1 Reply Latest reply on Oct 28, 2011 11:56 PM by Andrew Gingerich
    No firewire video out in Mac CS5.5.1?
    Andrew Gingerich Level 1
      Okay, I've got a strange problem here: I'm trying to preview a DV sequence through an OHCI-compliant FireWire deck, and it's just not receiving any signal (audio or video) from Premiere no matter what I do. Device control works fine, capture works fine, and FireWire preview works fine in Final Cut 7 and After Effects. But no matter what I do in the playback settings for Premiere, it's like there's no signal running out through FireWire. Here are my settings:
      DV-native (480i/48khz) sequence
      Realtime playback:
           External Device: "DV: 29.97 720 x 480i"
           Aspect Ratio Conversion: I have tried all three options, to no effect.
           External Device Audio
      I've also tried previewing out native DV material without dropping it into the sequence. No luck there. And no, export to tape doesn't work either.
      System specs:
      Mac Pro 3,1
      OS 10.7.2
      6GB RAM
      nVidia Quadro 4000
      Has anyone else experienced this problem?
