6 Replies Latest reply on Nov 24, 2011 7:49 AM by willyfury
    Can load Flash 11 in Firefox but not in IE8
    cjf36
      I've tried a lot of the suggestions posted here (security settings etc) and it will not install in IE8. I have XP Pro (SP3) and am using Webroot. After disabling Webroot & Windows firewalls I can get Flash to install in Firefox, so I know it is on my computer, but whenever I use IE8 and try to use a program like YouTube it keeps saying that I need to upgrade Flash. It seems to install ok and says "Installation complete- you are now running Flash 11" but it doesn't work. I've uninstalled the program many times and tried to install it with all the anti-virus protection turned off but no luck.
      Any help or suggestions would be very much appreciated.
      thanks
      Carl
        • 1. Re: Can load Flash 11 in Firefox but not in IE8
          pwillener Level 8
          What files do you have in C:\Windows\system32\Macromed\Flash ?
          Can you post the contents of the FlashInstall.log file from that same folder?  (Or attach the whole file to your next post.)
          • 2. Re: Can load Flash 11 in Firefox but not in IE8
            cjf36 Level 1
            The files in that folder are  FlashInstall.log
                                                  FlashInstall.log.virtual
                                                  flashplayer.xpt
                                                  FlashUtil11c_Plugin.exe
                                                  genuinst.exe
                                                  install.log
                                                  KB923789.inf
                                                  NPSWF32.dll
            I can't seem to get the install log to paste here- any suggestions as to how to display it?
            • 3. Re: Can load Flash 11 in Firefox but not in IE8
              pwillener Level 8
              Your Windows XP is 32-bit, not the 64-bit edition?
              Anyway, I don't see the Flash Player IE add-on in your install folder, but I see several old things in there.  I suggest you do the following
              • go to http://forums.adobe.com/thread/909550 and download (save to disk)
                • the 32-bit uninstaller
                • the 32-bit installer for Internet Explorer
                • the 32-bit installer for Firefox
              • close all browser windows, then run the downloaded uninstaller
              • restart Windows
              • delete any remaining files in C:\Windows\system32\Macromed\Flash
              • now run both downloaded installers
              If you still have problems, please list again what files you now have in that install folder.
              Also paste the contents of the FlashInstall.log file (using Ctrl+V), or attach the log file to your forum post.
              • 4. Re: Can load Flash 11 in Firefox but not in IE8
                cjf36 Level 1
                Here is the contents of the Flash Install log. The weird thing is that it installed ok and works fine using Firefox, just not IE8. I have a 32 bit system. One other thing, I have another computer with XP and when I was prompted to update Flash, I tried and the same thing happened. Luckily I was able to use system restore to get back the older version.
                I'll be away for a couple of weeks and when I return I'll try other install methods, if you have any suggestions. It's strange that the probelem exists on both my 32 bit XP systems, which leads me to believe that the problem is a compatablity issue with Flash as opposed to any flaws in my system.
