2 Replies Latest reply on Oct 31, 2011 12:29 AM by pwillener
    about my earlier post
    theaceofdiamonds1977
      i tried to respond to it, unfortunately, because of this program, adobe flash player 11, i am unable to do so. i un-installed it and downloaded and re-installed version 10.3 and still i'm having the same problems. i am also unable to see what is in the inbox of my email. the thing says it's installed, but when i do the "manage add ons" routine, like other people, it's not there. you tube still swears i don't have a current version of flash player, and it also swears i don't have java. neither of these are true. you guys released a product that is destroying and wreaking havoc on computers. now, as for my system information, here it is in full:
      System Information
      Time of this report: 10/30/2011, 20:31:50
             Machine name: EMACHINE-98E05C
         Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_gdr.101209-1647)
                 Language: English (Regional Setting: English)
      System Manufacturer: eMachines
             System Model: EL1300G
                     BIOS: )Phoenix - Award WorkstationBIOS v6.00PG
                Processor: AMD Athlon(tm) Processor 2650e,  MMX,  3DNow, ~1.6GHz
                   Memory: 894MB RAM
                Page File: 761MB used, 1406MB available
              Windows Dir: C:\WINDOWS
          DirectX Version: DirectX 9.0c (4.09.0000.0904)
      DX Setup Parameters: Not found
           DxDiag Version: 5.03.2600.5512 32bit Unicode
      DxDiag Notes
        DirectX Files Tab: No problems found.
            Display Tab 1: No problems found.
              Sound Tab 1: No problems found.
                Music Tab: No problems found.
                Input Tab: No problems found.
              Network Tab: No problems found.
      DirectX Debug Levels
      Direct3D:    0/4 (n/a)
      DirectDraw:  0/4 (retail)
      DirectInput: 0/5 (n/a)
      DirectMusic: 0/5 (n/a)
      DirectPlay:  0/9 (retail)
      DirectSound: 0/5 (retail)
      DirectShow:  0/6 (retail)
      Display Devices
              Card name: NVIDIA GeForce 6150SE nForce 430
           Manufacturer: NVIDIA
              Chip type: GeForce 6150SE nForce 430
               DAC type: Integrated RAMDAC
             Device Key: Enum\PCI\VEN_10DE&DEV_03D0&SUBSYS_01531025&REV_A2
         Display Memory: 512.0 MB
           Current Mode: 1024 x 768 (32 bit) (60Hz)
                Monitor: Plug and Play Monitor
        Monitor Max Res: 1600,1200
            Driver Name: nv4_disp.dll
         Driver Version: 6.14.0011.6401 (English)
            DDI Version: 9 (or higher)
      Driver Attributes: Final Retail
      Driver Date/Size: 2/25/2008 12:29:00, 5784832 bytes
            WHQL Logo'd: Yes
        WHQL Date Stamp: n/a
                    VDD: n/a
               Mini VDD: nv4_mini.sys
          Mini VDD Date: 2/25/2008 12:29:00, 6867360 bytes
      Device Identifier: {D7B71E3E-4090-11CF-946A-582103C2CB35}
              Vendor ID: 0x10DE
              Device ID: 0x03D0
              SubSys ID: 0x01531025
            Revision ID: 0x00A2
            Revision ID: 0x00A2
            Video Accel:
      Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                         {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                         {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                         {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
               Registry: OK
           DDraw Status: Enabled
             D3D Status: Enabled
             AGP Status: Enabled
      DDraw Test Result: Not run
      D3D7 Test Result: Not run
      D3D8 Test Result: Not run
      D3D9 Test Result: Not run
      Sound Devices
                  Description: Realtek HD Audio output
      Default Sound Playback: Yes
      Default Voice Playback: Yes
                  Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0888&SUBSYS_10250153&REV_1002
              Manufacturer ID: 1
                   Product ID: 100
                         Type: WDM
                  Driver Name: RtkHDAud.sys
               Driver Version: 5.10.0000.5628 (English)
                  WHQL Logo'd: Yes
                Date and Size: 5/20/2008 17:53:00, 4800000 bytes
                  Other Files:
              Driver Provider: Realtek Semiconductor Corp.
