0 Replies Latest reply on Oct 28, 2011 12:56 PM by Code Girl
    DropDownList casting problem
    Code Girl Level 1
      Table
      int id
      string name
      Tables extends table
      Array<TableLinks> of children
      TableLinks
      Table rightTable
      In flex, I get a list of Tables from my web service
      Display a combobox with the list of Tables
      Once someone selects from the list the list of TableLinks is populated in a datagrid
      in the rightTable column it displays the rightTable.name in the label
      When you edit the column a dropdownlist shows
      <mx:DataGridColumn id="tableNameDC"
         headerText="Table"
         editable="true"
         dataField="rightTable"
         labelFunction="tableFormat"
         editorDataField="value"
         width="150">
      Is there anyway to cast my Tables list to type Table here?
      Currently, I keep the list as Tables
      When you select and item the value is saved to a value object but casted from Tables to Table
      When you exit the dropdownlist the get value function returns the Table value Object.  But for some reason, it keeps telling me its null.
      Its as if when I cast the Tables item to Table it fails.
      public function get value():TableDto
      return rightTableDto
      protected function selectableDropDown_closeHandler(event:DropDownEvent):void
      rightTableDto = selectableDropDown.selectedItem as TableDto;
      So, if the first question is not doable,  what do you think I am doing wrong?
