3 Replies Latest reply on Oct 28, 2011 9:35 PM by kglad
    Problems with hitTestObject
    RensStudent
      Hey,
      this is my first year of flash and we have an assignment where we must drive with a car to a finishline.
      making the car move isnt a problem, but there has to be 6 objects you must avoid when driving around.
      when i drive around and i hit my object i should avoid, it stops and i cant move around. and instead i want to be able to corrigate my direction.
      some of my terms are in dutch i'll try to make some commentary in english.
      visual idea how it looks like
      i made 4 car objects that look a direction
      up = Autoboven
      down = Autoonder
      left = Autolinks
      right = Autoright
      import flash.display.MovieClip;
      import flash.utils.Timer;
      import flash.events.TimerEvent;
      import flash.text.TextField;
       // kegel = cone
      var clipArray:Array = [kegel1,kegel2,kegel3,kegel4,kegel5,kegel6];
      var auto:MovieClip = new Autolinks();
      var finish:MovieClip = new Finish();
      addChild(auto);
      auto.x= 490;
      auto.y= 80;
      var richting:int = 0;
      //richting  = direction
      //tijd = time
      var tijd:int = 0;
      var txtFld:TextField = new TextField();
      addChild(txtFld);
      txtFld.x = 500;
      txtFld.y = 370;
      var timer:Timer = new Timer(1000);
      timer.addEventListener(TimerEvent.TIMER, onTimer);
      timer.start();
      function onTimer(evt:TimerEvent):void{
                tijd +=1;
                txtFld.text = (tijd) + " sec";
                var clip:MovieClip;
      stage.addEventListener(KeyboardEvent.KEY_DOWN , onKeyPressed);
      function onKeyPressed(evt:KeyboardEvent):void{
                switch (evt.keyCode){
                          case Keyboard.LEFT:
                                    changeLeft();
                          break;
                          case Keyboard.RIGHT:
                                     changeRight();
                          break;
                          case Keyboard.DOWN:
                                    changeDown();
                          break;
                          case Keyboard.UP:
                                    changeUp();
                          break;
      function changeLeft()
                          if (richting != 0)
                                    clip= new Autolinks();
                                    changeRichting(clip);
                                    richting = 0;
                          if(auto.x > 100 && !( isHitting() ) )
                                    auto.x -= 10;
                           else if( isHitting() )
                          else if (auto.x <= 100){
                                    stage.removeEventListener(KeyboardEvent.KEY_DOWN, onKeyPressed);
                                    removeChild(auto);
                                    finish.x = 225;
                                    finish.y = 200;
                                    addChild(finish);
                                    timer.stop();
      function changeRight()
                          if (richting != 1)
                          {          clip= new Autorechts();
                                    richting = 1;}
                          if (!(auto.x < (stage.stageWidth-auto.width)) && !(isHitting()))
                          {          auto.x += 10; }
      function changeUp()
                          if (richting != 2)
                                    clip = new Autoboven();
                                    richting = 2;
                          if ((auto.y > 0)&& !(isHitting()))
                                    auto.y -= 10;
      function changeDown()
               if (richting != 3)
                     clip= new Autoonder();
                     richting = 3;
                if ((auto.y < stage.stageHeight) && !(isHitting()))
                     auto.y += 10;
      function changeRichting(clip:MovieClip)
                var xpos:int = auto.x;
                var ypos:int = auto.y;
                removeChild(auto);
                auto = clip;
                addChild(auto);
                auto.x = xpos;
                auto.y = ypos;
      function isHitting():Boolean
           for (var i:int = 0; i < clipArray.length; i++){
                          if( auto.hitTestObject( clipArray[i] )){
                                    return true;
        return false
      i dont have  big experience in programming in flash, and this code can be very hard to understand
      any help or tips will be appreciated much!
      Greetz Rens
        • 1. Re: Problems with hitTestObject
          you're not doing anything when isHitting() returns true.  why don't you add some code to that part of your app.
          • 2. Re: Problems with hitTestObject
            RensStudent Level 1
            I know, but i cant figure out how i'm able to do it.
            so when i hit an object when i pres the left key , i want to be able to only use up/down/right to corrigate.
            do u have any ideas how i'm able to start solving that?
            thnx
            • 3. Re: Problems with hitTestObject
              here's changeLeft().  the rest are all similar:
               // kegel = cone
              addChild(auto);
              auto.x= 490;
              auto.y= 80;
              //tijd = time
              var tijd:int = 0;
              addChild(txtFld);
              txtFld.x = 500;
              txtFld.y = 370;
              timer.start();
                        tijd +=1;
                        var clip:MovieClip;
                                  case Keyboard.LEFT:
                                            changeLeft();
                                  break;
                                             changeRight();
                                  break;
                                  case Keyboard.DOWN:
                                            changeDown();
                                  break;
                                  case Keyboard.UP:
                                            changeUp();
                                  break;
                                  if (richting != 0)
                                            richting = 0;
                                            auto.x -= 10;
                                            removeChild(auto);
                                            finish.x = 225;
                                            finish.y = 200;
                                            addChild(finish);
                                            timer.stop();
              if(isHitting()){
              auto.x+=10;