               HW Accel Level: Full
                    Cap Flags: 0xF5F
          Min/Max Sample Rate: 8000, 192000
      Static/Strm HW Mix Bufs: 33, 32
      Static/Strm HW 3D Bufs: 33, 32
                    HW Memory: 0
             Voice Management: No
      EAX(tm) 2.0 Listen/Src: Yes, Yes
         I3DL2(tm) Listen/Src: Yes, Yes
      Sensaura(tm) ZoomFX(tm): No
                     Registry: OK
            Sound Test Result: Not run
      Sound Capture Devices
                  Description: Realtek HD Audio Input
        Default Sound Capture: Yes
        Default Voice Capture: Yes
                    Cap Flags: 0x41
                 Format Flags: 0xFFF
      DirectMusic
              DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
           DLS Version: 1.00.0016.0002
          Acceleration: n/a
                 Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
                        Microsoft MIDI Mapper , Hardware (Not Kernel Mode), Output, No DLS, Internal
                        Microsoft GS Wavetable SW Synth , Hardware (Not Kernel Mode), Output, No DLS, Internal
              Registry: OK
      DirectInput Devices
            Device Name: Mouse
               Attached: 1
          Controller ID: n/a
      Vendor/Product ID: n/a
              FF Driver: n/a
            Device Name: Keyboard
               Attached: 1
          Controller ID: n/a
              FF Driver: n/a
      Poll w/ Interrupt: No
               Registry: OK
      USB Devices
      + USB Root Hub
      | Vendor/Product ID: 0x10DE, 0x03F1
      | Matching Device ID: usb\root_hub
      | Service: usbhub
      | Driver: usbhub.sys, 4/14/2008 05:00:00, 59520 bytes
      | Driver: usbd.sys, 4/14/2008 05:00:00, 4736 bytes
      Gameport Devices
      PS/2 Devices
      + Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
      | Matching Device ID: *pnp0303
      | Service: i8042prt
      | Driver: i8042prt.sys, 4/14/2008 05:00:00, 52480 bytes
      | Driver: kbdclass.sys, 4/14/2008 05:00:00, 24576 bytes
      + Terminal Server Keyboard Driver
      | Matching Device ID: root\rdp_kbd
      | Upper Filters: kbdclass
      | Service: TermDD
      | Driver: termdd.sys, 4/14/2008 06:43:22, 40840 bytes
      + PS/2 Compatible Mouse
      | Matching Device ID: *pnp0f13
      | Service: i8042prt
      | Driver: mouclass.sys, 4/14/2008 01:09:48, 23040 bytes
      + Terminal Server Mouse Driver
      | Matching Device ID: root\rdp_mou
      | Upper Filters: mouclass
      | Service: TermDD
      DirectPlay Service Providers
      DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
      DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
      DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
      DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
      Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
      IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
      Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
      Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
      DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
      DirectPlay Test Result: Not run
      Registry: OK
      DirectPlay Adapters
      DirectPlay8 IPX Service Provider: IPX Adapter 1 - (00000000,00E04C31F239)
      DirectPlay8 IPX Service Provider: IPX Adapter 2 - (00000000,001D72B9C80B)
      DirectPlay8 TCP/IP Service Provider: Wireless Network Connection - IPv4 -
      DirectPlay Voice Codecs
      Voxware VR12 1.4kbit/s