                thanks
                =O====== M/10.1.102.64 2010-11-27+05-00-33.968 ========
                0000 [I] 00000010 "C:\Documents and Settings\Owner\My Documents\Downloads\install_flash_player(2).exe"
                0001 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/Version 2
                =X====== M/10.1.102.64 2010-11-27+05-00-48.609 ========
                =O====== M/10.1.102.64 2010-11-27+05-01-02.515 ========
                0002 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/Version 2
                0003 [W] 00001037 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
                0004 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
                0005 [W] 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
                0006 [W] 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
                0007 [W] 00001036 Software\Opera Software/Last CommandLine 2
                0008 [W] 00001036 Software\Opera Software/Last CommandLine 2
                0009 [W] 00001036 Software\Opera Software/Plugin Path 2
                0010 [W] 00001036 Software\Opera Software/Plugin Path 2
                0011 [I] 00000014 C:\WINDOWS\system32\Macromed\Flash\NPSWF32.dll
                0012 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10l_Plugin.exe
                0013 [I] 00000017 C:\WINDOWS\system32\Macromed\Flash
                =X====== M/10.1.102.64 2010-11-27+05-01-19.093 ========
                =O====== M/10.2.152.26 2011-02-19+20-25-25.671 ========
                0000 [I] 00000010 "C:\DOCUME~1\Owner\LOCALS~1\Temp\FlashPlayerUpdate.exe"
                0001 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                0002 [I] 00000013 C:\WINDOWS\system32\Macromed\Flash\Flash10m.ocx
                0003 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10m_ActiveX.exe
                0004 [I] 00000016 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10m_ActiveX.dll
                =X====== M/10.2.152.26 2011-02-19+20-25-47.671 ========
                =O====== M/10.2.152.26 2011-03-10+00-08-41.187 ========
                0000 [I] 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil10m_ActiveX.exe" -update activex
                0001 [I] 00000011 0
                =X====== M/10.2.152.26 2011-03-10+00-09-34.609 ========
                =O====== M/10.2.152.32 2011-03-10+00-09-34.734 ========
                0000 [I] 00000010 "C:\DOCUME~1\Owner\LOCALS~1\Temp\2.dir\InstallFlashPlayer.exe" -iv 0
                0001 [I] 00000013 C:\WINDOWS\system32\Macromed\Flash\Flash10n.ocx
                0002 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10n_ActiveX.exe
                0003 [I] 00000016 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10n_ActiveX.dll
                =X====== M/10.2.152.32 2011-03-10+00-12-13.859 ========
                =O====== M/10.2.152.32 2011-04-09+00-41-18.500 ========
                0000 [I] 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil10n_ActiveX.exe" -update activex
                0001 [E] 00001039
                =X====== M/10.2.152.32 2011-04-09+00-41-27.156 ========
                =O====== M/10.2.152.32 2011-04-10+18-05-54.125 ========
                0001 [E] 00001039
                =X====== M/10.2.152.32 2011-04-10+18-06-02.593 ========
                =O====== M/10.2.152.32 2011-04-17+00-48-43.046 ========
                =X====== M/10.2.152.32 2011-04-17+00-48-58.375 ========
                =O====== M/10.2.152.32 2011-04-17+01-20-55.886 ========
                =X====== M/10.2.152.32 2011-04-17+01-21-17.120 ========
                =O====== M/10.2.152.32 2011-04-18+16-38-59.859 ========
                0001 [E] 00001039
                =X====== M/10.2.152.32 2011-04-18+16-39-04.390 ========
                =O====== M/10.2.152.32 2011-05-01+22-13-21.296 ========
                0001 [E] 00001039
                =X====== M/10.2.152.32 2011-05-01+22-13-26.234 ========
                =O====== M/10.2.152.32 2011-05-14+23-24-34.953 ========
                0001 [E] 00001039
                =X====== M/10.2.152.32 2011-05-14+23-25-48.109 ========
                =O====== M/10.2.152.32 2011-05-19+16-52-11.484 ========
                0001 [E] 00001039
                =X====== M/10.2.152.32 2011-05-19+16-52-53.812 ========
                =O====== M/10.2.152.32 2011-06-03+14-25-09.421 ========
                0001 [I] 00000011 0
                =X====== M/10.2.152.32 2011-06-03+14-26-53.734 ========
