1 Reply Latest reply on Oct 31, 2011 2:21 PM by Shongrunden
    Group degradation in perceived performance
    theMadPenguin
      Hi there,
      We recently upgraded to SDK 4.5.1 and noticed that our application took a hit in perceived responsiveness in the process. After digging around a bit I ran into a change in the Group class that is responsible for this degradation, the change itself is in bold:
          override public function set scrollRect(value:Rectangle):void
              // Work-around for Flash Player bug: if GraphicElements share
              // the Group's Display Object and cacheAsBitmap is true, the
              // scrollRect won't function correctly.
              var previous:Boolean = canShareDisplayObject;
              super.scrollRect = value;
              if (numGraphicElements > 0 && previous != canShareDisplayObject)
                  invalidateDisplayObjectOrdering();
              if (mouseEnabledWhereTransparent && hasMouseListeners)
                  // Re-render our mouse event fill if necessary.
                  redrawRequested = true;
                  super.$invalidateDisplayList();
      Below please find a small application that illustrates this problem. Note that I have monkey patched Group in the default package so that it is possible to compile with and without the code above. I find that a large screen and Chrome help showcase the problem.
      The part that I am not getting is what was the code in bold trying to fix in the first place?
      Thanks!!
      ~ Miguel
      <s:Application
          minWidth="955" minHeight="600"
          xmlns:fx="http://ns.adobe.com/mxml/2009"
          xmlns:mx="library://ns.adobe.com/flex/mx"
          xmlns:local="*">
          <fx:Script>
              <![CDATA[
                  private var _moveMode:Boolean = false;
                  protected function monkeypatchedgroup1_mouseMoveHandler(event:MouseEvent):void
                      // TODO Auto-generated method stub
                      if (_moveMode)
                          redBox.x = event.stageX;
                          redBox.y = event.stageY;
                  protected function bordercontainer1_mouseDownHandler(event:MouseEvent):void
                      _moveMode = true;
                  protected function monkeypatchedgroup1_mouseUpHandler(event:MouseEvent):void
                      _moveMode = false;
          </fx:Script>
          <fx:Declarations>
              <!-- Place non-visual elements (e.g., services, value objects) here -->
          </fx:Declarations>
          <local:MonkeyPatchedGroup
              width="100%" height="100%"
              mouseMove="monkeypatchedgroup1_mouseMoveHandler(event)"
              mouseUp="monkeypatchedgroup1_mouseUpHandler(event)">
              <s:BorderContainer id="redBox"
                  width="50" height="50"
                  backgroundColor="red"
                  mouseDown="bordercontainer1_mouseDownHandler(event)"/>
          </local:MonkeyPatchedGroup>
      </s:Application>
      Here is the monkey patched group:
      //  ADOBE SYSTEMS INCORPORATED
      //  Copyright 2008 Adobe Systems Incorporated
      //  All Rights Reserved.
      //  NOTICE: Adobe permits you to use, modify, and distribute this file
      //  in accordance with the terms of the license agreement accompanying it.
      package
          import flash.display.BlendMode;
          import flash.display.DisplayObject;
          import flash.geom.Rectangle;
          import mx.core.FlexVersion;
          import mx.core.IFlexModule;
          import mx.core.IFontContextComponent;
          import mx.core.IUIComponent;
          import mx.core.IUITextField;
          import mx.core.IVisualElement;
          import mx.core.IVisualElementContainer;
          import mx.core.UIComponent;
          import mx.core.mx_internal;
          import mx.events.FlexEvent;
          import mx.graphics.shaderClasses.ColorBurnShader;
          import mx.graphics.shaderClasses.ColorDodgeShader;
          import mx.graphics.shaderClasses.ColorShader;
          import mx.graphics.shaderClasses.ExclusionShader;
          import mx.graphics.shaderClasses.HueShader;
          import mx.graphics.shaderClasses.LuminosityShader;
          import mx.graphics.shaderClasses.SaturationShader;
          import mx.graphics.shaderClasses.SoftLightShader;
          import mx.styles.IAdvancedStyleClient;
          import mx.styles.ISimpleStyleClient;
          import mx.styles.IStyleClient;
          import mx.styles.StyleProtoChain;
          import spark.components.ResizeMode;
          import spark.components.supportClasses.GroupBase;
          import spark.core.DisplayObjectSharingMode;
          import spark.core.IGraphicElement;
          import spark.core.IGraphicElementContainer;
          import spark.core.ISharedDisplayObject;
          import spark.events.ElementExistenceEvent;
          use namespace mx_internal;
          //  Events
           *  Dispatched when a visual element is added to the content holder.
           *  <code>event.element</code> is the visual element that was added.
           *  @eventType spark.events.ElementExistenceEvent.ELEMENT_ADD
           *  @langversion 3.0
           *  @playerversion Flash 10
           *  @playerversion AIR 1.5
           *  @productversion Flex 4
          [Event(name = "elementAdd", type = "spark.events.ElementExistenceEvent")]
           *  Dispatched when a visual element is removed from the content holder.
           *  <code>event.element</code> is the visual element that's being removed.
           *  @eventType spark.events.ElementExistenceEvent.ELEMENT_REMOVE
           *  @langversion 3.0
          [Event(name = "elementRemove", type = "spark.events.ElementExistenceEvent")]
          //  Styles
           *  Color of text shadows.
           *  @default #FFFFFF
           *  @langversion 3.0
          [Style(name = "textShadowColor", type = "uint", format = "Color", inherit = "yes", theme = "mobile")]
           *  Alpha of text shadows.
           *  @default 0.55
           *  @langversion 3.0
          [Style(name = "textShadowAlpha", type = "Number", inherit = "yes", minValue = "0.0", maxValue = "1.0", theme = "mobile")]
          //  Excluded APIs
          [Exclude(name = "addChild", kind = "method")]
          [Exclude(name = "addChildAt", kind = "method")]
          [Exclude(name = "removeChild", kind = "method")]
          [Exclude(name = "removeChildAt", kind = "method")]
          [Exclude(name = "setChildIndex", kind = "method")]
          [Exclude(name = "swapChildren", kind = "method")]
          [Exclude(name = "swapChildrenAt", kind = "method")]
          [Exclude(name = "numChildren", kind = "property")]
          [Exclude(name = "getChildAt", kind = "method")]
          [Exclude(name = "getChildIndex", kind = "method")]
          //  Other metadata
          [ResourceBundle("components")]
          [DefaultProperty("mxmlContent")]
          [IconFile("Group.png")]
           *  The Group class is the base container class for visual elements.
           *  The Group container takes as children any components that implement
           *  the IUIComponent interface, and any components that implement
           *  the IGraphicElement interface.
           *  Use this container when you want to manage visual children,
           *  both visual components and graphical components.
