1 Reply Latest reply on Oct 28, 2011 8:30 PM by John Hawkinson
    placing the content in a text frame from xml
    siva.sachu
      i ve a text frame the lable the frame is"MainR" and the contents in the text frame is "<Family>",now the thing is that how i can replace the conent in the text frame by the xml document ,where the xml document contains a family node.
      thanks in advance
      Regards
      SIVa
        • 1. Re: placing the content in a text frame from xml
          John Hawkinson Level 5
          This is not really a typical InDesign XML workflow.
          Have you imported the "xml document" into the InDesign XML tree in your InDesign document?
          What scripting language are you working in?
          It sounds like you want to take the XMLElement and call .placeXML() on it, placing it into the relevant text frame. Or if you only need to replace the bracketted text, you'll have to place it into a temporary story, and then move it into your target text frame.
          It might help to tell us more (a lot more) about your desired workflow. Pictures are always good.