      Voxware SC06 6.4kbit/s
      Voxware SC03 3.2kbit/s
      MS-PCM 64 kbit/s
      MS-ADPCM 32.8 kbit/s
      Microsoft GSM 6.10 13 kbit/s
      TrueSpeech(TM) 8.6 kbit/s
      DirectPlay Lobbyable Apps
      Disk & DVD/CD-ROM Drives
            Drive: C:
      Free Space: 10.4 GB
      Total Space: 142.4 GB
      File System: NTFS
            Model: ST316081 5AS SCSI Disk Device
            Drive: G:
            Model: SanDisk U3 Cruzer Micro USB Device
           Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.5593 (English), 5/2/2008 03:49:39, 62976 bytes
            Drive: D:
            Model: HL-DT-ST DVDRAM GH40F SCSI CdRom Device
      System Devices
           Name: NVIDIA nForce Serial ATA Controller
      Device ID: PCI\VEN_10DE&DEV_03F6&SUBSYS_01531025&REV_A2\3&2411E6FE&0&41
         Driver: C:\WINDOWS\system32\DRIVERS\nvgts.sys, 10.03.0000.0021 (English), 1/25/2008 20:01:06, 132096 bytes
         Driver: C:\WINDOWS\system32\nvraidco.dll, 10.03.0000.0021 (English), 1/25/2008 19:48:56, 360448 bytes
         Driver: C:\WINDOWS\system32\nvraiins.dll, 10.03.0000.0021 (English), 1/25/2008 19:48:56, 360448 bytes
         Driver: C:\WINDOWS\system32\NvRCoAr.dll, 10.03.0000.0021 (Arabic), 1/25/2008 19:48:26, 37376 bytes
         Driver: C:\WINDOWS\system32\NvRCoCs.dll, 10.03.0000.0021 (Czech), 1/25/2008 19:48:26, 37376 bytes
         Driver: C:\WINDOWS\system32\NvRCoDa.dll, 10.03.0000.0021 (Danish), 1/25/2008 19:48:28, 37888 bytes
         Driver: C:\WINDOWS\system32\NvRCoDe.dll, 10.03.0000.0021 (German), 1/25/2008 19:48:28, 37888 bytes
         Driver: C:\WINDOWS\system32\NvRCoEl.dll, 10.03.0000.0021 (Greek), 1/25/2008 19:48:28, 38400 bytes
         Driver: C:\WINDOWS\system32\NvRCoEng.dll, 10.03.0000.0021 (English), 1/25/2008 19:48:28, 37376 bytes
         Driver: C:\WINDOWS\system32\NvRCoENU.dll, 10.03.0000.0021 (English), 1/25/2008 19:48:30, 37376 bytes
         Driver: C:\WINDOWS\system32\NvRCoEs.dll, 10.03.0000.0021 (Spanish), 1/25/2008 19:48:30, 38400 bytes
         Driver: C:\WINDOWS\system32\NvRCoEsm.dll, 10.03.0000.0021 (Spanish), 1/25/2008 19:48:30, 38400 bytes
         Driver: C:\WINDOWS\system32\NvRCoFi.dll, 10.03.0000.0021 (Finnish), 1/25/2008 19:48:30, 37888 bytes
         Driver: C:\WINDOWS\system32\NvRCoFr.dll, 10.03.0000.0021 (French), 1/25/2008 19:48:32, 38400 bytes
         Driver: C:\WINDOWS\system32\NvRCoHe.dll, 10.03.0000.0021 (Hebrew), 1/25/2008 19:48:32, 36864 bytes
         Driver: C:\WINDOWS\system32\NvRCoHu.dll, 10.03.0000.0021 (Hungarian), 1/25/2008 19:48:32, 37888 bytes
         Driver: C:\WINDOWS\system32\NvRCoIt.dll, 10.03.0000.0021 (Italian), 1/25/2008 19:48:32, 38400 bytes
         Driver: C:\WINDOWS\system32\NvRCoJa.dll, 10.03.0000.0021 (Japanese), 1/25/2008 19:48:34, 36352 bytes
         Driver: C:\WINDOWS\system32\NvRCoKo.dll, 10.03.0000.0021 (Korean), 1/25/2008 19:48:34, 35840 bytes
         Driver: C:\WINDOWS\system32\NvRCoNl.dll, 10.03.0000.0021 (Dutch), 1/25/2008 19:48:34, 37888 bytes
         Driver: C:\WINDOWS\system32\NvRCoNo.dll, 10.03.0000.0021 (Norwegian (Bokmål)), 1/25/2008 19:48:34, 37888 bytes
         Driver: C:\WINDOWS\system32\NvRCoPl.dll, 10.03.0000.0021 (Polish), 1/25/2008 19:48:36, 37888 bytes
         Driver: C:\WINDOWS\system32\NvRCoPt.dll, 10.03.0000.0021 (Portuguese), 1/25/2008 19:48:36, 38400 bytes
         Driver: C:\WINDOWS\system32\NvRCoPtb.dll, 10.03.0000.0021 (Portuguese), 1/25/2008 19:48:36, 38400 bytes