           *  <p>To improve performance and minimize application size,
           *  the Group container cannot be skinned.
           *  If you want to apply a skin, use the SkinnableContainer instead.</p>
           *  <p><b>Note:</b> The scale grid might not function correctly when there
           *  are DisplayObject children inside of the Group, such as a component
           *  or another Group.  If the children are GraphicElement objects, and
           *  they all share the Group's DisplayObject, then the scale grid works
           *  properly.</p>
           *  <p>Setting any of the following properties on a GraphicElement child
           *  requires that GraphicElement to create its own DisplayObject,
           *  thus negating the scale grid properties on the Group.</p>
           *  <pre>
           *  alpha
           *  blendMode other than BlendMode.NORMAL or "auto"
           *  colorTransform
           *  filters
           *  mask
           *  matrix
           *  rotation
           *  scaling
           *  3D properties
           *  bounds outside the extent of the Group
           *  </pre>
           *  <p>The Group container has the following default characteristics:</p>
           *  <table class="innertable">
           *     <tr><th>Characteristic</th><th>Description</th></tr>
           *     <tr><td>Default size</td><td>Large enough to display its children</td></tr>
           *     <tr><td>Minimum size</td><td>0 pixels</td></tr>
           *     <tr><td>Maximum size</td><td>10000 pixels wide and 10000 pixels high</td></tr>
           *  </table>
           *  @mxml
           *  <p>The <code>&lt;s:Group&gt;</code> tag inherits all of the tag
           *  attributes of its superclass and adds the following tag attributes:</p>
           *  <pre>
           *  &lt;s:Group
           *    <strong>Properties</strong>
           *    blendMode="auto"
           *    mxmlContent="null"
           *    scaleGridBottom="null"
           *    scaleGridLeft="null"
           *    scaleGridRight="null"
           *    scaleGridTop="null"
           *    <strong>Events</strong>
           *    elementAdd="<i>No default</i>"
           *    elementRemove="<i>No default</i>"
           *  /&gt;
           *  </pre>
           *  @see spark.components.DataGroup
           *  @see spark.components.SkinnableContainer
           *  @includeExample examples/GroupExample.mxml
           *  @langversion 3.0
          public class MonkeyPatchedGroup extends GroupBase implements IVisualElementContainer, IGraphicElementContainer, ISharedDisplayObject
               *  Constructor.
               *  @langversion 3.0
              public function MonkeyPatchedGroup():void
                  super();
              //  Variables
              private var needsDisplayObjectAssignment:Boolean = false;
              private var layeringMode:uint = ITEM_ORDERED_LAYERING;
              private var numGraphicElements:uint = 0;
              private static const ITEM_ORDERED_LAYERING:uint = 0;
              private static const SPARSE_LAYERING:uint = 1;
              //  Overridden properties
              //  baselinePosition
               *  @inheritDoc
               *  @langversion 3.0
              override public function get baselinePosition():Number
                  if (FlexVersion.compatibilityVersion < FlexVersion.VERSION_4_5)
                      return super.baselinePosition;
                  if (!validateBaselinePosition())
                      return NaN;
                  var bElement:IVisualElement = baselinePositionElement;
                  // If no baselinePositionElement is specified, use the first element
                  if (bElement == null)
                      for (var i:int = 0; i < numElements; i++)
                          var elt:IVisualElement = getElementAt(i);
                          if (elt.includeInLayout)
                              bElement = elt;
                              break;
                  if (bElement)
                      return bElement.baselinePosition + bElement.y;
                  else
              [Inspectable(category = "General", enumeration = "noScale,scale", defaultValue = "noScale")]
               *  @private
              override public function set resizeMode(value:String):void
                  if (isValidScaleGrid())
                      // Force the resize mode to be scale if we
                      // have set scaleGrid properties
                      value = ResizeMode.SCALE;
                  super.resizeMode = value;
               *  @private
                      trace("Calling invalidateDisplayList in GroupBase");
               * @private
              override mx_internal function set hasMouseListeners(value:Boolean):void
                  if (mouseEnabledWhereTransparent)
                  super.hasMouseListeners = value;
               *  @private
              override public function set width(value:Number):void
                  if (_width != value)
                  super.width = value;
               *  @private
              override public function set height(value:Number):void
                  if (_height != value)
                  super.height = value;
              //  Properties
              //  alpha
              [Inspectable(defaultValue = "1.0", category = "General", verbose = "1")]
               *  @private
              override public function set alpha(value:Number):void
                  if (super.alpha == value)
                      return;
                  if (_blendMode == "auto")
                      // If alpha changes from an opaque/transparent (1/0) and translucent
                      // (0 < value < 1), then trigger a blendMode change
                      if ((value > 0 && value < 1 && (super.alpha == 0 || super.alpha == 1)) || ((value == 0 || value == 1) && (super.alpha > 0 && super.alpha < 1)))
                          blendModeChanged = true;
                          invalidateProperties();
                  super.alpha = value;
              //  baselinePositionElement
              private var _baselinePositionElement:IVisualElement;
               *  The element used to calculate the GroupBase's baselinePosition
               *  @langversion 3.0
              public function get baselinePositionElement():IVisualElement
                  return _baselinePositionElement;
               *  @private
              public function set baselinePositionElement(value:IVisualElement):void
                  if (value === _baselinePositionElement)
                      return;
                  _baselinePositionElement = value;
                  invalidateParentSizeAndDisplayList();
              //  blendMode
               *  @private
               *  Storage for the blendMode property.
              private var _blendMode:String = "auto";
              private var blendModeChanged:Boolean;
              private var blendShaderChanged:Boolean;
              [Inspectable(category = "General", enumeration = "auto,add,alpha,darken,difference,erase,hardlight,invert,layer,lighten,multiply,normal,subtract,screen,overlay,colordodge,colorburn,exclusion,softlight,hue,saturation,color,luminosity", defaultValue = "auto")]
               *  A value from the BlendMode class that specifies which blend mode to use.
               *  A bitmap can be drawn internally in two ways.
               *  If you have a blend mode enabled or an external clipping mask, the bitmap is drawn
               *  by adding a bitmap-filled square shape to the vector render.
               *  If you attempt to set this property to an invalid value,
               *  Flash Player or Adobe AIR sets the value to <code>BlendMode.NORMAL</code>.
               *  <p>A value of "auto" (the default) is specific to Group's use of
               *  blendMode and indicates that the underlying blendMode should be
               *  <code>BlendMode.NORMAL</code> except when <code>alpha</code> is not
               *  equal to either 0 or 1, when it is set to <code>BlendMode.LAYER</code>.
