Our group finally applied the 9.0.1 update. When I first opened RH, it took about 10 minutes before it comes up. One of our other developers said that it took her 3 minutes to open hers, but when I went over to check, she was able to bring it up right away. Then I went to mine and opened it; it opened right away. I can't say what went on with her machine, but I can say that mine started opening right away after I had opened up a project. Before then, it was just slow to open, hanging on the splash screen for so long that I had thought it froze up.
I had the intention of telling our IT department that it might be a corrupted install. Now that it's opening just fine, I'm not sure what to tell them. I guess I'll tell them that the install works fine, but I want to check the community to see if this has happened to others or if I should be concerned about anything.
Kevin
Perhaps RoboHelp needed to recreate the CPD. If you're on a machine that's no so speedy, it may take a while. When the CPD is created, the project can be opened much faster. Other than that, is the project located on a network drive? If so, move it to your local as project on network drives are begging to be corrupted. (And take a lot longer to open,)
Greet,
Willam
Thank you for the response, Willam.
This isn't even related to a project. The delay was happening just by opening RoboHelp. I didn't even get as far as trying to open a project.
There seems to be nothing wrong with it now. I was just wondering if that was typical. It sounds like it might just be a fluke with our setup.
Kevin
Sounds like a damaged install. Try stripping it all off & reinstall.
Be very cautious while uninstalling you RoboHelp,
first the RH 9.0.1 patch should be uninstalled from the add/remove program then only the RoboHelp 9 should be uninstalled.
Hope this might help
Ashish
Thank you. It sounds like it's unique to just our install. Weird.
It *seems* to be working fine right now. If we run into problems, I'll keep the uninstall warning in mind.
Kevin