         Driver: C:\WINDOWS\system32\NvRCoRu.dll, 10.03.0000.0021 (Russian), 1/25/2008 19:48:36, 37888 bytes
         Driver: C:\WINDOWS\system32\NvRCoSk.dll, 10.03.0000.0021 (Slovak), 1/25/2008 19:48:38, 37888 bytes
         Driver: C:\WINDOWS\system32\NvRCoSl.dll, 10.03.0000.0021 (Slovenian), 1/25/2008 19:48:38, 37888 bytes
         Driver: C:\WINDOWS\system32\NvRCoSv.dll, 10.03.0000.0021 (Swedish), 1/25/2008 19:48:38, 37888 bytes
         Driver: C:\WINDOWS\system32\NvRCoTh.dll, 10.03.0000.0021 (Thai), 1/25/2008 19:48:38, 37376 bytes
         Driver: C:\WINDOWS\system32\NvRCoTr.dll, 10.03.0000.0021 (Turkish), 1/25/2008 19:48:40, 37888 bytes
         Driver: C:\WINDOWS\system32\NvRCoZhc.dll, 10.03.0000.0021 (Chinese), 1/25/2008 19:48:40, 35328 bytes
         Driver: C:\WINDOWS\system32\NvRCoZht.dll, 10.03.0000.0021 (Chinese), 1/25/2008 19:48:40, 35328 bytes
      Device ID: PCI\VEN_10DE&DEV_03F6&SUBSYS_01531025&REV_A2\3&2411E6FE&0&40
           Name: PCI standard RAM Controller
      Device ID: PCI\VEN_10DE&DEV_03F5&SUBSYS_01531025&REV_A2\3&2411E6FE&0&0A
         Driver: n/a
           Name: PCI standard PCI-to-PCI bridge
      Device ID: PCI\VEN_10DE&DEV_03F3&SUBSYS_00000000&REV_A1\3&2411E6FE&0&20
         Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.5512 (English), 4/14/2008 05:00:00, 68224 bytes
           Name: Standard Enhanced PCI to USB Host Controller
      Device ID: PCI\VEN_10DE&DEV_03F2&SUBSYS_CB8410DE&REV_A3\3&2411E6FE&0&11
         Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.5512 (English), 4/14/2008 05:00:00, 30208 bytes
         Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.5512 (English), 4/14/2008 05:00:00, 143872 bytes
         Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.5512 (English), 4/13/2008 22:42:10, 74240 bytes
         Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.5512 (English), 4/14/2008 05:00:00, 59520 bytes
         Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.5512 (English), 4/14/2008 05:00:00, 7168 bytes
           Name: Standard OpenHCD USB Host Controller
      Device ID: PCI\VEN_10DE&DEV_03F1&SUBSYS_CB8410DE&REV_A3\3&2411E6FE&0&10
         Driver: C:\WINDOWS\system32\drivers\usbohci.sys, 5.01.2600.5512 (English), 4/14/2008 05:00:00, 17152 bytes
           Name: Microsoft UAA Bus Driver for High Definition Audio
      Device ID: PCI\VEN_10DE&DEV_03F0&SUBSYS_01531025&REV_A2\3&2411E6FE&0&28
         Driver: C:\WINDOWS\system32\DRIVERS\hdaudbus.sys, 5.10.0001.5013 (English), 4/14/2008 05:00:00, 144384 bytes
           Name: NVIDIA Network Bus Enumerator
      Device ID: PCI\VEN_10DE&DEV_03EF&SUBSYS_01531025&REV_A2\3&2411E6FE&0&38
         Driver: C:\WINDOWS\system32\DRIVERS\nvnetbus.sys, 1.00.0001.6776 (English), 1/29/2008 12:37:48, 22016 bytes
         Driver: C:\WINDOWS\system32\DRIVERS\nvnrm.sys, 1.00.0002.6776 (English), 1/29/2008 12:37:38, 950272 bytes
         Driver: C:\WINDOWS\system32\bdco1.dll, 1.00.0000.6776 (English), 1/29/2008 12:36:56, 9216 bytes
         Driver: C:\WINDOWS\system32\bdco1ins.dll, 1.00.0000.6776 (English), 1/29/2008 12:36:56, 9216 bytes
         Driver: C:\WINDOWS\system32\nvconrm.dll, 1.00.0000.0035 (English), 1/29/2008 12:13:08, 35840 bytes
           Name: Standard Dual Channel PCI IDE Controller
      Device ID: PCI\VEN_10DE&DEV_03EC&SUBSYS_CB8410DE&REV_A2\3&2411E6FE&0&30
         Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.5512 (English), 4/14/2008 05:00:00, 24960 bytes
         Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.5512 (English), 4/14/2008 05:00:00, 96512 bytes
         Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 4/14/2008 05:00:00, 3328 bytes
           Name: NVIDIA nForce PCI System Management
      Device ID: PCI\VEN_10DE&DEV_03EB&SUBSYS_01531025&REV_A2\3&2411E6FE&0&09
         Driver: n/a
      Device ID: PCI\VEN_10DE&DEV_03EA&SUBSYS_CB8410DE&REV_A1\3&2411E6FE&0&00
         Driver: n/a
      Device ID: PCI\VEN_10DE&DEV_03E9&SUBSYS_00000000&REV_A2\3&2411E6FE&0&60
      Device ID: PCI\VEN_10DE&DEV_03E9&SUBSYS_00000000&REV_A2\3&2411E6FE&0&58
      Device ID: PCI\VEN_10DE&DEV_03E8&SUBSYS_00000000&REV_A2\3&2411E6FE&0&48
           Name: PCI standard ISA bridge
      Device ID: PCI\VEN_10DE&DEV_03E0&SUBSYS_00000000&REV_A2\3&2411E6FE&0&08
         Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.5512 (English), 4/14/2008 05:00:00, 37248 bytes
           Name: NVIDIA GeForce 6150SE nForce 430
      Device ID: PCI\VEN_10DE&DEV_03D0&SUBSYS_01531025&REV_A2\3&2411E6FE&0&68
         Driver: C:\WINDOWS\system32\DRIVERS\nv4_mini.sys, 6.14.0011.6401 (English), 2/25/2008 12:29:00, 6867360 bytes
         Driver: C:\WINDOWS\system32\nv4_disp.dll, 6.14.0011.6401 (English), 2/25/2008 12:29:00, 5784832 bytes
         Driver: C:\WINDOWS\system32\nvsvc32.exe, 6.14.0011.6401 (English), 2/25/2008 12:29:00, 155716 bytes
         Driver: C:\WINDOWS\system32\nvapi.dll, 6.14.0011.6401 (English), 2/25/2008 12:29:00, 364544 bytes
         Driver: C:\WINDOWS\system32\nvoglnt.dll, 6.14.0011.6401 (English), 2/25/2008 12:29:00, 6750208 bytes
         Driver: C:\WINDOWS\system32\nvcpl.dll, 6.14.0011.6401 (English), 2/25/2008 12:29:00, 8491008 bytes
         Driver: C:\WINDOWS\system32\nvmctray.dll, 6.14.0011.6401 (English), 2/25/2008 12:29:00, 81920 bytes
         Driver: C:\WINDOWS\system32\nvwddi.dll, 6.14.0011.6401 (English), 2/25/2008 12:29:00, 81920 bytes
         Driver: C:\WINDOWS\system32\nvnt4cpl.dll, 6.14.0010.11155 (English), 2/25/2008 12:29:00, 286720 bytes
         Driver: C:\WINDOWS\system32\nvmccs.dll, 6.14.0011.6401 (English), 2/25/2008 12:29:00, 229376 bytes
         Driver: C:\WINDOWS\system32\nvdisps.dll, 6.14.0011.6401 (English), 2/25/2008 12:29:00, 6356992 bytes
         Driver: C:\WINDOWS\system32\nvdispsr.dll, 6.14.0011.6401 (English), 2/25/2008 12:29:00, 5509120 bytes
         Driver: C:\WINDOWS\system32\nvgames.dll, 6.14.0011.6401 (English), 2/25/2008 12:29:00, 3346432 bytes
         Driver: C:\WINDOWS\system32\nvgamesr.dll, 6.14.0011.6401 (English), 2/25/2008 12:29:00, 3166208 bytes
         Driver: C:\WINDOWS\system32\nvmccss.dll, 6.14.0011.6401 (English), 2/25/2008 12:29:00, 188416 bytes
         Driver: C:\WINDOWS\system32\nvmccssr.dll, 6.14.0011.6401 (English), 2/25/2008 12:29:00, 458752 bytes
         Driver: C:\WINDOWS\system32\nvmobls.dll, 6.14.0011.6401 (English), 2/25/2008 12:29:00, 1163264 bytes
         Driver: C:\WINDOWS\system32\nvmoblsr.dll, 6.14.0011.6401 (English), 2/25/2008 12:29:00, 2854912 bytes
         Driver: C:\WINDOWS\system32\nvvitvs.dll, 6.14.0011.6401 (English), 2/25/2008 12:29:00, 3563520 bytes
         Driver: C:\WINDOWS\system32\nvvitvsr.dll, 6.14.0011.6401 (English), 2/25/2008 12:29:00, 3629056 bytes
         Driver: C:\WINDOWS\system32\nvwss.dll, 6.14.0011.6401 (English), 2/25/2008 12:29:00, 2383872 bytes
         Driver: C:\WINDOWS\system32\nvwssr.dll, 6.14.0011.6401 (English), 2/25/2008 12:29:00, 2441216 bytes