               *  This behavior ensures that groups have correct
               *  compositing of their graphic objects when the group is translucent.</p>
               *  @default "auto"
               *  @see flash.display.DisplayObject#blendMode
               *  @see flash.display.BlendMode
               *  @langversion 3.0
              override public function get blendMode():String
                  return _blendMode;
               *  @private
              override public function set blendMode(value:String):void
                  if (value == _blendMode)
                      return;
                  //The default blendMode in FXG is 'auto'. There are only
                  //certain cases where this results in a rendering difference,
                  //one being when the alpha of the Group is > 0 and < 1. In that
                  //case we set the blendMode to layer to avoid the performance
                  //overhead that comes with a non-normal blendMode.
                  if (value == "auto")
                      _blendMode = value;
                      // SDK-29631: Use super.$blendMode instead of super.blendMode
                      // since Group completely overrides blendMode and we
                      // want to bypass the extra logic in UIComponent which
                      // has its own override.
                      // TODO (egeorgie): figure out whether we can share some
                      // of that logic in the future.
                      if (((alpha > 0 && alpha < 1) && super.$blendMode != BlendMode.LAYER) || ((alpha == 1 || alpha == 0) && super.$blendMode != BlendMode.NORMAL))
                  else
                      var oldValue:String = _blendMode;
                      _blendMode = value;
                      // If one of the non-native Flash blendModes is set,
                      // record the new value and set the appropriate
                      // blendShader on the display object.
                      if (isAIMBlendMode(value))
                          blendShaderChanged = true;
                      // Only need to re-do display object assignment if blendmode was normal
                      // and is changing to something else, or the blend mode was something else
                      // and is going back to normal.  This is because display object sharing
                      // only happens when blendMode is normal.
                      if ((oldValue == BlendMode.NORMAL || value == BlendMode.NORMAL) && !(oldValue == BlendMode.NORMAL && value == BlendMode.NORMAL))
              //  mxmlContent
              private var mxmlContentChanged:Boolean = false;
              private var _mxmlContent:Array;
              [ArrayElementType("mx.core.IVisualElement")]
               *  The visual content children for this Group.
               *  This method is used internally by Flex and is not intended for direct
               *  use by developers.
               *  <p>The content items should only be IVisualElement objects.
               *  An <code>mxmlContent</code> Array should not be shared between multiple
               *  Group containers because visual elements can only live in one container
               *  at a time.</p>
               *  <p>If the content is an Array, do not modify the Array
               *  directly. Use the methods defined by the Group class instead.</p>
               *  @default null
               *  @langversion 3.0
              public function set mxmlContent(value:Array):void
                  if (createChildrenCalled)
                      setMXMLContent(value);
                  else
                      mxmlContentChanged = true;
                      _mxmlContent = value;
                          // we will validate this in createChildren();
               *  @private
              mx_internal function getMXMLContent():Array
                  if (_mxmlContent)
                      return _mxmlContent.concat();
                  else
                      return null;
               *  @private
               *  Adds the elements in <code>mxmlContent</code> to the Group.
               *  Flex calls this method automatically; you do not call it directly.
               *  @langversion 3.0
              private function setMXMLContent(value:Array):void
                  var i:int;
                  // if there's old content and it's different than what
                  // we're trying to set it to, then let's remove all the old
                  // elements first.
                  if (_mxmlContent != null && _mxmlContent != value)
                      for (i = _mxmlContent.length - 1; i >= 0; i--)
                          elementRemoved(_mxmlContent[i], i);
                  _mxmlContent = (value) ? value.concat() : null; // defensive copy
                  if (_mxmlContent != null)
                      var n:int = _mxmlContent.length;
                      for (i = 0; i < n; i++)
                          var elt:IVisualElement = _mxmlContent[i];
                          // A common mistake is to bind the viewport property of a Scroller
                          // to a group that was defined in the MXML file with a different parent
                          if (elt.parent && (elt.parent != this))
                              throw new Error(resourceManager.getString("components", "mxmlElementNoMultipleParents",
        [ elt ]));
                          elementAdded(elt, i);
              //  Properties: ScaleGrid
              private var scaleGridChanged:Boolean = false;
              // store the scaleGrid into a rectangle to save space (top, left, bottom, right);
              private var scaleGridStorageVariable:Rectangle;
              //  scale9Grid
               *  @private
              override public function set scale9Grid(value:Rectangle):void
                  if (value != null)
                      scaleGridTop = value.top;
                      scaleGridBottom = value.bottom;
                      scaleGridLeft = value.left;
                      scaleGridRight = value.right;
                  else
                      scaleGridTop = NaN;
                      scaleGridBottom = NaN;
                      scaleGridLeft = NaN;
                      scaleGridRight = NaN;
              //  scaleGridBottom
              [Inspectable(category = "General")]
               *  Specifies the bottom coordinate of the scale grid.
               *  @langversion 3.0
              public function get scaleGridBottom():Number
                  if (scaleGridStorageVariable)
                      return scaleGridStorageVariable.height;
                  return NaN;
              public function set scaleGridBottom(value:Number):void
                  if (!scaleGridStorageVariable)
                      scaleGridStorageVariable = new Rectangle(NaN, NaN, NaN, NaN);
                  if (value != scaleGridStorageVariable.height)
                      scaleGridStorageVariable.height = value;
                      scaleGridChanged = true;
              //  scaleGridLeft
               * Specifies the left coordinate of the scale grid.
               *  @langversion 3.0
              public function get scaleGridLeft():Number
                      return scaleGridStorageVariable.x;
                  return NaN;
              public function set scaleGridLeft(value:Number):void
                  if (value != scaleGridStorageVariable.x)
                      scaleGridStorageVariable.x = value;
              //  scaleGridRight
               * Specifies the right coordinate of the scale grid.
               *  @langversion 3.0
              public function get scaleGridRight():Number
                      return scaleGridStorageVariable.width;
                  return NaN;
              public function set scaleGridRight(value:Number):void
                  if (value != scaleGridStorageVariable.width)
                      scaleGridStorageVariable.width = value;
              //  scaleGridTop
               * Specifies the top coordinate of the scale grid.
               *  @langversion 3.0
              public function get scaleGridTop():Number
                      return scaleGridStorageVariable.y;
                  return NaN;
              public function set scaleGridTop(value:Number):void
                  if (value != scaleGridStorageVariable.y)
                      scaleGridStorageVariable.y = value;
              private function isValidScaleGrid():Boolean
                  return !isNaN(scaleGridLeft) && !isNaN(scaleGridTop) && !isNaN(scaleGridRight) && !isNaN(scaleGridBottom);
              //  Overridden methods: UIComponent
               *  @private
               *  Whether createChildren() has been called or not.