                =O====== M/10.3.181.16 2011-06-03+14-26-53.812 ========
                0000 [I] 00000010 "C:\DOCUME~1\Owner\LOCALS~1\Temp\3.dir\InstallFlashPlayer.exe" -iv 0
                0001 [I] 00000013 C:\WINDOWS\system32\Macromed\Flash\Flash10r.ocx
                0002 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10r_ActiveX.exe
                0003 [I] 00000016 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10r_ActiveX.dll
                0004 [I] 00000019 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
                =X====== M/10.3.181.16 2011-06-03+14-27-32.203 ========
                =O====== M/10.3.181.16 2011-06-13+00-38-35.093 ========
                0000 [I] 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil10r_ActiveX.exe" -update activex
                =X====== M/10.3.181.16 2011-06-13+00-38-40.359 ========
                =O====== M/10.3.181.16 2011-06-20+04-11-08.421 ========
                0001 [I] 00000011 0
                =X====== M/10.3.181.16 2011-06-20+04-11-43.859 ========
                =O====== M/10.3.181.26 2011-06-20+04-11-44.000 ========
                0001 [I] 00000013 C:\WINDOWS\system32\Macromed\Flash\Flash10t.ocx
                0002 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10t_ActiveX.exe
                0003 [I] 00000016 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10t_ActiveX.dll
                0005 [W] 00001024 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl 183
                =X====== M/10.3.181.26 2011-06-20+04-12-53.296 ========
                =O====== M/10.3.181.26 2011-08-18+01-20-29.203 ========
                0000 [I] 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil10t_ActiveX.exe" -update activex
                0001 [I] 00000011 0
                =X====== M/10.3.181.26 2011-08-18+01-22-21.968 ========
                =O====== M/10.3.183.5 2011-08-18+01-22-22.015 ========
                0001 [I] 00000013 C:\WINDOWS\system32\Macromed\Flash\Flash10v.ocx
                0002 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10v_ActiveX.exe
                0003 [I] 00000016 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10v_ActiveX.dll
                0005 [I] 00000020 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
                0006 [W] 00001024 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl 183
                =X====== M/10.3.183.5 2011-08-18+01-23-02.031 ========
                =O====== M/10.3.183.10 2011-09-23+15-58-04.031 ========
                0000 [I] 00000010 "C:\Documents and Settings\Owner\Local Settings\Temp\install_flash_player_ax.exe" -dlm -install
                0001 [W] 00001015 C:\WINDOWS\system32\Macromed\Flash\Flash10v.ocx 20
                0002 [I] 00000018
                0003 [W] 00001015 C:\WINDOWS\system32\Macromed\Flash\Flash10v.ocx 20
                0004 [I] 00000013 C:\WINDOWS\system32\Macromed\Flash\Flash10x.ocx
                0005 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10x_ActiveX.exe
                0006 [I] 00000016 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10x_ActiveX.dll
                0007 [I] 00000019 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
                0008 [I] 00000020 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
                0009 [W] 00001024 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl 183
                =X====== M/10.3.183.10 2011-09-23+15-58-17.406 ========
                =O====== M/11.0.1.152 2011-10-14+02-58-52.625 ========
                0000 [I] 00000010 "C:\Virtual\Untrusted\C_\Documents and Settings\Owner\Local Settings\Temp\3.dir\InstallFlashPlayer.exe" -iv 0
                0001 [W] 00001036 Software\Macromedia\FlashPlayer\SafeVersions/11.0 2
                0002 [W] 00001036 Software\Macromedia\FlashPlayer\SafeVersions/11.0 2
                0003 [I] 00000020 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
                0004 [I] 00000013 C:\WINDOWS\system32\Macromed\Flash\Flash11c.ocx
                0005 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil11c_ActiveX.exe
                0006 [I] 00000016 C:\WINDOWS\system32\Macromed\Flash\FlashUtil11c_ActiveX.dll
                0008 [W] 00001024 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl 183
                =X====== M/11.0.1.152 2011-10-14+02-59-44.484 ========
                =O====== M/11.0.1.152 2011-10-22+22-08-59.203 ========
                0000 [I] 00000010 "C:\Documents and Settings\Owner\Local Settings\Temp\install_flash_player_ax_32bit.exe" -dlm -install