         Driver: C:\WINDOWS\help\nvcpl.hlp, 2/25/2008 12:29:00, 177897 bytes
         Driver: C:\WINDOWS\help\nvwcplen.hlp, 2/25/2008 12:29:00, 55444 bytes
         Driver: C:\WINDOWS\system32\nvcod.dll, 1.00.0000.0035 (English), 2/25/2008 12:29:00, 35328 bytes
         Driver: C:\WINDOWS\system32\nvcodins.dll, 1.00.0000.0035 (English), 2/25/2008 12:29:00, 35328 bytes
           Name: PCI standard host CPU bridge
      Device ID: PCI\VEN_1022&DEV_1103&SUBSYS_00000000&REV_00\3&2411E6FE&0&C3
         Driver: n/a
      Device ID: PCI\VEN_1022&DEV_1102&SUBSYS_00000000&REV_00\3&2411E6FE&0&C2
         Driver: n/a
      Device ID: PCI\VEN_1022&DEV_1101&SUBSYS_00000000&REV_00\3&2411E6FE&0&C1
         Driver: n/a
      Device ID: PCI\VEN_1022&DEV_1100&SUBSYS_00000000&REV_00\3&2411E6FE&0&C0
         Driver: n/a
      DirectX Components
         ddraw.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 279552 bytes
      ddrawex.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 27136 bytes
         dxapi.sys: 5.01.2600.0000 English Final Retail 4/14/2008 05:00:00 10496 bytes
          d3d8.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 1179648 bytes
      d3d8thk.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 8192 bytes
          d3d9.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 1689088 bytes
         d3dim.dll: 5.01.2600.0000 English Final Retail 4/14/2008 05:00:00 436224 bytes
      d3dim700.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 824320 bytes
      d3dramp.dll: 5.01.2600.0000 English Final Retail 4/14/2008 05:00:00 590336 bytes
         d3drm.dll: 5.01.2600.0000 English Final Retail 4/14/2008 05:00:00 350208 bytes
        d3dxof.dll: 5.01.2600.0000 English Final Retail 4/14/2008 05:00:00 47616 bytes
      d3dpmesh.dll: 5.01.2600.0000 English Final Retail 4/14/2008 05:00:00 34816 bytes
         dplay.dll: 5.00.2134.0001 English Final Retail 4/14/2008 05:00:00 33040 bytes
        dplayx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 229888 bytes
      dpmodemx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 23552 bytes
      dpwsock.dll: 5.00.2134.0001 English Final Retail 4/14/2008 05:00:00 42768 bytes
      dpwsockx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 57344 bytes
      dplaysvr.exe: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 29696 bytes
        dpnsvr.exe: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 17920 bytes
         dpnet.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 375296 bytes
      dpnlobby.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 3072 bytes
      dpnaddr.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 3072 bytes
      dpvoice.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 212480 bytes
      dpvsetup.exe: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 83456 bytes
        dpvvox.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 116736 bytes
        dpvacm.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 21504 bytes
      dpnhpast.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 35328 bytes
      dpnhupnp.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 60928 bytes
      dpserial.dll: 5.00.2134.0001 English Final Retail 4/14/2008 05:00:00 53520 bytes
        dinput.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 158720 bytes
      dinput8.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 181760 bytes
         dimap.dll: 5.01.2600.0000 English Final Retail 4/14/2008 05:00:00 44032 bytes
