0 Replies Latest reply on Jun 3, 2008 10:31 AM by elextra
    How to expose Hibernate 'non' conventional beans into flex apps via remoting
    elextra
      I am relatively new to the flex world. I am from the Spring/Hibernate world.
      In Hibernate, the POJO object or domain object , or simply beans that you use to persist you object into the database does not have to follow the bean definition/contract, i.e: public default constructor with getter/setters. There are good reasons behind creating those kind of 'hibernate beans' (I will call them that way for lack of a better name). In fact, only defining a one-parameter constructor (i.e. omitting the default one) guaranties you that your client cannot invoke your API without that needed parameter. Likewise, exposing only the getters for some private member variables (without the setters) make sense when you don't want that variable to ever change, etc....hibernate can do all that using cglib, etc....
      Now, my understanding of Flex and how remote services work (from what I could see in all the samples around about hibernate/spring), is that your java server bean get proxied 'dynamically' or 'statically' if I wish into an Actionscript class object according to the rule: "values found in public bean properties with get/set methods and public variables ", therefore my public getVariable() from my 'hibernate' bean does not get sent back.
      This is creating me tons of problems, because the server API already exist and we already have a JSF implementation using it....Changing into flex is just my own initiative to prove that we can get better UI...
      What is flex/BlazeDS solution for fixing this case?
      One solution that comes to mind (not very bright, but should work) is to build a plain java bean object for each of these 'hibernate' beans to ensure the translation on both side between the 'hibernate bean' and the 'expected' bean from flex. From the server to the client, It would to copy the content of the hibernate bean and return those 'proper' beans back to flex. On the way out (from the client to the server), it would have to recreate the bean as exposed on the server before sending it to the server).... It's probably not the best solution, especially considering that eventually as some point, I will need to define another set of those object, in flex, using actionscript (I think these are what you guys call VOs) in order to do strong typing in flex........becomes very tough to manage!
      Any input would be valuable.
      Thank you,