               *  We use this in the setter for mxmlContent to know
               *  whether to validate the value immediately, or just
               *  wait to let createChildren() do it.
              private var createChildrenCalled:Boolean = false;
               *  @private
              override protected function createChildren():void
                  super.createChildren();
                  createChildrenCalled = true;
                  if (mxmlContentChanged)
                      mxmlContentChanged = false;
                      setMXMLContent(_mxmlContent);
               *  @private
              override public function validateProperties():void
                  super.validateProperties();
                  // Property validation happens top-down, so now let's
                  // validate graphic element properties after
                  // calling super.validateProperties()
                  if (numGraphicElements > 0)
                      var length:int = numElements;
                      for (var i:int = 0; i < length; i++)
                          var element:IGraphicElement = getElementAt(i) as IGraphicElement;
                          if (element)
                              element.validateProperties();
               *  @private
              override protected function commitProperties():void
                  super.commitProperties();
                  invalidatePropertiesFlag = false;
                  if (blendModeChanged)
                      blendModeChanged = false;
                      // Figure out the correct blendMode value
                      // to set.
                          if (alpha == 0 || alpha == 1)
                              super.$blendMode = BlendMode.NORMAL;
                          else
                              super.$blendMode = BlendMode.LAYER;
                      else if (!isAIMBlendMode(_blendMode))
                          super.$blendMode = _blendMode;
                      if (blendShaderChanged)
                          // The graphic element's blendMode was set to a non-Flash
                          // blendMode. We mimic the look by instantiating the
                          // appropriate shader class and setting the blendShader
                          // property on the displayObject.
                          blendShaderChanged = false;
                          switch (_blendMode)
                              case "color":
                                  super.blendShader = new ColorShader();
                                  break;
                              case "colordodge":
                                  super.blendShader = new ColorDodgeShader();
                                  break;
                              case "colorburn":
                                  super.blendShader = new ColorBurnShader();
                                  break;
                              case "exclusion":
                                  super.blendShader = new ExclusionShader();
                                  break;
                              case "hue":
                                  super.blendShader = new HueShader();
                                  break;
                              case "luminosity":
                                  super.blendShader = new LuminosityShader();
                                  break;
                              case "saturation":
                                  super.blendShader = new SaturationShader();
                                  break;
                              case "softlight":
                                  super.blendShader = new SoftLightShader();
                                  break;
                  // Due to dependent properties alpha and blendMode there may be a need
                  // for a second pass at committing properties (to ensure our new
                  // blendMode or blendShader is assigned to our underlying display
                  // object).
                  if (invalidatePropertiesFlag)
                  if (needsDisplayObjectAssignment)
                      needsDisplayObjectAssignment = false;
                      assignDisplayObjects();
                  if (scaleGridChanged)
                      // Don't reset scaleGridChanged since we also check it in updateDisplayList
                          resizeMode = ResizeMode.SCALE; // Force the resizeMode to scale
               *  @private
              override public function validateSize(recursive:Boolean = false):void
                  // Since IGraphicElement is not ILayoutManagerClient, we need to make sure we
                  // validate sizes of the elements, even in cases where recursive==false.
                  // Size validation happens bottom-up, so now let's
                  // validate graphic element size before
                  // calling super.validateSize()
                          if (element)
                              element.validateSize();
                  super.validateSize(recursive);
               *  @private
              override public function setActualSize(w:Number, h:Number):void
                  if (_width != w || _height != h)
                  super.setActualSize(w, h);
               *  @private
              override public function validateDisplayList():void
                  // call super.validateDisplayList() and let updateDisplayList() run
                  super.validateDisplayList();
                  // If the DisplayObject assignment is still not completed, then postpone validation
                  // of the GraphicElements. invalidateDisplayList() will be called during the next
                  // commitProperties() call since needsDisplayObjectAssignment=true,
                  // so we will be re-running validateDisplayList() anyways
                  if (needsDisplayObjectAssignment && invalidatePropertiesFlag)
                      return;
                  // DisplayList validation happens top-down, so we should
                  // validate graphic element DisplayList after
                  // calling super.validateDisplayList().  This is
                  // gets tricky because of graphic-element sharing.  We clear
                  // Group's graphic's object in updateDisplayList() and handle the
                  // rest of the DisplayList validation in here.
                  // Iterate through the graphic elements. If an element has a displayObject that has been
                  // invalidated, then validate all graphic elements that draw to this displayObject.
                  // The algorithm assumes that all of the elements that share a displayObject are in between
                  // the element with the shared displayObject and the next element that has a displayObject.
                  var sharedDisplayObject:ISharedDisplayObject = this;
                          if (!element)
                              continue;
                          // Do a special check for layer, we may stumble upon an element with layer != 0
                          // before we're done with the current shared sequence and we don't want to mark
                          // the sequence as valid, until we reach the next sequence.
                          if (element.depth == 0)
                              // Is this the start of a new shared sequence?
                              if (element.displayObjectSharingMode != DisplayObjectSharingMode.USES_SHARED_OBJECT)
                                  // We have finished redrawing the previous sequence
                                  if (sharedDisplayObject)
                                      sharedDisplayObject.redrawRequested = false;
                                  // Start the new sequence
                                  sharedDisplayObject = element.displayObject as ISharedDisplayObject;
                              if (!sharedDisplayObject || sharedDisplayObject.redrawRequested)
                                  element.validateDisplayList();
                          else
                              // If we have layering, we don't share the display objects.
                              // Don't update the current sharedDisplayObject
                              var elementDisplayObject:ISharedDisplayObject = element.displayObject as ISharedDisplayObject;
                              if (!elementDisplayObject || elementDisplayObject.redrawRequested)
                                  if (elementDisplayObject)
                                      elementDisplayObject.redrawRequested = false;
                  // Mark the last shared displayObject valid
               *  @private
              override protected function updateDisplayList(unscaledWidth:Number, unscaledHeight:Number):void
                  // let user's code (layout) run first before dealing with graphic element
                  // sharing because that's when redraws can be requested
                  super.updateDisplayList(unscaledWidth, unscaledHeight);
                  // Clear the group's graphic because graphic elements might be drawing to it
                  // This isn't needed for DataGroup because there's no DisplayObject sharing
                  // This code exists in updateDisplayList() as opposed to validateDisplayList()
                  // because of compatibility issues since most of this code was
                  // refactored from updateDisplayList() and in to validateDisplayList().  User's code
                  // already assumed that they could call super.updateDisplayList() and then be able to draw
                  // into the Group's graphics object.  Because of that, the graphics.clear() call is left
                  // in updateDisplayList() instead of in validateDisplayList() with the rest of the graphic
                  // element sharing code.
                  if (sharedDisplayObject.redrawRequested)
                      // clear the graphics here.  The pattern is usually to call graphics.clear()
                      // before calling super.updateDisplayList() so what happens in super.updateDisplayList()
                      // isn't erased.  However, in this case, what happens in super.updateDisplayList() isn't
                      // much, and we want to make sure super.updateDisplayList() runs first since the layout
                      // is what actually triggers the the shareDisplayObject to request to be redrawn.
