9 Replies Latest reply on Nov 8, 2011 11:24 PM by BKBK
    Incrementing a variable in memory
    pjlefemine
      I have an older application that is querying a list, pulling out an AD from the list, then incrementing the database by +1 with every pull. The site has grown very popular and now the traffic is creating a ton of deadlocks. I tried using CFLOCK but that made things worse.
      Instead of writing each increment to the DB, I want to write it to memory and then run a routine which collects that value at some interval and update the DB.
      How would I do this? Would I use an Array or some other method? I am not all that familiar with CF.  Thanks in advance.
        • 1. Re: Incrementing a variable in memory
          Dan Bracuk Level 5
          An application variable might do the trick.
          • 2. Re: Incrementing a variable in memory
            insuractive Level 3
            Are you doing your incrementing in the same SQL statement as your select or are you performing them as 2 separate queries?  If you are doing 2 database interactions, its probably a good idea to combine them into a multi-statement SQL block or a stored procedure.  Something like this:
            <cfquery ...>
            Update myADList
            SET counter_field = counter_field + 1
            WHERE id_field = 2;
            SELECT *
            FROM myADList
            WHERE id_field = 2
            </cfquery>
            Or, alternatively, this seems like an excellent candidate for an asynchronous process.  Perhaps instead of having a counter field in your List table (which is giving you deadlock read/write problems), you created a new table that logged AD views.  You could capture a lot more details about your viewers (location/IP Address, datetime, etc) which would allow you to analyze your data a little more.  You could then fire the Log insert off as an asynchronous CF thread or an AJAX call.
            Hope that helps
            -Michael
            • 3. Re: Incrementing a variable in memory
              BKBK Adobe Community Professional & MVP
              A result-set is more or less equivalent to a 2-dimensional array. So you may use an array or a struct to store the data. If the variable involves a user's increment, make it a session variable. Then collect the values within an interval in an application variable, as Dan says.
              • 4. Re: Incrementing a variable in memory
                PatLefemin
                I researched this using a global application variable and that is exactly what I want to do. My problem now is I have no idea how to do that and generate a unique global variable each time since the variable company_id is always random.
                Here is my existing code.
                **This section queries my database for current advertisers**
                <CFQUERY NAME="GRABCOMPANYINFO" DATASOURCE="bg4" cachedwithin="#CreateTimeSpan(0,0,30,0)#">
                SELECT      COMPANY_ID, COMPANY, WEBADDRESS, graphic, flashad
                FROM         dbo.COMPANIES
                WHERE       (COMPANY_ID = #COMPANY_ID#)
                </CFQUERY>
                **Once it pulls the ad the below code updates the views in the DB.
                <cflock name="bannerkingwrite" timeout="10" throwontimeout="no" type="readonly">
                <CFQUERY NAME="UPDATEVIEWS" DATASOURCE="BG4">
                UPDATE     dbo.BANNERKING
                SET        VIEWS=VIEWS +1,MONTHVIEWS=MONTHVIEWS + 1
                WHERE       COMPANY_ID = #COMPANY_ID#
                </CFQUERY>
                </cflock>
                What I want to do is to replace the Update Query above with an application variable.  Any idea how I could do that?
                Thanks -
                • 5. Re: Incrementing a variable in memory
                  <cflock scope="application" timeout="10" throwontimeout="no" type="exclusive">
                  <CFQUERY NAME="application.GRABCOMPANYINFO" DATASOURCE="bg4">
                      FROM        dbo.COMPANIES
                      WHERE       COMPANY_ID = #application.COMPANY_ID#
                  </CFQUERY>
                      </CFQUERY>
                  </cflock>
                  • 6. Re: Incrementing a variable in memory
                    pjlefemine Level 1
                    Thanks, but that is not what I was looking for.
                    The first query is fine, I would like to remove the second query which updates the views with an application variable. So it would increment the variable in memory and then I can write it out to the database later.
                    Something similar to this:
                    <cflock scope = "Application" timeout = "30" type = "Exclusive">
                        <cfset application.views#company_id# = application.views#company_id# + 1>
                        </cflock>
                    This does not seem to work.
                    • 7. Re: Incrementing a variable in memory
                      insuractive Level 3
                      You should be able to use CF's structure syntax to dynamically add/refer to named elements in a structure in order to store counts of your company IDs even if you don't know what they will be until run-time.
                      <!--- Initialize application scoped structure in your application.cfc/cfm--->
                      <cfset application.stMyApplicationCounter = StructNew()>
                      <!--- intialize/increment your counter after your query code --->
                           <cfif NOT isDefined("application.stMyApplicationCounter['#company_id#']")>
                                <cfset application.stMyApplicationCounter[company_id] = 0>
                           </cfif>
                          <cfset application.stMyApplicationCounter[company_id]++>
                      </cflock>
                      That should give you a count for each company ID that has been accessed and you can use the keys in later queries if you like in order to update your counts asyncrhonously.
                      • 8. Re: Incrementing a variable in memory
                        I had been cooking up an example. It's along the same lines as Insuractive's.
                        <!--- immediately after the variable application.COMPANY_ID is created, initialize the number of views for each company_id--->
                        <cfparam name="application.views['#application.COMPANY_ID#']" default="0">
                        <cfparam name="application.monthViews['#application.COMPANY_ID#']" default="0">
                        <!--- later on ... --->
                                FROM        dbo.COMPANIES
                            </CFQUERY>
                            <CFQUERY NAME="application.getViews" DATASOURCE="BG4">
                                SELECT     VIEWS, MONTHVIEWS
                                FROM     dbo.BANNERKING
                            </CFQUERY>
                            <!--- update the number of views for each particular company_id--->
                            <cfset application.views["#application.COMPANY_ID#"] = application.views["#application.COMPANY_ID#"] + 1>
                            <cfset application.monthViews["#application.COMPANY_ID#"] = application.monthViews["#application.COMPANY_ID#"] + 1>
                        </cflock>
                        • 9. Re: Incrementing a variable in memory
                          Referring to my last post, it might be more efficient to join the 2 queries into one. In fact I should have commented out the second query as optional. It now looks a bit confusing -- even to me! You would only run it where you needed to use the current number of views from the database.
                                  FROM        dbo.COMPANIES
                              </CFQUERY>
                                  FROM     dbo.BANNERKING
                              </CFQUERY>
                          </cflock>
                          <!--- much later in the code ... --->
                              SET        VIEWS=#application.views[application.COMPANY_ID]#,MONTHVIEWS=#application.monthViews[appl ication.COMPANY_ID]#
                              </CFQUERY>
                          </cflock>
