5 Replies Latest reply on Oct 27, 2011 9:32 AM by tmooney
    PC specs for HD editing
    tmooney
      I would like to edit some projects that were shoot in AVCHD. I currently use FCP but I would like to work at home on my PC and I am not sure if the computer has enough speed to do what I need to do. The projects are mostly theatre plays so they are 2hrs or more and I want the ability to export in 16 x 9 for a DVD master. My PC is older; it's a dual core 2.66 with 4meg of RAM. Is that enough to work with longer projects. Thanks.
        • 1. Re: PC specs for HD editing
          We usually recommend a quad core or i7 processor for editing AVCHD. However, Macs work a bit more efficiently. So, at least with version 10, you may be able to get by -- assuming your project is set up correctly.
          But on a PC, I'd still recommend a quad core or i7.
          • 2. Re: PC specs for HD editing
            Aimed at CS5, but This message has a really good graphic about requirements
            CS5 Requirements http://forums.adobe.com/thread/810750?tstart=0
            • 3. Re: PC specs for HD editing
              tmooney Level 1
              Good chart. Things are different with the Mac's. Will probably need a new PC down the road. Thanks again.
              • 4. Re: PC specs for HD editing
                jeffgedgaud
                The system requirements from Adobe call for a 2GHz or faster and Dual Core is recommended for the higher resolution video but you will definetely need something better than a dual core and 2GHz processor. I found a four core is a minimum for video editing and closer to 3 GHz is better for faster rendering. Memory is also important and if possible more than 4 GB is nice to use for rendering and editing, a 64 bit operating system will give you the ability to use more than 4 GB of memory.
                http://www.adobe.com/products/premiere-elements/tech-specs.html
                The chart does not really give specifics but the eight core is overshooting it in my opinion unless your going to be building a video editing machine. You can build a system specifically for video editing but as you are only purchasing Elements I would recommend a good computer with a quad core processor at or close to 3GHz and at least 4 GB of Memory.
                A lot of people on this forum like to give information that does not coincide with people editing video as a hobby, they give a lot of information geared toward the professional and can often forget that people using Premiere Elements are not going to be designing a computer for thier video editing when their only paying a hundred or less for the editing program.
                • 5. Re: PC specs for HD editing
                  tmooney Level 1
                  Thanks for the reply. I have FCP on a MAC at work for anything involved but this is for me to do some small stuff at the house. I need to assemble a timeline and export for DVD, very little editing involved. I will make sure that I get at least a Quad Core which should be safe. I can find one used.