                0001 [F] 00001041
                =X====== M/11.0.1.152 2011-10-22+22-09-00.562 ========
                =O====== M/11.0.1.152 2011-10-22+22-09-17.656 ========
                0001 [F] 00001041
                =X====== M/11.0.1.152 2011-10-22+22-09-18.406 ========
                =O====== M/11.0.1.152 2011-10-22+22-09-28.796 ========
                0001 [I] 00000020 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
                0002 [I] 00000013 C:\WINDOWS\system32\Macromed\Flash\Flash11c.ocx
                0003 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil11c_ActiveX.exe
                0004 [I] 00000016 C:\WINDOWS\system32\Macromed\Flash\FlashUtil11c_ActiveX.dll
                0005 [I] 00000019 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
                =X====== M/11.0.1.152 2011-10-22+22-09-34.625 ========
                =O====== M/11.0.1.152 2011-10-27+19-41-47.156 ========
                0000 [I] 00000010 "C:\DOCUME~1\Owner\LOCALS~1\Temp\17.dir\InstallFlashPlayer.exe" -iv 6
                =X====== M/11.0.1.152 2011-10-27+19-41-57.390 ========
                =O====== M/11.0.1.152 2011-10-27+19-41-34.109 ========
                0000 [I] 00000010 C:\DOCUME~1\Owner\LOCALS~1\Temp\ICD1.tmp\FP_AX_CAB_INSTALLER64.exe
                0001 [I] 00000011 0
                =X====== M/11.0.1.152 2011-10-27+19-41-57.468 ========
                =O====== M/11.0.1.152 2011-10-27+19-58-29.406 ========
                0001 [F] 00001041
                =X====== M/11.0.1.152 2011-10-27+19-58-30.062 ========
                =O====== M/11.0.1.152 2011-10-27+19-58-39.093 ========
                0001 [F] 00001041
                =X====== M/11.0.1.152 2011-10-27+19-58-39.546 ========
                =O====== M/11.0.1.152 2011-10-27+19-58-55.484 ========
                =X====== M/11.0.1.152 2011-10-27+19-59-01.953 ========
                =O====== M/11.0.1.152 2011-10-27+20-01-49.578 ========
                0001 [F] 00001041
                =X====== M/11.0.1.152 2011-10-27+20-01-50.031 ========
                =O====== M/11.0.1.152 2011-10-27+20-02-01.546 ========
                =X====== M/11.0.1.152 2011-10-27+20-02-05.578 ========
                =O====== M/11.0.1.152 2011-10-27+20-12-31.484 ========
                0000 [I] 00000010 "C:\DOCUME~1\Owner\LOCALS~1\Temp\7.dir\InstallFlashPlayer.exe" -iv 6
                =X====== M/11.0.1.152 2011-10-27+20-12-52.484 ========
                =O====== M/11.0.1.152 2011-10-27+20-12-18.937 ========
                0000 [I] 00000010 C:\DOCUME~1\Owner\LOCALS~1\Temp\ICD2.tmp\FP_AX_CAB_INSTALLER64.exe
                0001 [I] 00000011 0
                =X====== M/11.0.1.152 2011-10-27+20-12-52.546 ========
                =O====== M/11.0.1.152 2011-10-27+20-35-07.812 ========
                0000 [I] 00000010 C:\WINDOWS\system32\Macromed\Flash\FlashUtil11c_ActiveX.exe -maintain activex
                0001 [W] 00001015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil11c_ActiveX.exe 5
                0002 [I] 00000018
                0003 [W] 00001015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil11c_ActiveX.exe 5
                0004 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
                0005 [W] 00001037 Software\Macromedia\FlashPlayerActiveX/ 2
                0006 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
                0007 [W] 00001021
                0008 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                0009 [W] 00001015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil11c_ActiveX.exe 5
                0010 [I] 00000012
                =X====== M/11.0.1.152 2011-10-27+20-35-22.359 ========
                =O====== M/10.1.102.64 2011-10-27+20-39-31.312 ========
                0000 [I] 00000010 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10l_Plugin.exe -maintain plugin
                0001 [W] 00001015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10l_Plugin.exe 5
                0002 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
                0003 [W] 00001037 Software\Macromedia\FlashPlayerPlugin/ 2
                0004 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
                0005 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
                0006 [W] 00001021
                0007 [W] 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
                0008 [W] 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
                0009 [W] 00001036 Software\Opera Software/Last CommandLine 2