                      graphics.clear();
                      drawBackground();
                      // If a scaleGrid is set, make sure the extent of the groups bounds are filled so
                      // the player will scale our contents as expected.
                      if (isValidScaleGrid() && resizeMode == ResizeMode.SCALE)
                          graphics.lineStyle();
                          graphics.beginFill(0, 0);
                          graphics.drawRect(0, 0, 1, 1);
                          graphics.drawRect(measuredWidth - 1, measuredHeight - 1, 1, 1);
                          graphics.endFill();
                      scaleGridChanged = false;
                          // Check for DisplayObjects other than overlays
                          var overlayCount:int = _overlay ? _overlay.numDisplayObjects : 0;
                          if (numChildren - overlayCount > 0)
                              throw new Error(resourceManager.getString("components", "scaleGridGroupError"));
                          super.scale9Grid = new Rectangle(scaleGridLeft,
                                                           scaleGridTop,
                                                           scaleGridRight - scaleGridLeft,
                                                           scaleGridBottom - scaleGridTop);
                      else
                          super.scale9Grid = null;
               *  @private
               *  TODO (rfrishbe): Most of this code is a duplicate of UIComponent::notifyStyleChangeInChildren,
               *  refactor as appropriate to avoid code duplication once we have a common
               *  child iterator between UIComponent and Group.
              override public function notifyStyleChangeInChildren(
                  styleProp:String, recursive:Boolean):void
                  if (mxmlContentChanged || !recursive)
                      return;
                  var n:int = numElements;
                  for (var i:int = 0; i < n; i++)
                      var child:ISimpleStyleClient = getElementAt(i) as ISimpleStyleClient;
                      if (child)
                          child.styleChanged(styleProp);
                          if (child is IStyleClient)
                              IStyleClient(child).notifyStyleChangeInChildren(styleProp,
        recursive);
                  if (advanceStyleClientChildren != null)
                      for (var styleClient:Object in advanceStyleClientChildren)
                          var iAdvanceStyleClientChild:IAdvancedStyleClient = styleClient as IAdvancedStyleClient;
                          if (iAdvanceStyleClientChild)
                              iAdvanceStyleClientChild.styleChanged(styleProp);
               *  @private
               *  TODO (rfrishbe): Most of this code is a duplicate of UIComponent::regenerateStyleCache,
              override public function regenerateStyleCache(recursive:Boolean):void
                  // Regenerate the proto chain for this object
                  initProtoChain();
                  // Recursively call this method on each child.
                      var child:IVisualElement = getElementAt(i);
                          // Does this object already have a proto chain?
                          // If not, there's no need to regenerate a new one.
                          if (IStyleClient(child).inheritingStyles != StyleProtoChain.STYLE_UNINITIALIZED)
                              IStyleClient(child).regenerateStyleCache(recursive);
                      else if (child is IUITextField)
                          if (IUITextField(child).inheritingStyles)
                              StyleProtoChain.initTextField(IUITextField(child));
                  // Call this method on each non-visual StyleClient
                          if (iAdvanceStyleClientChild && iAdvanceStyleClientChild.inheritingStyles != StyleProtoChain.STYLE_UNINITIALIZED)
                              iAdvanceStyleClientChild.regenerateStyleCache(recursive);
              //  Content management
               *  @private
              override public function get numElements():int
                  if (_mxmlContent == null)
                      return 0;
                  return _mxmlContent.length;
               *  @private
              override public function getElementAt(index:int):IVisualElement
                  // check for RangeError:
                  checkForRangeError(index);
                  return _mxmlContent[index];
               *  @private
               *  Checks the range of index to make sure it's valid
              private function checkForRangeError(index:int, addingElement:Boolean = false):void
                  // figure out the maximum allowable index
                  var maxIndex:int = (_mxmlContent == null ? -1 : _mxmlContent.length - 1);
                  // if adding an element, we allow an extra index at the end
                  if (addingElement)
                      maxIndex++;
                  if (index < 0 || index > maxIndex)
                      throw new RangeError(resourceManager.getString("components", "indexOutOfRange",
        [ index ]));
               * @private
              private function isAIMBlendMode(value:String):Boolean
                  if (value == "colordodge" || value == "colorburn" || value == "exclusion" || value == "softlight" || value == "hue" || value == "saturation" || value == "color" || value == "luminosity")
                      return true;
                  else
                      return false;
               *  @inheritDoc
               *  @langversion 3.0
              public function addElement(element:IVisualElement):IVisualElement
                  var index:int = numElements;
                  // This handles the case where we call addElement on something
                  // that already is in the list.  Let's just handle it silently
                  // and not throw up any errors.
                  if (element.parent == this)
                      index = numElements - 1;
                  return addElementAt(element, index);
               *  @inheritDoc
               *  @langversion 3.0
              public function addElementAt(element:IVisualElement, index:int):IVisualElement
                  if (element == this)
                      throw new ArgumentError(resourceManager.getString("components", "cannotAddYourselfAsYourChild"));
                  checkForRangeError(index, true);
                  var host:DisplayObject = element.parent;
                  if (host == this)
                      setElementIndex(element, index);
                      return element;
                  else if (host is IVisualElementContainer)
                      // Remove the item from the group if that group isn't this group
                      IVisualElementContainer(host).removeElement(element);
                  // If we don't have any content yet, initialize it to an empty array
                      _mxmlContent = [];
                  _mxmlContent.splice(index, 0, element);
                  if (!mxmlContentChanged)
                      elementAdded(element, index);
                  return element;
               *  @inheritDoc
               *  @langversion 3.0
              public function removeElement(element:IVisualElement):IVisualElement
                  return removeElementAt(getElementIndex(element));
               *  @inheritDoc
               *  @langversion 3.0
              public function removeElementAt(index:int):IVisualElement
                  // check RangeError
                  var element:IVisualElement = _mxmlContent[index];
                  // Need to call elementRemoved before removing the item so anyone listening
                  // for the event can access the item.
