• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
CFPOP and the FROM variable
Contributor ,
Oct 27, 2011 Oct 27, 2011
I use CFPOP too read mails,
And I want to do different processing following the email adress found in the
FROM variable.
But, depending of the Mail agent sending mails,
The FROM variable contains different types of values :
1 - can be the Email (alone)
2 - can be the name of the person, without any email
3 - can be the name of the person followed by the email
4 - can be the name of the person followed by an email of the mail server.
As I need to find the Email of the sender, only in cases 1 and 3 can give me the right email.
Can someone explain this ?
I do not see anything in CF to solve this, even in programming or in the CF administrator.
I have the impression that , what is retruned in the "FROM" depends of the mail server ?
Thanks for any help, explanation on that subject,
Pierre.
TOPICS
Advanced techniques
Views
1.1K
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
What happens if you use the header variable instead of the from?
Votes
Translate
Translate
Report
Report
Contributor ,
Thanks for your suggestion,
the header variable does not give the Email adress of the sender,
it gives the same : the person name.
here is the result of that variable :
Received: from [192.168.13.131] by email.images-creations.fr [192.168.13.209] with SmartMax MailMax for track@stw.fr; Tue, 18 Oct 2011 16:56:29 +0200 Return-Path: X-SmartMax-AuthUser: Received: from mx1-1.images-creations.fr (localhost [127.0.0.1]) by mx1-1-relay.images-creations.fr (Postfix) with ESMTP id 76EC432E0D9 for ; Tue, 18 Oct 2011 16:56:26 +0200 (CEST) X-Spam-Checker-Version: SpamAssassin 3.2.5 (2008-06-10) on mx1-1.images-creations.fr X-Spam-Level: ***** X-Spam-Status: No, score=6.0 required=8.0 tests=BAYES_50,HTML_MESSAGE, LIMSI_S36,RCVD_IN_NJABL_PROXY,TVD_SPACE_RATIO autolearn=no version=3.2.5 Received: from smtp.smtpout.orange.fr (smtp12.smtpout.orange.fr [80.12.242.134]) by mx1-1.images-creations.fr (Postfix) with ESMTP id 63CFE32E0D5 for ; Tue, 18 Oct 2011 16:56:26 +0200 (CEST) Received: from StationDev ([80.14.60.39]) by mwinf5d47 with ME id mEwR1h00J0qnSTU03EwRkh; Tue, 18 Oct 2011 16:56:26 +0200 X-ME-engine: default From: "Pierre LARDE" To: Subject: 13744 Date: Tue, 18 Oct 2011 16:56:24 +0200 Message-ID: <000501cc8da6$1b58e540$520aafc0$@fr> MIME-Version: 1.0 Content-Type: multipart/alternative; boundary="----=_NextPart_000_0006_01CC8DB6.DEE1B540" X-Mailer: Microsoft Office Outlook 12.0 Thread-Index: AcyNpfyCtDyvnB33RuaPaOwckewWUg== Content-Language: fr
the From is there also the name , not an Email.
Thanks for any other suggestion,
Pierre.
Votes
Translate
Translate
Report
Report
Contributor ,
I found another variable : "replyto"
I tried it,
but it gives the same content as the "from" variable
so, no use.
And I get the name of the sender, not the Email.
example : "Ricken Patel - Avaaz.org"  , this is what is returned in "from" or "replyto"
This is not an Email adress, so I cannot answer via a cfmail.
Votes
Translate
Translate
Report
Report
Contributor ,
Nov 06, 2011 Nov 06, 2011
LATEST
Solution is there :
The email adress is present in the "from" variable inside brakets < >
So it is not displayed.
With a cfdump, it can be seen.
Male a findnocase of "<" , if found, Email is inside < >.
Then just make a string extraction of the email inside the brakets, if brakets exist.
Ans the valid Email is there.
Pierre.
Votes
Translate
Translate
Report
Report
Resources
Documentation
