3 Replies Latest reply on Oct 25, 2011 7:11 PM by drkstr_1
    MXML Components and ActionScript Classes
    numba1john
      Hello,
      I am fairly new to Flex and OOP and am confused on how some parts of OOP work.
      I have a Spark TextInput Component with an id which equals "test".
      I also have a function that takes "test.text", appends a string to and and puts the resulting value into another TestInput called test2.
      How can I move the "appendPhrase()" function into a class so that it would still accept values from "test" and change the "text2" values?
      I tried creating a function that would assign the value of the varaible in the class using classname.variable name, made it bindable, and assigned
      the text value of the textinput that value, but I was wondering if there was any other way I could do that?
      ~~~~~~~~~~~~~~~~Version1~~~~~~~~~~~~~~~~~~~~~
      <fx:Script>
          private function appendPhrase():void
              test2.text = test.text + " was added";
      </fx:Script>
      <s:TextInput x="0" y="0" id="test" />
      <s:TextInput x="0" y="10" id="test2" />
      <s:Button click="appendPhrase();" />
      ~~~~~~~~~~~~~~~~~~Version 2:~~~~~~~~~~~~~~~~~
      function in class:
      public class ChangeString
          [Bindable]
          public var text:String;
          private function appendPhrase(firstString:Object):void
             text = firstString.text + " was added";
      main.mxml:
      [Bindable]
      public var changed:Object = new ChangeString();
      <s:TextInput x="0" y="0" id="test" click="changeValue(test.text)" />
      <s:TextInput x="0" y="10" id="test2" text="{changed.text}"/>
        • 1. Re: MXML Components and ActionScript Classes
          drkstr_1 Level 4
          package models
                    [Bindable]
                    public class MyViewModel
                              public var text:String "Hello ";
                              public function appendText(t:String):String
                                        this.text = this.text + t;
                                        return this.text;
          <fx:Script>
          <![CDATA[
          import models.MyViewModel;
          [Bindable]
          public var model:MyViewModel = new MyViewModel();
          </fx:Script>
          <s:TextInput id="test" x="0" y="0" click="this.model.appendText(this.test.text)" text="World" />
          <s:TextInput id="test2" x="0" y="10" text="{this.model.text}" />
          I would go about it a little differently maybe. I would use the model class as a data holder, and use a private local method, utility class, or controller class to modify values on the model (data holder class).
          • 2. Re: MXML Components and ActionScript Classes
            numba1john Level 1
            Why did you use the "this" (don't know how to call it)... variable?
            I removed all the "this" variables and it still worked fine.
            • 3. Re: MXML Components and ActionScript Classes
              drkstr_1 Level 4
              'this' points to whatever the current class scope is.
              It is somewhat of a standard coding convetion to use 'this' on public properties and methods inside your class, but mostly it's just personal preferance. It also triggers the auto completion...
