Hi
I have a merged html project which produces a Microsoft html (chm) file. The "window" in the master project is a "Webhelp Pro". The "window" in the child projects are "HTML Help" windows. Is there a way I can change the window type in my projects so that they are consistent and when a user selects a topic in one of the child projects it will not create a new window?
thank you
Steve
Hi Steve
The Window type you see in the Windows area depends on what the Primary Layout is set to. Well, sort of.
Really what I mean here is that if you choose to create a new window, it will be of the type that the Primary Layout is. You likely need to configure Microsoft HTML Help as your Primary Layout, then define a new window. At that point you should see properties for a CHM window.
Cheers... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7, 8 or 9 within the day! |
Hi Steve
Cheers... Rick
Thank you Rick Your answer was very helpful
