5.5 - View the full discussion
                 Replies to this message go to everyone subscribed to this thread, not directly to the person who posted the message. To post a reply, either reply to this email or visit the message page: http://forums.adobe.com/message/3988558#3988558
                 To unsubscribe from this thread, please visit the message page at http://forums.adobe.com/message/3988558#3988558. In the Actions box on the right, click the Stop Email Notifications link.
                 Start a new discussion in Premiere Pro CS5 & CS5.5 by email or at Adobe Forums
              For more information about maintaining your forum email notifications please go to http://forums.adobe.com/message/2936746#2936746.
            • 3. Re: Dynamic link confusing two separate AE compositions in PPro from different projects
              Colin Brougham Level 6
              It's not the comps that are the problem; it's the project file names themselves. You can have all the comps in a project named the same thing, and it'll be fine, but naming projects incrementally is an issue.
              After Effects includes a versioning function (Save and Increment) that will create a new AE project file with a serial number, e.g. AE Project 01, AE Project 02, etc. This is all well and good if you're just working in After Effects, but Dynamic Link gets confused and will usually start looking at the later project file for comps. That will just create a big mess, as you've found.
              Changing the names of the project files won't help things relink automatically properly, but it can help you fix things. Make all your DL AE comps offline in your Pr projects, and name your AE projects in a manner that is not serial (give them more random names). Select your offline AE comps, and right-click > Link Media, and point to the new AE project. Things should link up correctly then--but if they don't, you'll just have to remove all the AE comps from your Pr project, reimport the comps from the newly-named AE project, and replace them. It's a pain but it'll probably just keep getting worse if you don't.
              • 4. Re: Dynamic link confusing two separate AE compositions in PPro from different projects
                Thanks Colin, I tried what you suggested with both the AE Project that it should be referencing and the AE project it is erroneously referencing but both failed to fix the issue. Its as if a hidden clip were laid over the top of the one I want to play. Frustrating.
                Date: Mon, 24 Oct 2011 19:47:03 -0600
                    created by Colin Brougham in Premiere Pro CS5 & CS5.5 - View the full discussion
                It's not the comps that are the problem; it's the project file names themselves. You can have all the comps in a project named the same thing, and it'll be fine, but naming projects incrementally is an issue. After Effects includes a versioning function (Save and Increment) that will create a new AE project file with a serial number, e.g. AE Project 01, AE Project 02, etc. This is all well and good if you're just working in After Effects, but Dynamic Link gets confused and will usually start looking at the later project file for comps. That will just create a big mess, as you've found. Changing the names of the project files won't help things relink automatically properly, but it can help you fix things. Make all your DL AE comps offline in your Pr projects, and name your AE projects in a manner that is not serial (give them more random names). Select your offline AE comps, and right-click > Link Media, and point to the new AE project. Things should link up correctly then--but if they don't, you'll just have to remove all the AE comps from your Pr project, reimport the comps from the newly-named AE project, and replace them. It's a pain but it'll probably just keep getting worse if you don't.
                     Replies to this message go to everyone subscribed to this thread, not directly to the person who posted the message. To post a reply, either reply to this email or visit the message page: http://forums.adobe.com/message/3988711#3988711
                     To unsubscribe from this thread, please visit the message page at http://forums.adobe.com/message/3988711#3988711. In the Actions box on the right, click the Stop Email Notifications link.
