2 Replies Latest reply on Jun 3, 2008 7:19 PM by slaingod
    Flex 3 CSS won't compile, HELP!!!
    Connect Studios Level 1
      As you can see in this image, design view finds the assets just fine, but it has compile errors. -> Flex CSS Foolishness
      Any suggestions???
        • 2. Re: Flex 3 CSS won't compile, HELP!!!
          slaingod Level 1
          Flex's css stuff seems to freak out occasionally. I find doing a clean build or a restart of the app helps. If not, then you probably have some bug in your CSS that isn't obvious that throws things off. Try removing each section of CSS until you see which section is causing the problem, then narrow it down.
          Also, keep in mind that assets are relative to their files and that can be problematic at times, especially when going from dev to production.
          I generally have my folders look like:
          src
          views
          assets
          bin-debug
          lib
          etc...
          I have my style.css in the assets folder along with my embeds and I still include everything as ../assets/ because they are relative to the src/App.mxml that they were included in as opposed to the location of the CSS file I believe.