                      elementRemoved(element, index);
                  _mxmlContent.splice(index, 1);
                  return element;
               *  @inheritDoc
               *  @langversion 3.0
               *  @playerversion AIR 2.5
               *  @productversion Flex 4.5
              public function removeAllElements():void
                  for (var i:int = numElements - 1; i >= 0; i--)
                      removeElementAt(i);
               *  @private
              override public function getElementIndex(element:IVisualElement):int
                  var index:int = _mxmlContent ? _mxmlContent.indexOf(element) : -1;
                  if (index == -1)
                      throw ArgumentError(resourceManager.getString("components", "elementNotFoundInGroup",
        [ element ]));
                  else
                      return index;
               *  @inheritDoc
               *  @langversion 3.0
              public function setElementIndex(element:IVisualElement, index:int):void
                  // check for RangeError...this is done in addItemAt
                  // but we want to do it before removing the element
                  if (getElementIndex(element) == index)
                      return;
               *  @inheritDoc
               *  @langversion 3.0
              public function swapElements(element1:IVisualElement, element2:IVisualElement):void
                  swapElementsAt(getElementIndex(element1), getElementIndex(element2));
               *  @inheritDoc
               *  @langversion 3.0
              public function swapElementsAt(index1:int, index2:int):void
                  checkForRangeError(index1);
                  checkForRangeError(index2);
                  // Make sure that index1 is the smaller index so that addElementAt
                  // doesn't RTE
                  if (index1 > index2)
                      var temp:int = index2;
                      index2 = index1;
                      index1 = temp;
                  else if (index1 == index2)
                      return;
                  var element1:IVisualElement = _mxmlContent[index1];
                  var element2:IVisualElement = _mxmlContent[index2];
                  // Make sure we do the proper invalidations, but don't dispatch events
                      elementRemoved(element1, index1, false /*notifyListeners*/);
                      elementRemoved(element2, index2, false /*notifyListeners*/);
                  // Step 1: remove
                  // Make sure we remove the bigger index first
                  _mxmlContent.splice(index2, 1);
                  _mxmlContent.splice(index1, 1);
                  // Step 2: swap
                  // Add them in reverse order
                  _mxmlContent.splice(index1, 0, element2);
                  _mxmlContent.splice(index2, 0, element1);
                      elementAdded(element2, index1, false /*notifyListeners*/);
                      elementAdded(element1, index2, false /*notifyListeners*/);
              //  Content management (internal)
               *  @private
              override public function invalidateLayering():void
                  if (layeringMode == ITEM_ORDERED_LAYERING)
                      layeringMode = SPARSE_LAYERING;
               *  Adds an item to this Group.
               *  @param item The item that was added.
               *  @param index The index where the item was added.
               *  @langversion 3.0
              mx_internal function elementAdded(element:IVisualElement, index:int, notifyListeners:Boolean = true):void
                  if (layout)
                      layout.elementAdded(index);
                  if (element.depth != 0)
                      invalidateLayering();
                  // Set the moduleFactory to the child, but don't overwrite an existing moduleFactory.
                  // Propagate moduleFactory to the child, but don't overwrite an existing moduleFactory.
                  if (element is IFlexModule && IFlexModule(element).moduleFactory == null)
                      if (moduleFactory != null)
                          IFlexModule(element).moduleFactory = moduleFactory;
                      else if (document is IFlexModule && document.moduleFactory != null)
                          IFlexModule(element).moduleFactory = document.moduleFactory;
                      else if (parent is IFlexModule && IFlexModule(element).moduleFactory != null)
                          IFlexModule(element).moduleFactory = IFlexModule(parent).moduleFactory;
                  // Set the font context in non-UIComponent children.
                  // UIComponent children use moduleFactory.
                  if (element is IFontContextComponent && !(element is UIComponent) && IFontContextComponent(element).fontContext == null)
                      IFontContextComponent(element).fontContext = moduleFactory;
                  if (element is IGraphicElement)
                      numGraphicElements++;
                      addingGraphicElementChild(element as IGraphicElement);
                  else
                      // item must be a DisplayObject
                      // if the display object ordering is invalidated (because we have graphic elements
                      // that aren't actually in the display list), then lets just add our item to the end.
                      // If the ordering isn't invalidated, then let's just try to add it to the proper index.
                      if (invalidateDisplayObjectOrdering())
                          // This always adds the child to the end of the display list. Any
                          // ordering discrepancies will be fixed up in assignDisplayObjects().
                          addDisplayObjectToDisplayList(DisplayObject(element));
                      else
                          addDisplayObjectToDisplayList(DisplayObject(element), index);
                  if (notifyListeners)
                      if (hasEventListener(ElementExistenceEvent.ELEMENT_ADD))
                          dispatchEvent(new ElementExistenceEvent(
                                        ElementExistenceEvent.ELEMENT_ADD, false, false,
                                        element, index));
                      if (element is IUIComponent && element.hasEventListener(FlexEvent.ADD))
                          element.dispatchEvent(new FlexEvent(FlexEvent.ADD));
                  invalidateSize();
               *  Removes an item from this Group.
               *  @param index The index of the item that is being removed.
               *  @langversion 3.0
              mx_internal function elementRemoved(element:IVisualElement, index:int, notifyListeners:Boolean = true):void
                  var childDO:DisplayObject = element as DisplayObject;
                      if (hasEventListener(ElementExistenceEvent.ELEMENT_REMOVE))
                                        ElementExistenceEvent.ELEMENT_REMOVE, false, false,
                                        element, index));
                      if (element is IUIComponent && element.hasEventListener(FlexEvent.REMOVE))
                          element.dispatchEvent(new FlexEvent(FlexEvent.REMOVE));
                  if (element && (element is IGraphicElement))
                      numGraphicElements--;
                      removingGraphicElementChild(element as IGraphicElement);
                  else if (childDO && childDO.parent == this)
                      super.removeChild(childDO);
                  invalidateSize();
                  if (layout)
                      layout.elementRemoved(index);
               *  @private
              mx_internal function addingGraphicElementChild(child:IGraphicElement):void
                  // Special case (defensive coding) - if the element was previously
                  // a child of this Group, and it didn't release its previously assigned
                  // DisplayObject when its parent changed, and there's the possibility that
                  // the Group may assign it the same DisplayObject and the same sharing mode,
                  // we still need to invalidate and redraw as the displayObject likely has
                  // been redrawn while the element was not a child of this Group.
                  if (child.displayObject && child.displayObjectSharingMode == DisplayObjectSharingMode.USES_SHARED_OBJECT)
                      invalidateGraphicElementDisplayList(child);
                  child.parentChanged(this);
                  // Sets up the inheritingStyles and nonInheritingStyles objects
                  // and their proto chains so that getStyle() works.
                  // If this object already has some children,
                  // then reinitialize the children's proto chains.
                      IStyleClient(child).regenerateStyleCache(true);
                  if (child is ISimpleStyleClient)
                      ISimpleStyleClient(child).styleChanged(null);
                      IStyleClient(child).notifyStyleChangeInChildren(null, true);
               *  @private
              mx_internal function removingGraphicElementChild(child:IGraphicElement):void
                  // First discard the displayObject, as child may decide to destroy it
                  // when parent changes.
                  discardDisplayObject(child);
                  child.parentChanged(null);
               *  Removes the element's <code>DisplayObject</code> from this <code>Group's</code>
               *  display list.
