This content has been marked as final.
Show 2 replies
1. Re: HDS-Live Apache Module Error 1026
Mally H Oct 28, 2011 9:43 AM (in response to Mally H)Ive solved it, HDS-Live does not work with 64bit FMS !!! reinstalled 32bit and it is dandy,
2. Re: HDS-Live Apache Module Error 1026
Nitin Goel Oct 31, 2011 12:42 AM (in response to Mally H)Hi Mally,
Its good that you solved the problem, but HDS-live must have worked with 64 bit FMS. In case of 64 bit, only the Apache and its modules needs to be 32 bit. FMS can still be 64 bit. 64 bit FMS installation on windows does install 32 bit apache along with it..
It seems you had some other issue. Possibly a bug. If you see "Error from libf4f.dll: Could not parse afra index." more often, please consider to file a bug..
