3 Replies Latest reply on Oct 18, 2013 3:26 AM by Jezbelle
    Exporting DPX sequence: frame rate incorrect in exported file
    jd rum
      Hello all, I'm new here.  I'd really appreciate some help with this issue.  My sequence and source files I am working with are 2048x1240, (1.0), 23.976 fps .  I am exporting a DPX file sequence with matching settings.
      The problem is, when I import that new DPX file sequence back into my Premiere project, or an AE project with the same settings, the new DPX file has a frame rate of 29.97 fps.
      I've tried numerous times and checked all my settings.  I can't figure out why the new DPX sequence is not 23.976 fps.  Any ideas what I am doing wrong here?
      here are my export settings, note output and source have matching frame rates:
      and here is a screen grab showing the file properties of my new exported DPX sequence, after importing back into Premiere Pro CS5, with a frame rate of 29.97 fps.
      Any help will be greatly appreciated!
      thanks,
      Jeremy