               *  The <code>Group</code> also ensures any elements that share the
               *  <code>DisplayObject</code> is redrawn.
               *  <p>This method doesn't necessarily trigger new <code>DisplayObject</code>
               *  reassignment for the passed in <code>element</code>.
               *  To request new display object reassignment, call the
               *  <code>invalidateGraphicElementSharing()</code> method.</p>
               *  @param element The graphic element whose display object is discarded.
               *  @see #invalidateGraphicElementSharing
               *  @langversion 3.0
              mx_internal function discardDisplayObject(element:IGraphicElement):void
                  var oldDisplayObject:DisplayObject = element.displayObject;
                  if (!oldDisplayObject)
                      return;
                  // If the element created the display object
                  if (element.displayObjectSharingMode != DisplayObjectSharingMode.USES_SHARED_OBJECT && oldDisplayObject.parent == this)
                      super.removeChild(oldDisplayObject);
                      // Redo the shared sequences.
                  else if (oldDisplayObject is ISharedDisplayObject)
                      // Redraw the shared sequence
                      ISharedDisplayObject(oldDisplayObject).redrawRequested = true;
                      // Make sure we do a pass through the graphic elements and redraw
                      // the invalid ones.  We should only redraw, no need to redo the layout.
               *  @private
               *  Returns true if the Group's display object can be shared with graphic elements
               *  inside the group
              private function get canShareDisplayObject():Boolean
                  // We can't even check the cacheAsBitmap property since that will
                  // cause a back buffer allocation, which is another FP bug.
                  if (scrollRect)
                      return false;
                  // We can't share ourselves if we're in blendMode != normal, or we have
                  // to deal with any layering. The reason is because we handle layer = 0 first
                  // in our implementation, and we don't want those to use our display object to
                  // draw into because there could be something further down the line that has
                  // layer < 0. The cases where we are in blendMode != normal is when blendMode
                  // has been explicitly set or blendMode is auto and there is a fractional alpha.
                  return (_blendMode == "normal" || _blendMode == "auto" && (alpha == 0 || alpha == 1)) && (layeringMode == ITEM_ORDERED_LAYERING);
               *  @private
               *  Invalidates the display object ordering and will run assignDisplayObjects()
               *  if necessary.
               *  @return true if the display object ordering needed to be invalidated;
               *          false otherwise.
              private function invalidateDisplayObjectOrdering():Boolean
                  if (layeringMode == SPARSE_LAYERING || numGraphicElements > 0)
                      needsDisplayObjectAssignment = true;
                      return true;
                  return false;
               *  @private
               *  Called to assign display objects to graphic elements
              private function assignDisplayObjects():void
                  var topLayerItems:Vector.<IVisualElement>;
                  var bottomLayerItems:Vector.<IVisualElement>;
                  var keepLayeringEnabled:Boolean = false;
                  var insertIndex:int = 0;
                  // Keep track of the previous IVisualElement.  This is used when
                  // assigning DisplayObjects to the IGraphicElements.
                  // If the Group can share its DisplayObject with the IGraphicElements
                  // then initialize the prevItem with this Group object.
                  var prevItem:IVisualElement;
                  if (canShareDisplayObject)
                      prevItem = this;
                  // Iterate through all of the items
                  var len:int = numElements;
                  for (var i:int = 0; i < len; i++)
                      var item:IVisualElement = getElementAt(i);
                      if (layeringMode != ITEM_ORDERED_LAYERING)
                          var layer:Number = item.depth;
                          if (layer != 0)
                              if (layer > 0)
                                  if (topLayerItems == null)
                                      topLayerItems = new Vector.<IVisualElement>();
                                  topLayerItems.push(item);
                                  continue;
                              else
                                  if (bottomLayerItems == null)
                                      bottomLayerItems = new Vector.<IVisualElement>();
                                  bottomLayerItems.push(item);
                                  continue;
                      // this should only get called if layer == 0, or we don't care
                      // about layering (layeringMode == ITEM_ORDERED_LAYERING)
                      insertIndex = assignDisplayObjectTo(item, prevItem, insertIndex);
                      prevItem = item;
                  // we've done all layer == 0 items.
                  // now let's put the higher z-index ones on next
                  // then we'll handle the ones on bottom, but we'll
                  // insert them in the very beginning (index = 0)
                  if (topLayerItems != null)
                      keepLayeringEnabled = true;
                      //topLayerItems.sortOn("layer",Array.NUMERIC);
                      GroupBase.sortOnLayer(topLayerItems);
                      len = topLayerItems.length;
                      for (i = 0; i < len; i++)
                          // For layer != 0, we never share display objects
                          insertIndex = assignDisplayObjectTo(topLayerItems[i], null /*prevElement*/,
                                                              insertIndex);
                  if (bottomLayerItems != null)
                      insertIndex = 0;
                      //bottomLayerItems.sortOn("layer",Array.NUMERIC);
                      GroupBase.sortOnLayer(bottomLayerItems);
                      len = bottomLayerItems.length;
                          // For layer != 0, we never share dsiplay objects
                          insertIndex = assignDisplayObjectTo(bottomLayerItems[i], null /*prevElement*/,
                                                              insertIndex);
                  // If we tried to layer these visual elements and found that we
                  // don't actually need to because layer=0 for all of them,
                  // then lets optimize this next time and just skip the layering step.
                  // If an element gets added that has layer set to something non-zero, then
                  // layeringMode will get set to SPARSE_LAYERING.
                  // If the layer property changes on a current element, invalidateLayering()
                  // will be called and layeringMode will get set to SPARSE_LAYERING.
                  if (keepLayeringEnabled == false)
                      layeringMode = ITEM_ORDERED_LAYERING;
               *  @private
               *  Assigns a DisplayObject to the curElement and ensures the DisplayObject
               *  is at insertIndex in the display object list.
               *  If <code>curElement</code> implements IGraphicElement, then both its
               *  DisplayObject and displayObjectSharingMode will be updated.
               *  @curElement The current element to assign DisplayObject to
               *  @prevEelement The previous element in the list of elements or null.
