3 Replies Latest reply on Oct 30, 2011 8:33 PM by Jim_Simon
    Premiere Pro CS5 cross dissolve causes slight pixelation
    Wilderness08 Level 1
      I spliced two clips (with no pixelation upon a test playback), and then added a default cross dissolve which caused a slight pixelation in one "frame." I tried cutting the offending "frame" out, but another pixelated frame appeared. I attempted removing and re-adding a replacement cross dissolve, but a pixelated "frame" kept appearing. Each time I removed the cross dissolve, the spliced clips played perfectly. I have used cross dissoved on other similar projects with no problems. Any suggestions?