      diactfrm.dll: 5.01.2600.0000 English Final Retail 4/14/2008 05:00:00 394240 bytes
           joy.cpl: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 68608 bytes
         gcdef.dll: 5.01.2600.0000 English Final Retail 4/14/2008 05:00:00 76800 bytes
           pid.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 35328 bytes
        dsound.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 367616 bytes
      dsound3d.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 1293824 bytes
        dswave.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 19456 bytes
         dsdmo.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 181248 bytes
      dsdmoprp.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 71680 bytes
        dmusic.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 104448 bytes
        dmband.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 28672 bytes
      dmcompos.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 61440 bytes
         dmime.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 181248 bytes
      dmloader.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 35840 bytes
      dmstyle.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 105984 bytes
      dmsynth.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 103424 bytes
      dmscript.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 82432 bytes
        system.dll: 1.01.4322.2490 English Final Retail 10/12/2011 10:16:32 1232896 bytes
      Microsoft.DirectX.Direct3D.dll: 9.05.0132.0000 English Final Retail 10/30/2011 05:14:25 473600 bytes
      Microsoft.DirectX.Direct3DX.dll: 5.04.0000.3900 English Final Retail 10/30/2011 05:14:12 2676224 bytes
      Microsoft.DirectX.Direct3DX.dll: 9.04.0091.0000 English Final Retail 10/30/2011 05:14:13 2846720 bytes
      Microsoft.DirectX.Direct3DX.dll: 9.05.0132.0000 English Final Retail 10/30/2011 05:14:14 563712 bytes
      Microsoft.DirectX.Direct3DX.dll: 9.06.0168.0000 English Final Retail 10/30/2011 05:14:14 567296 bytes
      Microsoft.DirectX.Direct3DX.dll: 9.07.0239.0000 English Final Retail 10/30/2011 05:14:15 576000 bytes
      Microsoft.DirectX.Direct3DX.dll: 9.08.0299.0000 English Final Retail 10/30/2011 05:14:15 577024 bytes
      Microsoft.DirectX.Direct3DX.dll: 9.09.0376.0000 English Final Retail 10/30/2011 05:14:16 577536 bytes
      Microsoft.DirectX.Direct3DX.dll: 9.10.0455.0000 English Final Retail 10/30/2011 05:14:16 577536 bytes
      Microsoft.DirectX.Direct3DX.dll: 9.11.0519.0000 English Final Retail 10/30/2011 05:14:16 578560 bytes
      Microsoft.DirectX.Direct3DX.dll: 9.12.0589.0000 English Final Retail 10/30/2011 05:14:25 578560 bytes
      Microsoft.DirectX.DirectDraw.dll: 5.04.0000.2904 English Final Retail 10/30/2011 05:14:25 145920 bytes
      Microsoft.DirectX.DirectInput.dll: 5.04.0000.2904 English Final Retail 10/30/2011 05:14:26 159232 bytes
      Microsoft.DirectX.DirectPlay.dll: 5.04.0000.2904 English Final Retail 10/30/2011 05:14:26 364544 bytes
      Microsoft.DirectX.DirectSound.dll: 5.04.0000.2904 English Final Retail 10/30/2011 05:14:26 178176 bytes
      Microsoft.DirectX.AudioVideoPlayback.dll: 5.04.0000.2904 English Final Retail 10/30/2011 05:14:24 53248 bytes
      Microsoft.DirectX.Diagnostics.dll: 5.04.0000.2904 English Final Retail 10/30/2011 05:14:25 12800 bytes
      Microsoft.DirectX.dll: 5.04.0000.2904 English Final Retail 10/30/2011 05:14:24 223232 bytes
