2 Replies Latest reply on Oct 29, 2011 8:45 AM by John T Smith
    Burn error
    Larocl
      Is tehre a maximun time lenght on a compsoed video that Premier will not burn?  I keep getting an internal software error 215.  I have burned one video successfully but it was less tehn thirty minutes.
        • 1. Re: Burn error
          You can usually fit about 70 minutes of video on a standard DVD and about 140 minutes on a dual layer disc -- although the program can squeeze your video and reduce quality to fit a bit more on if you need to.
          How much video are you trying to squeeze onto a disc?
          There could be a number of other problems at work here, including a lack of defragmented hard drive space, source video that doesn't match the project settings, a bad burner driver, etc. So it's hard to even speculate what's up without a lot more information.
          • 2. Re: Burn error
            Some reading...
            Read Bill Hunt on a file type as WRAPPER http://forums.adobe.com/thread/440037?tstart=0
            What is a CODEC... a Primer http://forums.adobe.com/thread/546811?tstart=0
            What CODEC is INSIDE that file? http://forums.adobe.com/thread/440037?tstart=0
            Report back with the codec details of your file, use the programs below
            For PC http://www.headbands.com/gspot/ or http://mediainfo.sourceforge.net/en
            For Mac http://mediainfo.massanti.com/
            Once you know exactly what it is you are editing, report back with that information... and your project setting, and if there is a red line above the video in the timeline, which indicates a mismatch between video and project
            More information needed for someone to help http://forums.adobe.com/thread/416679
            Some is general about your computer and OS, some is specific to video editing
            Build a Configuration file http://www.piriform.com/speccy
            Brand/Model Computer (or Brand/Model Motherboard if self-built)
            How much system memory you have installed, such as 2Gig or ???
            Operating System version, such as Win7 64bit Pro... or whatevevr
            -including your security settings, such as are YOU the Administrator
            -and have you tried to RIGHT click the program Icon and then select
            -the Run as Administrator option (for Windows, not sure about Mac)
            Your Firewall settings and brand of anti-virus are you running
            Brand/Model graphics card, sush as ATI "xxxx" or nVidia "xxxx"
            -or the brand/model graphics chip if on the motherboard
            -and the exact driver version for the above graphics card/chip
            -and how much video memory you have on your graphics card
            Brand/Model sound card, or sound "chip" name on Motherboard
            -and the exact driver version for the above sound card/chip
            Size(s) and configuration of your hard drive(s)... example below
            -and how much FREE space is available on each drive (in Windows
            -you RIGHT click the drive letter while using Windows Explorer
            -and then select the Properties option to see used/free space)
            Windows Indexing is BAD http://forums.adobe.com/thread/676303
            While in Properties, be sure you have drive indexing set OFF
            -for the drive, and for all directories, to improve performance
            Some/Much of the above are available by going to the Windows
            Control Panel and then the Hardware option (Win7 option name)
            OR Control Panel--System--Hardware Tab--Device Manager for WinXP
            And the EXACT type and size of file that is causing you problems
            -for pictures, that includes the camera used and the pixel dimensions
            Plus Video-Specific Information http://forums.adobe.com/thread/459220?tstart=0
            My 3 hard drives are configured as...
            1 - 320Gig Boot for Win7 64bit Pro and all program installs
            2 - 320Gig data for Win7 swap file and video project files
            3 - 1Terabyte data for all video files... input & output files (*)
            (*) for 4 drives, drive 3 all source files & drive 4 all output files
            Search Microsoft to find out how to redirect your Windows swap file
            http://search.microsoft.com/search.aspx?mkt=en-US&setlang=en-US