                0010 [W] 00001036 Software\Opera Software/Last CommandLine 2
                0011 [W] 00001036 Software\Opera Software/Plugin Path 2
                0012 [W] 00001036 Software\Opera Software/Plugin Path 2
                0013 [W] 00001015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10l_Plugin.exe 5
                0014 [I] 00000012
                =X====== M/10.1.102.64 2011-10-27+20-39-36.812 ========
                =O====== M/11.0.1.152 2011-10-27+20-42-52.875 ========
                0002 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                0004 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
                0005 [I] 00000013 C:\WINDOWS\system32\Macromed\Flash\Flash11c.ocx
                0006 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil11c_ActiveX.exe
                0007 [I] 00000016 C:\WINDOWS\system32\Macromed\Flash\FlashUtil11c_ActiveX.dll
                0008 [I] 00000019 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
                =X====== M/11.0.1.152 2011-10-27+20-42-55.453 ========
                =O====== M/11.0.1.152 2011-10-27+20-49-46.359 ========
                0000 [I] 00000010 "C:\DOCUME~1\Owner\LOCALS~1\Temp\10.dir\InstallFlashPlayer.exe" -iv 6
                =X====== M/11.0.1.152 2011-10-27+20-50-22.062 ========
                =O====== M/11.0.1.152 2011-10-27+20-49-36.281 ========
                0000 [I] 00000010 C:\DOCUME~1\Owner\LOCALS~1\Temp\ICD3.tmp\FP_AX_CAB_INSTALLER64.exe
                0001 [I] 00000011 0
                =X====== M/11.0.1.152 2011-10-27+20-50-22.156 ========
                =O====== M/11.0.1.152 2011-10-27+22-53-16.484 ========
                0002 [I] 00000018
                0007 [W] 00001037 Software\Microsoft\Code Store Database\Distribution Units\{D27CDB6E-AE6D-11CF-96B8-444553540000}/ 2
                0008 [W] 00001021
                0009 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                0010 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                0011 [W] 00001015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil11c_ActiveX.exe 5
                0012 [I] 00000012
                =X====== M/11.0.1.152 2011-10-27+22-54-04.296 ========
                =O====== M/11.0.1.152 2011-10-28+00-45-09.328 ========
                =X====== M/11.0.1.152 2011-10-28+00-45-11.281 ========
                =O====== M/11.0.1.152 2011-10-28+00-48-06.750 ========
                0001 [F] 00001041
                =X====== M/11.0.1.152 2011-10-28+00-48-07.312 ========
                =O====== M/11.0.1.152 2011-10-28+00-48-32.468 ========
                0001 [F] 00001041
                =X====== M/11.0.1.152 2011-10-28+00-48-32.906 ========
                =O====== M/11.0.1.152 2011-10-28+01-07-09.703 ========
                0001 [F] 00001041
                =X====== M/11.0.1.152 2011-10-28+01-07-10.203 ========
                =O====== M/11.0.1.152 2011-10-28+01-07-27.828 ========
                =X====== M/11.0.1.152 2011-10-28+01-07-34.453 ========
                =O====== M/11.0.1.152 2011-10-28+01-11-28.109 ========
                0000 [I] 00000010 "C:\Documents and Settings\Owner\Local Settings\Temp\install_flash_player_32bit.exe" -dlm -install
                0002 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                0003 [F] 00001041
                =X====== M/11.0.1.152 2011-10-28+01-11-28.765 ========
                =O====== M/11.0.1.152 2011-10-28+01-11-42.125 ========
                0004 [W] 00001037 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
                0005 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
                0006 [W] 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
                0007 [W] 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
                0012 [I] 00000014 C:\WINDOWS\system32\Macromed\Flash\NPSWF32.dll
                0013 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil11c_Plugin.exe
                0014 [I] 00000017 C:\WINDOWS\system32\Macromed\Flash
                0015 [I] 00000019 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
                0016 [W] 00001024 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl 183
                =X====== M/11.0.1.152 2011-10-28+01-11-44.343 ========
                =O====== M/11.0.1.152 2011-10-28+01-29-47.203 ========
                0001 [F] 00001041
                =X====== M/11.0.1.152 2011-10-28+01-29-47.640 ========
