I'm working on a game, that loads up external text files to create maps. There is a error if the player moves out of bounds, and there is no map to load. All I need is a sort of check to see if the text file actually exists, before loading it. Can anyone help me?
you can use the ioerrorevent of your urlloader to capture the error and take appropriate steps:
import flash.events.IOErrorEvent;
yourURLLoader.addEventListener(IOErrorEvent.IO_ERROR,f);
function f(e:IOErrorEvent):void{
//do whatever
Thanks, thats pretty helpful, though I suppose I should be more specific. If no map exists, I want to send the player back to the previous map, or not have him move at all. Let me include some code to show what I'm currently doing.
function MoveWest():void //Also have a function for each direction, but I'll just use the West function for example.
worldX--;
startX = stage.stageWidth - 32;
startY = myPlayer.y;
loadMap()
function loadMap():void
DestroyMap(); //In case this isn't self explainatory, this removes the previous map from the stage.
//Layer 1
mapLoader = new URLLoader();
mapLoader.addEventListener(Event.COMPLETE, onmapLoad);
mapLoader.addEventListener(IOErrorEvent.IO_ERROR,error1);
mapLoader.load(new URLRequest("Maps/L1/"+worldX+","+worldY+".txt"));
//Layer 2
mapLoader2 = new URLLoader();
mapLoader2.addEventListener(Event.COMPLETE, onmapLoad2);
mapLoader2.addEventListener(IOErrorEvent.IO_ERROR,error2);
mapLoader2.load(new URLRequest("Maps/L2/"+worldX+","+worldY+".txt"));
function error1(e:IOErrorEvent):void
//do whatever
trace("Something went wrong!");
function error2(e:IOErrorEvent):void
//do whatever
So basicly, I want something I can put into the "Move" functions, where if said text file doesn't exist, treat that direction as a solid wall.
i don't know what your 2 layers are but here's how you would load the previous map if you had one map/layer:
var previousMap:String;
worldX--;
loadMap()
function loadMap(s:String=null):void
//Layer 1
mapLoader.addEventListener(IOErrorEvent.IO_ERROR,error 1);
//Layer 2
mapLoader2.addEventListener(IOErrorEvent.IO_ERROR,erro r2);
if(!s){
} else {
mapLoader2.load(new URLRequest(s));
//do whatever
loadMap(previousMap);
function onmapLoad2(e:Event):void{
previousMap = "Maps/L2/"+worldX+","+worldY+".txt";
