0 Replies Latest reply on Oct 27, 2011 6:24 AM by GIS_11
    Search/filter datagrid with webservice
    GIS_11
      I've been trying to create a search text input for my datagrid that is populated with a webservice. I've tried a few different ways like the filter function but not having much luck. Was wondering if this is even possible to do with a webservice? Here's an example of my code.
      <fx:Declarations>
           <s:Webservice id="websvc"
                                 wsdl=http://localhost/SLWorkOrder/Service.asmx?wsdl
                                 showBusyCursor="true"
                                 fault="faultHandler(event)">
                <mx:operation name="GetDataSet"
                                    result="GetDataSetHandler(event)"/>
           </s:Webservice>
      </fx:Declarations>
      <fx:Script>
      <![CDATA[
      import mx.collections.ArrayCollection;
      import mx.controls.Alert;
      import mx.events.CloseEvent;
      import mx.events.DataGridEvent;
      import mx.rpc.events.FaultEvent;
      import mx.rpc.events.ResultEvent;
      [Bindable]
      public var dataArray:ArrayCollection = new ArrayCollection();
      private var firstTime:Boolean = true;
      private function initApp():void
      // Initialize and load the web service
      websvc.loadWSDL();
      websvc.GetDataSet();
      * Result event handler for websvc GetDataSetHandler call
      private function GetDataSetHandler(e:ResultEvent):void
      // Populate dataArray with dataset table
      dataArray = e.result.Tables.sl_Work_Orders.Rows;
      *Fault event handler for websvc WebService call
      private function faultHandler(event:FaultEvent):void
      Alert.show(event.fault.message, "Application Error");
      ///if the textbox is empty, it then calls back all of the data. I actually use a 'reset' button to do this as well.
      private function filter():void
      dataArray.filterFunction = filterdataArray;
      dataArray.refresh();
      private function filterdataArray(item:Object):Boolean{
      var searchString:String = myTextInput.text.toUpperCase();
      var itemName:String = (item.Complaint_Type as String).toUpperCase();
      return itemName.indexOf(searchString) > -1;
      private function clearMyTextInput():void {
      if (firstTime == true )
      myTextInput.text = "";
      firstTime = false;
      </fx:Script>
      <s:TextInput id="myTextInput" width="100%" height="26" change="filter()" enabled="true" focusIn="clearMyTextInput()" text="Filter/Search.."/>
      The error I get when trying to search is -  TypeError: Error #1009: Cannot access a property or method of a null object reference.