                =O====== M/11.0.1.152 2011-10-28+01-29-53.437 ========
                0001 [F] 00001041
                =X====== M/11.0.1.152 2011-10-28+01-29-54.359 ========
                =O====== M/11.0.1.152 2011-10-28+01-29-57.500 ========
                0001 [F] 00001041
                =X====== M/11.0.1.152 2011-10-28+01-29-58.015 ========
                =O====== M/11.0.1.152 2011-10-28+01-30-14.671 ========
                =X====== M/11.0.1.152 2011-10-28+01-30-18.859 ========
                =O====== M/10.3.183.10 2011-10-28+01-56-00.046 ========
                0000 [I] 00000010 "C:\Virtual\Untrusted\C_\Documents and Settings\Owner\Local Settings\Temporary Internet Files\Content.IE5\APDRV35S\uninstall_flash_player[1].exe" -force
                0001 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
                0002 [W] 00001037 Software\Macromedia\FlashPlayerActiveX/ 2
                0003 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
                0004 [W] 00001037 Software\Microsoft\Code Store Database\Distribution Units\{D27CDB6E-AE6D-11CF-96B8-444553540000}/ 2
                0005 [W] 00001021
                0006 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                0007 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
                0008 [W] 00001037 Software\Macromedia\FlashPlayerPlugin/ 2
                0009 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
                0010 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
                0011 [W] 00001021
                0012 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                0013 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                0014 [W] 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
                0015 [W] 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
                0016 [W] 00001036 Software\Opera Software/Last CommandLine 2
                0017 [W] 00001036 Software\Opera Software/Last CommandLine 2
                0018 [W] 00001036 Software\Opera Software/Plugin Path 2
                0019 [W] 00001036 Software\Opera Software/Plugin Path 2
                =X====== M/10.3.183.10 2011-10-28+01-56-06.500 ========
                =O====== M/11.0.1.152 2011-10-28+02-07-19.890 ========
                0003 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                0004 [I] 00000020 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
                0005 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
                0006 [I] 00000013 C:\WINDOWS\system32\Macromed\Flash\Flash11c.ocx
                0007 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil11c_ActiveX.exe
                0008 [I] 00000016 C:\WINDOWS\system32\Macromed\Flash\FlashUtil11c_ActiveX.dll
                0009 [I] 00000019 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
                =X====== M/11.0.1.152 2011-10-28+02-07-22.828 ========
                =O====== M/11.0.1.152 2011-10-28+02-09-16.312 ========
                0001 [F] 00001041
                =X====== M/11.0.1.152 2011-10-28+02-09-17.062 ========
                =O====== M/11.0.1.152 2011-10-28+02-09-24.843 ========
                0001 [F] 00001041
                =X====== M/11.0.1.152 2011-10-28+02-09-25.218 ========
                =O====== M/11.0.1.152 2011-10-28+02-09-31.906 ========
                0001 [F] 00001041
                =X====== M/11.0.1.152 2011-10-28+02-09-32.375 ========
                =O====== M/11.0.1.152 2011-10-28+02-10-12.734 ========
                0001 [F] 00001041
                =X====== M/11.0.1.152 2011-10-28+02-10-13.250 ========
                =O====== M/11.0.1.152 2011-10-28+02-10-14.937 ========
                0001 [F] 00001041
                =X====== M/11.0.1.152 2011-10-28+02-10-15.421 ========
                =O====== M/11.0.1.152 2011-10-28+02-10-18.937 ========
                0001 [F] 00001041
                =X====== M/11.0.1.152 2011-10-28+02-10-19.500 ========
                =O====== M/11.0.1.152 2011-10-28+02-10-36.312 ========
                0001 [F] 00001041
                =X====== M/11.0.1.152 2011-10-28+02-10-36.718 ========
                =O====== M/11.0.1.152 2011-10-28+02-10-38.656 ========
                0001 [F] 00001041
                =X====== M/11.0.1.152 2011-10-28+02-10-39.046 ========
                =O====== M/11.0.1.152 2011-10-28+02-10-43.015 ========
                0001 [F] 00001041
                =X====== M/11.0.1.152 2011-10-28+02-10-43.468 ========
