11 Replies Latest reply on Oct 30, 2011 9:35 AM by DomCIRWS
    Countdown timer not working
    DomCIRWS Level 1
      I'm brand new to flash, I have CS4 profesional.
      I found a video online on how to make a countdown timer and I can't seem to get it to work.  The video looks like it's using ActionScript2 so I did the same.
      here's the script I'm using, if anyone can point out anything I'm doing wrong I'd apprecitate it.
      this.onEnterFrame = function() {
          var today:Date = new Date ();
          var currentYear = today.getFullYear();
          var currentTime = today.getTime();
          var targetDate:Date = new Date (2012,07,12);
          var targetTime = targetDate.getTime();
          var timeLeft = targetTime - currentTime;
          var sec = Math.floor (timeLeft/1000);
          var min = Math.floor (sec/60);
          var hrs = Math.floor (min/60);
          var days = Math.floor (hrs/24);
          sec = string (sec % 60);
          if (sec.length < 2) {
              sec = "0" + sec;
          min = string (min % 60);
          if (min.length < 2) {
              min = "0" + min;
          hrs = string (hrs % 24);
          if (hrs.length < 2) {
              hrs = "0" + hrs;
          days = string (days);
          var counter:String = days + ":" + hrs + ":" + min + ":" + sec;
          time_txt.text = counter;
        • 1. Re: Countdown timer not working
          do you have a textfield named time_txt on-stage?  if yes, what's not working?  if no, put one on-stage and retest.
          • 2. Re: Countdown timer not working
            DomCIRWS Level 1
            Hi thanks for the reply.
            Yes I do have a textfield called Text_txt on the stage, when I hit command return to test the movie I get these errors.
            Scene 1, Layer 'Action', Frame 1, 1180: Call to a possibly undefined method string. sec = string (sec % 60);
            Scene 1, Layer 'Action', Frame 1, 1180: Call to a possibly undefined method string. min = string (min % 60);
            Scene 1, Layer 'Action', Frame 1, 1180: Call to a possibly undefined method string. hrs = string (hrs % 24);
            Scene 1, Layer 'Action', Frame 1, 1180: Call to a possibly undefined method string. sec = string (days);
            Thanks again
            • 3. Re: Countdown timer not working
              Change string to String
              • 4. Re: Countdown timer not working
                that's because there is no string class.  it's the String class:
                    sec = String (sec % 60);
                        sec = "0" + sec;
                    min = String (min % 60);
                        min = "0" + min;
                   hrs = String (hrs % 24);
                        hrs = "0" + hrs;
                    days = String (days);
                p.s.  i don't think you need to cast those numbers as strings.
                • 5. Re: Countdown timer not working
                  DomCIRWS Level 1
                  I changed the s to S and that got ride of those errors, I'm getting one more
                  Warning: 1090: Migration issue: The onEnterFrame is not triggered automatically by Flash Player at run time in ActionScript 3.0.  You must first register this handler for the event using addEventListener ( 'enterFrame', callback_handler).
                  I'm getting this from an online Tutorial  heres the address to the Tutorial
                  http://www.entheosweb.com/Flash/video_tutorials/countdown_timer.asp
                  dom..
                  • 6. Re: Countdown timer not working
                    Try changing your Publish settings to be for AS2 instead of AS3, otherwise you'll need different code for the etner frame for AS3
                    • 7. Re: Countdown timer not working
                      DomCIRWS Level 1
                      That worked I changed from ActionScript 3 to ActionScript 2 and the counter is working.
                      Thanks for all your help I owe you one.
                      dom...
                      • 8. Re: Countdown timer not working
                        You're welcome.  It should have been caught after seeing the error messages in the first place... thoise were AS3 1180 errors, AS2 more often doesn't provide any.
                        • 9. Re: Countdown timer not working
                          DomCIRWS Level 1
                          About 8 years ago I used to use Director but it's been awhile. This is my first look at Flash, can you point me to some good tutorials??
                          Thanks again
                          dom...
                          • 10. Re: Countdown timer not working
                            If you're just picking up on Flash, I'd recommend you avoid AS2 and learn AS3 from the start instead.  As far as tutorials go, if you have an idea for something you want to develop, the best first step is to use Google and search using terms like "AS3 whatever tutorial" where whatever is the feature or type of project you want to learn about.  Beyond that gotoandlearn.com has numerous well-prepared tutorials, as does Lynda.com (fee-based), and there are others to be found at http://slekx.com/as3-intro/ and http://tv.adobe.com/product/flash/  In short, there are plenty of resources, you just need to become savvy in the ways of finding them, which can all start with Google.
                            • 11. Re: Countdown timer not working
                              DomCIRWS Level 1
                              Thanks again, I'll check out those sites, I'm sure I'll be back with many
                              more questions.
                              dom...