               *  @return Returns the display list index after the current element's
               *  DisplayObject.
              private function assignDisplayObjectTo(curElement:IVisualElement,
                                                     prevElement:IVisualElement,
                                                     insertIndex:int):int
                  if (curElement is DisplayObject)
                      super.setChildIndex(curElement as DisplayObject, insertIndex++);
                  else if (curElement is IGraphicElement)
                      var current:IGraphicElement = IGraphicElement(curElement);
                      var previous:IGraphicElement = prevElement as IGraphicElement;
                      var oldDisplayObject:DisplayObject = current.displayObject;
                      var oldSharingMode:String = current.displayObjectSharingMode;
                      if (previous && previous.canShareWithNext(current) && current.canShareWithPrevious(previous) && current.setSharedDisplayObject(previous.displayObject))
                          // If we are the second element in the shared sequence,
                          // make sure that the first element has the correct displayObjectSharingMode
                          if (previous.displayObjectSharingMode == DisplayObjectSharingMode.OWNS_UNSHARED_OBJECT)
                              previous.displayObjectSharingMode = DisplayObjectSharingMode.OWNS_SHARED_OBJECT;
                          current.displayObjectSharingMode = DisplayObjectSharingMode.USES_SHARED_OBJECT;
                      else if (prevElement == this && current.setSharedDisplayObject(this))
                      else
                          // We don't want to create new DisplayObjects for elements that
                          // already have created their own their display objects.
                          var ownsDisplayObject:Boolean = oldSharingMode != DisplayObjectSharingMode.USES_SHARED_OBJECT;
                          // If the element doesn't have a DisplayObject or it doesn't own
                          // the DisplayObject it currently has, then create a new one
                          var displayObject:DisplayObject = oldDisplayObject;
                          if (!ownsDisplayObject || !displayObject)
                              displayObject = current.createDisplayObject();
                          // Make sure the DisplayObject is at the correct position.
                          // Check displayObject for null, some graphic elements
                          // may choose not to create a DisplayObject during this pass.
                          if (displayObject)
                              addDisplayObjectToDisplayList(displayObject, insertIndex++);
                          current.displayObjectSharingMode = DisplayObjectSharingMode.OWNS_UNSHARED_OBJECT;
                      invalidateAfterAssignment(current, oldSharingMode, oldDisplayObject);
                  return insertIndex;
               *  @private
               *  Performs invalidation of the old and new shared sequenences.
               *  If necesary, removes the old display object from the list.
              private function invalidateAfterAssignment(element:IGraphicElement,
                                                         oldSharingMode:String,
                                                         oldDisplayObject:DisplayObject):void
                  // Make sure we remove or mark for redraw the old displayObject
                  var displayObject:DisplayObject = element.displayObject;
                  var sharingMode:String = element.displayObjectSharingMode;
                  if (oldDisplayObject == displayObject && sharingMode == oldSharingMode)
                      return;
                  // Make sure we redraw the display object
                  if (displayObject is ISharedDisplayObject)
                      ISharedDisplayObject(displayObject).redrawRequested = true;
                  // Old display object also needs to be redrawn, in case any other GE still uses it.
                  // Make sure we remove the old display object, if needed
                  if (oldDisplayObject && oldDisplayObject.parent == this && oldDisplayObject != displayObject && oldSharingMode != DisplayObjectSharingMode.USES_SHARED_OBJECT)
               *  @private
               *  If the displayObject is not a child of this Group, then insert it at the
               *  specified index (or at the end of the list, when index is -1).
               *  Else, if the displayObject is already a child of the Group, then simply
               *  adjust its child index.
              private function addDisplayObjectToDisplayList(child:DisplayObject, index:int = -1):void
                  if (child.parent == this)
                      super.setChildIndex(child, index != -1 ? index : super.numChildren - 1 - overlayCount);
                  else
                      super.addChildAt(child, index != -1 ? index : super.numChildren - overlayCount);
               *  Notify the host component that an element has changed and needs to be redrawn.
               *  Group calls the <code>validateDisplayList()</code> method on the IGraphicElement
               *  to give it a chance to redraw.
               *  @param element The element that has changed.
               *  @langversion 3.0
              public function invalidateGraphicElementDisplayList(element:IGraphicElement):void
                  if (element.displayObject is ISharedDisplayObject)
                      ISharedDisplayObject(element.displayObject).redrawRequested = true;
                  // Invalidate display list only, no need to run the layout.
               *  Notify the host component that an element changed and needs to validate properties.
               *  Group calls the <code>validateProperties()</code> method on the IGraphicElement
               *  to give it a chance to commit its properties.
               *  @langversion 3.0
              public function invalidateGraphicElementProperties(element:IGraphicElement):void
               *  Notify the host component that an element size has changed.
               *  Group calls the <code>validateSize()</code> method on the IGraphicElement
               *  to give it a chance to validate its size.
               *  @param element The element that has changed size.
               *  @langversion 3.0
              public function invalidateGraphicElementSize(element:IGraphicElement):void
                  // Invalidate the size only, no need to run the layout.
                  // Later on, if the size changes, then a layout pass will be triggered.
                  super.$invalidateSize();
               *  Notify the host that an element layer has changed.
               *  Group re-evaluates the sequences of elements with shared DisplayObjects
               *  and may re-assign the DisplayObjects and redraw the sequences as a result.
               *  @langversion 3.0
              public function invalidateGraphicElementSharing(element:IGraphicElement):void
                  // One of our children have told us they might need a displayObject
               *  @private
              override public function addChild(child:DisplayObject):DisplayObject
                  throw(new Error(resourceManager.getString("components", "addChildError")));
               *  @private
              override public function addChildAt(child:DisplayObject, index:int):DisplayObject
                  throw(new Error(resourceManager.getString("components", "addChildAtError")));
               *  @private
              override public function removeChild(child:DisplayObject):DisplayObject
                  throw(new Error(resourceManager.getString("components", "removeChildError")));
               *  @private
              override public function removeChildAt(index:int):DisplayObject
                  throw(new Error(resourceManager.getString("components", "removeChildAtError")));
               *  @private
              override public function setChildIndex(child:DisplayObject, index:int):void
                  throw(new Error(resourceManager.getString("components", "setChildIndexError")));
               *  @private
              override public function swapChildren(child1:DisplayObject, child2:DisplayObject):void
                  throw(new Error(resourceManager.getString("components", "swapChildrenError")));
               *  @private
              override public function swapChildrenAt(index1:int, index2:int):void
                  throw(new Error(resourceManager.getString("components", "swapChildrenAtError")));
               *  @private
               *  Override to ensure we set redrawRequested when appropriate.
              override public function set mouseEnabledWhereTransparent(value:Boolean):void
                  if (value == mouseEnabledWhereTransparent)
                      return;
                  super.mouseEnabledWhereTransparent = value;
              //  ISharedDisplayObject
               *  @private
              private var _redrawRequested:Boolean = false;
               *  @private
               *  Contains <code>true</code> when any of the <code>IGraphicElement</code> objects that share
               *  this <code>DisplayObject</code> object needs to redraw or the background for the container
               *  needs to be redrawn.
               *  This is used internally
               *  by the <code>Group</code> class and developers don't typically use this.
               *  @langversion 3.0
              public function get redrawRequested():Boolean
                  return _redrawRequested;
               *  @private
              public function set redrawRequested(value:Boolean):void
                  _redrawRequested = value;
