1. Re: Can't Capture from Sony HDV-Z1 into Premiere Pro CS5
Harm Millaard Oct 25, 2011 9:14 AM (in response to nikokanakis)If you shot in DV PAL, capture in DV PAL. Make sure your menu settings on the Z1 reflect that. Don't have a Z1 available now, but check the menu and it will be 'no problemo'.
2. Re: Can't Capture from Sony HDV-Z1 into Premiere Pro CS5
nikokanakis Oct 25, 2011 9:13 AM (in response to nikokanakis)Thanks Harm,
Yes, that was one of the items that I checked. I have the import/capture settings for DV PAL.
Any other suggestions?
Thanks for the speedy reply. Impressive!
3. Re: Can't Capture from Sony HDV-Z1 into Premiere Pro CS5
JSS1138 Oct 25, 2011 6:20 PM (in response to nikokanakis)I have the import/capture settings for DV PAL.
In the camera as well?
4. Re: Can't Capture from Sony HDV-Z1 into Premiere Pro CS5
Yiu-kun Oct 25, 2011 9:47 PM (in response to nikokanakis)Unless you're doing televised work, why not shoot in the world-wide standard of 23.976FPS? This would've saved you quite a lot of hassle.
Also, after configuring the IO you need to save and restart the application. A friend of mine running CS5.0 had to do that after hours of struggling. A simple "turn it off and on again" trick.
5. Re: Can't Capture from Sony HDV-Z1 into Premiere Pro CS5
Alan Craven Oct 26, 2011 2:45 AM (in response to nikokanakis)With most Sony HDV cameras or recorders, you have to have the output set to HDV or DV, as appropriate - the AUTO setting will not work. If you change this setting, you must do it with the camera disconnected, then re-connect it via firewire.
I have a broadly similar Sony V1E camera and a sony GV-HD700 recorder, and the above applies to both of them - as does the need to change the firewire driver to "legacy".
Apart from the above there should be no problem if you are capturing to a project with the same settings as the camera. As Harm sdays, If you are trying to capture to an NTSC project from a tape recorded as PAL, it simply will not work. You will have to do the conversion on export.
6. Re: Can't Capture from Sony HDV-Z1 into Premiere Pro CS5
anthony102504 Nov 15, 2012 6:45 AM (in response to Harm Millaard)I have just spent the usual 24 hours searching for a solution. I am so delighted that I found it (on Microsoft) that I wanted to share it here for anybody in the same frustrating postion!
I bought a new monster HP PC. As it didn't come with an IEEE 1394 firewire I bought a Startech card. However my Sony Z1 and CS5.5 capture would only partially work on the new machine; no vision or sound on capture screen and batch didn't work. Tried everything and (the last) one worked!
The JMicron chip has a 'problem', which the nice HP people wrote a new driver for http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&dlc=en&lc=en&softwar eitem=ob-74849-1&jumpid=reg_R1002_USEN. Apparently it works for other machines.
Harm please put this post where you think others may search.
7. Re: Can't Capture from Sony HDV-Z1 into Premiere Pro CS5
0to60tv Nov 15, 2012 6:58 AM (in response to anthony102504)Thank you for taking the time to post up your solution, all to often these threads dissapear once the OP finds the solution and never returns to share it!
8. Re: Can't Capture from Sony HDV-Z1 into Premiere Pro CS5
John T Smith Nov 15, 2012 8:10 AM (in response to nikokanakis)When you are ready, Convert NTSC <--> PAL http://forums.adobe.com/thread/995779
9. Re: Can't Capture from Sony HDV-Z1 into Premiere Pro CS5
anthony102504 Nov 20, 2012 9:41 AM (in response to 0to60tv)You thanked me too soon!
Just around the corner ...... PP started crashing, in capture mode, all over the place. In the end a newly bought, different manufacturer's IEEE 1394 firewire card, having a different chip set, worked perfectly from installation and with no driver issues. Fortunately they are cheap but as you see, its 5 days later.
10. Re: Can't Capture from Sony HDV-Z1 into Premiere Pro CS5
John T Smith Nov 20, 2012 10:29 AM (in response to anthony102504)Use a TI chip for firewire http://forums.adobe.com/thread/940242
