3 Replies Latest reply on Dec 12, 2011 12:14 PM by AIF Bob
    pixel bender edges problem
    yossialush Level 1
      i'm trying to make simple light shader, here is my code:
      <languageVersion : 1.0;>
      kernel SimpleLight
      <   namespace : "Your Namespace";
          vendor : "Yossi";
          version : 1;
          input image4 src;
          output pixel4 dst;
          parameter float3 lightPosition
                 defaultValue: float3(0,0,-100);
          void
          evaluatePixel()
              pixel4 pixel = sampleNearest(src,outCoord());
              float3 Normal = float3(0.0,0.0,-1.0);
              float3 pixelPos = float3(0.0,0.0,0.0);
              float3 Kd = float3(pixel.r,pixel.g,pixel.b);
              float3 lightDir = lightPosition - pixelPos;
              float diffuse = dot(Normal,normalize(lightDir));
              float3 res = Kd * (diffuse + specular);
              dst = pixel4(res.x,res.y,res.z,pixel.a);
      now here is the source image:
      http://tinypic.com/view.php?pic=2w3nw2q&s=5
      and here is the resault:
      http://tinypic.com/r/245bxtv/5
      instead of getting clean pic i get this thin white line on the right.
      when i run it on "GPU" or "CPU" it's ok, but on "FLASH" i get this.
      can anyone explane how to solve it?
      thank you.
        • 1. Re: pixel bender edges problem
          unique_screenname_here Level 3
          Please provide a working version of your filter. Thanks.
          • 2. Re: pixel bender edges problem
            yossialush Level 1
            i'm very sorry here is the code (working) :
            kernel SimpleLight
                vendor : "Yossi";
                version : 1;
                input image4 src;
                output pixel4 dst;
                void
                evaluatePixel()
                    float3 res = Kd * (diffuse);
            • 3. Re: pixel bender edges problem
              AIF Bob Level 3
              I think that the white line is simply part of the background to the image - does the output exactly match the size of the input?
              Bob
