1 Reply Latest reply on Oct 31, 2011 2:58 AM by draincover
    FlashBuilder 4.5 / Service WSDL (PHP) / How to use my Web Service Data into my Flex Project ?
    cpoupou
      Hello,
      I use FlashBuilder 4.5 for PHP.
      I have build a service in PHP wich runs independantly from FlashBuilder.
      I use the php-wsdl class to run the soap server, and generate the wsdl from my php service file.
      This service has 3 methods :
      - Method 1 "GetBla" : returns a string
      - Method 2 "GetAuth" : returns an object
      - Method 3 "GetInfo ": returns an array of object
      My Methods from my Data/Services view in my Flex Project
      In my Flex Project, through my Responders, i get result only with the method 1 "GetBla" which works like a charm.
      When I run my Flex Project, I monitore through the Netwotk Monitor view of FlashBuilder and everything is fine, i get responses full of data from my 3 method calls.
      Structure of the Response of Method 3 Call through Network Monitor View : Array of objects
      Then for the example above, Array of objects from my Method 3 "GetInfo", I assigne the result of my CallResponder like this :
      But i get nothing into my ArrayCollection myInfo.
      I have tried a lot, i assume that my flex level is low.
      I need your help.
      Thanks for reading and sorry for my bad english.
      cpoupou
