3 Replies Latest reply on Oct 25, 2011 11:24 PM by Flex harUI
    Filtering datagrid with textInput?
    xandout
      I have a datagrid that is populated from MySQL, I would like to have a "search" box on the page that will filter based on input.
      An example in Flash is here: http://www.adobe.com/devnet/flash/quickstart/datagrid_pt3.html
      The example there is instant, I do not really need instant. If it needs to be done with an onClick button event, that is fine.
      I have read through several web pages and forum posts here and have yet to find anything that I could understand.  Any help is welcome, links, code snippets, even just plain old advice.
      I really appreciate in advance guys.
        • 1. Re: Filtering datagrid with textInput?
          Flex harUI Adobe Employee
          Look for examples on using filterFunction in ArrayCollection.
          If you want a TextInput in the header, that is more challenging, but there should be examples out there.
          • 2. Re: Filtering datagrid with textInput?
            xandout Level 1
            OK What I had done before I saw this reply was create a copy of the getAllCustomer() function and changed this:
            $stmt = mysqli_prepare($this->connection, "SELECT * FROM $this->tablename");
            to this:
            $stmt = mysqli_prepare($this->connection, "SELECT * FROM customer WHERE customer.company LIKE '%$search%'");
            And with a button I call this:
            getAllCustomerResult.token = customerService.getAllCustomerSearch(custSearchText.text);
            I know this is creating a lot of overhead for my server as it is another flex ->  PHP -> MySQL call.
            I know this can be acheived without this and I did see references to this ArrayCollecton elsewhere I was just clueless on how to do this.
            Can you provide a link to an easy to follow article on this.
            Thanks a ton though.
            • 3. Re: Filtering datagrid with textInput?
              Just google for “flex examples arrayCollection filter”
