1. Re: ZWAdobeF font
Dov Isaacs Oct 28, 2011 6:30 AM (in response to CNatka)The ZWAdobeF font is a special hack installed by Adobe Acrobat for use by some of its PDFMaker components for use as a marker in creating PDF files from Microsoft Office files.
Do not delete the font if you have Acrobat installed on the system. It is otherwise useless to end users.
- Dov
2. Re: ZWAdobeF font
CNatka Oct 29, 2011 2:11 AM (in response to Dov Isaacs)So the ZWAdobeF font solve the purpose of conversion of some type of file format to PDF as the PDFMaker component in Adobe Acrobat and hence is installed on the system? Does removing the font causes the failure in the PDF conversion procedure. The issue i am facing is that when I am converting some text file in the ZWAdobeF font into PDF, text's relative position is changed in the created PDF and not the same as it was in the original drawing. My question is that if the font is used for internal support only then why other software like Office and others provide a font to write text in this format and what is the use of representation of this font for end users?
Kindly give me some information regarding this.
-CNatka
3. Re: ZWAdobeF font
Dov Isaacs Oct 29, 2011 2:16 AM (in response to CNatka)Do not use the ZWAdobeF font for any purpose whatsoever. It is not really a “valid” font. On the other hand, as long as you have Acrobat installed, don't delete it.
Just make believe it doesn't exist and you won't get into any trouble!!!
- Dov
