1 Reply Latest reply on Oct 27, 2011 2:37 AM by mauprice
    Parsing a string variable as baseURL
    mauprice Level 1
      I want to use a httpService request to read an XML file which retreives data from the xml file which is the path i want to parse to the Super_Sample1 Class / Function rather than having it as a hard coded path.
      I can read the XML file and display the path in a text field.
      Once the XML file resoonse is received it then triggers the HTTPService to receive the data using the path from the XLM file.
      I get an error when ever I modify the hard coded path to a variable like the {mypath.lastResult} which is where the XML path is returned to.
      I hope I explained this clear enough.
      Any suggestions on parsing this path to the Function shown below?
      package services.sample1
      import com.adobe.fiber.core.model_internal;
      import com.adobe.fiber.services.wrapper.HTTPServiceWrapper;
      import mx.rpc.AbstractOperation;
      import mx.rpc.AsyncToken;
      import mx.rpc.http.HTTPMultiService;
      import mx.rpc.http.Operation;
      [ExcludeClass]
      internal class _Super_Sample1 extends com.adobe.fiber.services.wrapper.HTTPServiceWrapper
          // Constructor
          public function _Super_Sample1()
              // initialize service control
              _serviceControl = new mx.rpc.http.HTTPMultiService("http://ibm/sample01-debug/"); <<<<<< This is what I want to replace with a string variable
               var operations:Array = new Array();
               var operation:mx.rpc.http.Operation;
               var argsArray:Array;
               operation = new mx.rpc.http.Operation(null, "Operation");
               operation.url = "mytest.php";
               operation.method = "GET";
               operation.resultType = Object;
               operations.push(operation);
               _serviceControl.operationList = operations;
               preInitializeService();
               model_internal::initialize();
          //init initialization routine here, child class to override
          protected function preInitializeService():void
            * This method is a generated wrapper used to call the 'Operation' operation. It returns an mx.rpc.AsyncToken whose
            * result property will be populated with the result of the operation when the server response is received.
            * To use this result from MXML code, define a CallResponder component and assign its token property to this method's return value.
            * You can then bind to CallResponder.lastResult or listen for the CallResponder.result or fault events.
            * @see mx.rpc.AsyncToken
            * @see mx.rpc.CallResponder
            * @return an mx.rpc.AsyncToken whose result property will be populated with the result of the operation when the server response is received.
          public function Operation() : mx.rpc.AsyncToken
              var _internal_operation:mx.rpc.AbstractOperation = _serviceControl.getOperation("Operation");
                          var _internal_token:mx.rpc.AsyncToken = _internal_operation.send() ;
              return _internal_token;
        • 1. Re: Parsing a string variable as baseURL
          mauprice Level 1
          It's ok, I have solved it now. I just needed to add another function to load the XML path as below.
                      loadXML();
                    public function loadXML(url:String=""){
                  _serviceControl = new mx.rpc.http.HTTPMultiService();
                   operation.url = url;
                   operation.serializationFilter = serializer0;
                   operation.resultElementType = valueObjects.Mytest_return;