                =O====== M/11.0.1.152 2011-10-28+02-10-48.250 ========
                0001 [F] 00001041
                =X====== M/11.0.1.152 2011-10-28+02-10-48.671 ========
                =O====== M/11.0.1.152 2011-10-28+02-11-26.687 ========
                0001 [F] 00001041
                =X====== M/11.0.1.152 2011-10-28+02-11-27.093 ========
                =O====== M/11.0.1.152 2011-10-28+02-11-27.984 ========
                0001 [F] 00001041
                =X====== M/11.0.1.152 2011-10-28+02-11-28.390 ========
                =O====== M/11.0.1.152 2011-10-28+02-12-15.921 ========
                0001 [F] 00001041
                =X====== M/11.0.1.152 2011-10-28+02-12-16.468 ========
                =O====== M/11.0.1.152 2011-10-28+02-12-18.187 ========
                0001 [F] 00001041
                =X====== M/11.0.1.152 2011-10-28+02-12-18.593 ========
                =O====== M/11.0.1.152 2011-10-28+02-13-59.187 ========
                0001 [F] 00001041
                =X====== M/11.0.1.152 2011-10-28+02-13-59.687 ========
                =O====== M/11.0.1.152 2011-10-28+02-14-13.859 ========
                0001 [F] 00001041
                =X====== M/11.0.1.152 2011-10-28+02-14-14.421 ========
                =O====== M/11.0.1.152 2011-10-28+02-14-15.625 ========
                0001 [F] 00001041
                =X====== M/11.0.1.152 2011-10-28+02-14-16.171 ========
                =O====== M/10.3.183.10 2011-10-28+02-24-31.796 ========
                0001 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                0003 [W] 00001037 Software\Macromedia\FlashPlayerActiveX/ 2
                0004 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
                0005 [W] 00001037 Software\Microsoft\Code Store Database\Distribution Units\{D27CDB6E-AE6D-11CF-96B8-444553540000}/ 2
                0006 [W] 00001021
                0007 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                0008 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                0009 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                0010 [W] 00001018
                0011 [W] 00001036 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
                0012 [W] 00001037 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
                0013 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
                0014 [W] 00001019
                0015 [W] 00001020
                0016 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
                0017 [W] 00001037 Software\Macromedia\FlashPlayerPlugin/ 2
                0018 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
                0019 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
                0020 [W] 00001021
                0021 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                0022 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                0023 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\{2CA4F306-B280-4ab2-B5E1-1DFA3583F046}/C:\WINDOWS\system32\FlashPlayerCPLApp.c pl 2
                0024 [W] 00001048
                0025 [I] 00000020 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
                0026 [W] 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
                0027 [W] 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
                0028 [W] 00001036 Software\Opera Software/Last CommandLine 2
                0029 [W] 00001036 Software\Opera Software/Last CommandLine 2
                0030 [W] 00001036 Software\Opera Software/Plugin Path 2
                0031 [W] 00001036 Software\Opera Software/Plugin Path 2
                =X====== M/10.3.183.10 2011-10-28+02-24-36.328 ========
                =O====== M/11.0.1.152 2011-10-28+02-58-32.156 ========
                =X====== M/11.0.1.152 2011-10-28+02-58-36.015 ========
                =O====== M/11.0.1.152 2011-10-28+03-53-17.656 ========
                0000 [I] 00000010 "C:\DOCUME~1\Owner\LOCALS~1\Temp\58.dir\InstallFlashPlayer.exe" -iv 6
                =X====== M/11.0.1.152 2011-10-28+03-53-25.796 ========
                =O====== M/11.0.1.152 2011-10-28+03-53-05.187 ========
                0000 [I] 00000010 C:\DOCUME~1\Owner\LOCALS~1\Temp\ICD5.tmp\FP_AX_CAB_INSTALLER64.exe
                0001 [I] 00000011 0
                =X====== M/11.0.1.152 2011-10-28+03-53-25.812 ========
                =O====== M/11.0.1.152 2011-10-28+03-53-58.375 ========
                0000 [I] 00000010 "C:\DOCUME~1\Owner\LOCALS~1\Temp\60.dir\InstallFlashPlayer.exe" -iv 6
