1 Reply Latest reply on Nov 1, 2011 3:59 AM by Neal Hudson
    Issue with PDF displaying correctly in Flex mx:HTML control in Windows / Reader X
    Neal Hudson
      I'm having an issue with the PDF displaying outside the viewable area of the mx:HTML control in Flex. When the application starts up - the mx:HTML is set to a certain size, but can be enlarged if the application is maximized. These are the following conditions to replicate it:
      • Issue only happens in Windows (Windows 7, not on Mac)
      • Issue only happens with Reader X installed (not with previous versions)
      • Issue only happens when running the built app, does not happen in debug / development mode from FlashBuilder
      Here is some code to reproduce the issue. It looks a bit messy with the groups within groups, but there is other stuff in our application that I've stripped out just to have a small test app to reproduce the issue:
      <s:WindowedApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:mx="library://ns.adobe.com/flex/mx"
      width="1004" height="510" backgroundColor="#000000" >
      <fx:Script>
          <![CDATA[
              import mx.events.FlexEvent;
              protected function press_clickHandler():void
                  htmlContent.location = "vt1_04_using_flash_builder.pdf";
      </fx:Script>
      <fx:DesignLayer>
      <mx:HDividedBox id="myDividedBox" left="10" right="5" top="39" bottom="61" liveDragging="false">
      <mx:Panel id="pnlTreeCtrl" width="250" height="100%" headerHeight="0">
      <s:Button id="press" buttonMode="true" click="press_clickHandler()"
      right="84" top="8" label="Press"/>
      </mx:Panel>
      <s:Group id="groupCourseMain" height="100%" >
      <s:Group id="groupCourseHTML" right="0" top="30" bottom="0" width="100%">
      <mx:HTML id="htmlContent" top="0" bottom="0" width="100%" />
      </s:Group>
      </s:Group>
      </mx:HDividedBox>
      </fx:DesignLayer>
      </s:WindowedApplication>