                =X====== M/11.0.1.152 2011-10-28+03-54-42.296 ========
                =O====== M/11.0.1.152 2011-10-28+03-53-44.343 ========
                0000 [I] 00000010 C:\DOCUME~1\Owner\LOCALS~1\Temp\ICD6.tmp\FP_AX_CAB_INSTALLER64.exe
                0001 [I] 00000011 0
                =X====== M/11.0.1.152 2011-10-28+03-54-42.312 ========
                =O====== M/11.0.1.152 2011-10-28+14-44-16.656 ========
                0001 [E] 00001039
                =X====== M/11.0.1.152 2011-10-28+14-44-33.406 ========
                =O====== M/11.0.1.152 2011-10-28+14-44-34.859 ========
                0001 [E] 00001039
                =X====== M/11.0.1.152 2011-10-28+14-44-40.843 ========
                =O====== M/11.0.1.152 2011-10-28+14-44-48.875 ========
                0002 [I] 00000018
                0008 [W] 00001021
                0012 [I] 00000012
                =X====== M/11.0.1.152 2011-10-28+14-45-02.109 ========
                =O====== M/11.0.1.152 2011-10-28+15-40-45.796 ========
                =X====== M/11.0.1.152 2011-10-28+15-40-48.937 ========
                =O====== M/11.0.1.152 2011-10-28+15-42-47.500 ========
                0002 [I] 00000018
                0008 [W] 00001021
                0012 [I] 00000012
                =X====== M/11.0.1.152 2011-10-28+15-44-18.125 ========
                =O====== M/11.0.1.152 2011-10-28+15-51-17.046 ========
                0000 [I] 00000010 "C:\DOCUME~1\Owner\LOCALS~1\Temp\C.dir\InstallFlashPlayer.exe" -iv 6
                0004 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                0006 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
                0007 [I] 00000013 C:\WINDOWS\system32\Macromed\Flash\Flash11c.ocx
                0008 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil11c_ActiveX.exe
                0009 [I] 00000016 C:\WINDOWS\system32\Macromed\Flash\FlashUtil11c_ActiveX.dll
                0010 [I] 00000019 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
                =X====== M/11.0.1.152 2011-10-28+15-51-26.890 ========
                =O====== M/11.0.1.152 2011-10-28+15-51-08.062 ========
                0000 [I] 00000010 C:\DOCUME~1\Owner\LOCALS~1\Temp\ICD7.tmp\FP_AX_CAB_INSTALLER64.exe
                0001 [I] 00000011 0
                =X====== M/11.0.1.152 2011-10-28+15-51-26.968 ========
                =O====== M/11.0.1.152 2011-10-28+15-51-45.593 ========
                0000 [I] 00000010 "C:\DOCUME~1\Owner\LOCALS~1\Temp\18.dir\InstallFlashPlayer.exe" -iv 6
                =X====== M/11.0.1.152 2011-10-28+15-52-11.750 ========
                =O====== M/11.0.1.152 2011-10-28+15-51-36.609 ========
                0000 [I] 00000010 C:\DOCUME~1\Owner\LOCALS~1\Temp\ICD8.tmp\FP_AX_CAB_INSTALLER64.exe
                0001 [I] 00000011 0
                =X====== M/11.0.1.152 2011-10-28+15-52-11.765 ========
                =O====== M/11.0.1.152 2011-10-28+16-05-50.531 ========
                0002 [I] 00000018
                0008 [W] 00001021
                0012 [I] 00000012
                =X====== M/11.0.1.152 2011-10-28+16-05-58.046 ========
                =O====== M/11.0.1.152 2011-10-28+16-12-10.875 ========
                0003 [F] 00001041
                =X====== M/11.0.1.152 2011-10-28+16-12-11.875 ========
                =O====== M/11.0.1.152 2011-10-28+16-12-24.062 ========
                0003 [F] 00001041
                =X====== M/11.0.1.152 2011-10-28+16-12-24.703 ========
                =O====== M/11.0.1.152 2011-10-28+16-12-30.859 ========
                =X====== M/11.0.1.152 2011-10-28+16-12-33.718 ========
                • 5. Re: Can load Flash 11 in Firefox but not in IE8
                  pwillener Level 8
                  From the log file you posted, I believe if you follow the method that I posted earlier will let you install Flash Player successfully.
                  (I will also be away for a week from now.)
                  • 6. Re: Can load Flash 11 in Firefox but not in IE8
                    willyfury
                    I have the exact same issue. Adobe Flash 11 works perfect in Firefox. It installs but will not register in IE8. I followed suggestion above downloading 32bit uninstaller and running it, restarting computer, deleting all files in windows\system32\macromed\flash file. closing all browsers and programs using flash, installing the new saved to hard drive 32 bit installers for IE8 and Firefox. Result is the same. Firefox works, IE8 does not.