         dx7vb.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 619008 bytes
         dx8vb.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 1227264 bytes
      dxdiagn.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 2113536 bytes
         mfc40.dll: 4.01.0000.6151 English Beta Retail 9/17/2010 23:53:25 954368 bytes
         mfc42.dll: 6.02.8081.0000 English Final Retail 2/8/2011 06:33:55 978944 bytes
      wsock32.dll: 5.01.2600.5512 English Final Retail 4/14/2008 05:00:00 22528 bytes
      amstream.dll: 6.05.2600.5512 English Final Retail 4/14/2008 05:00:00 70656 bytes
      devenum.dll: 6.05.2600.5512 English Final Retail 4/14/2008 05:00:00 59904 bytes
        dxmasf.dll: 6.04.0009.1133 English Final Retail 4/14/2008 05:00:00 498742 bytes
        mciqtz.drv: 4.00.0096.0729 English Final Retail 11/17/1997 17:13:16 11776 bytes
      mciqtz32.dll: 6.05.2600.5512 English Final Retail 4/14/2008 05:00:00 35328 bytes
      mpg2splt.ax: 6.05.2600.5512 English Final Retail 4/14/2008 05:00:00 148992 bytes
         msdmo.dll: 6.05.2600.5512 English Final Retail 4/14/2008 05:00:00 14336 bytes
        encapi.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 20480 bytes
          qasf.dll: 11.00.5721.5145 English Final Retail 10/18/2006 22:47:18 211456 bytes
          qcap.dll: 6.05.2600.5512 English Final Retail 4/14/2008 05:00:00 192512 bytes
           qdv.dll: 6.05.2600.5512 English Final Retail 4/14/2008 05:00:00 279040 bytes
          qdvd.dll: 6.05.2600.5512 English Final Retail 4/14/2008 05:00:00 386048 bytes
         qedit.dll: 6.05.2600.5512 English Final Retail 4/14/2008 05:00:00 562176 bytes
      qedwipes.dll: 6.05.2600.5512 English Final Retail 4/14/2008 05:00:00 733696 bytes
        quartz.dll: 6.05.2600.5933 English Final Retail 2/5/2010 11:27:45 1291776 bytes
        quartz.vxd:                 Final Retail 11/17/1997 17:13:16 5672 bytes
      strmdll.dll: 4.01.0000.3938 English Final Retail 8/26/2009 01:00:21 247326 bytes
        vidx16.dll: 0.00.0000.0000 English Final Retail 11/17/1997 17:13:16 10240 bytes
      iac25_32.ax: 2.00.0005.0053 English Final Retail 4/14/2008 05:00:00 199680 bytes
        ir41_32.ax: 4.51.0016.0003 English Final Retail 4/14/2008 05:00:00 848384 bytes
      ir41_qc.dll: 4.30.0062.0002 English Final Retail 4/14/2008 05:00:00 120320 bytes
      ir41_qcx.dll: 4.30.0064.0001 English Final Retail 4/14/2008 05:00:00 338432 bytes
      ir50_32.dll: 5.2562.0015.0055 English Final Retail 4/14/2008 05:00:00 755200 bytes
      ir50_qc.dll: 5.00.0063.0048 English Final Retail 4/14/2008 05:00:00 200192 bytes
      ir50_qcx.dll: 5.00.0064.0048 English Final Retail 4/14/2008 05:00:00 183808 bytes
         ivfsrc.ax: 5.10.0002.0051 English Final Retail 4/14/2008 05:00:00 154624 bytes
      mswebdvd.dll: 6.05.2600.5857 English Final Retail 8/5/2009 02:01:48 204800 bytes
            ks.sys: 5.03.2600.5512 English Final Retail 4/14/2008 00:46:38 141056 bytes
        ksproxy.ax: 5.03.2600.5512 English Final Retail 4/14/2008 05:42:44 129536 bytes
        ksuser.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:58 4096 bytes
        stream.sys: 5.03.2600.5512 English Final Retail 4/14/2008 00:15:16 49408 bytes
      mspclock.sys: 5.03.2600.5512 English Final Retail 4/14/2008 01:09:52 5376 bytes
         mspqm.sys: 5.01.2600.5512 English Final Retail 4/14/2008 01:09:52 4992 bytes
      mskssrv.sys: 5.03.2600.5512 English Final Retail 4/14/2008 01:09:54 7552 bytes
        swenum.sys: 5.03.2600.5512 English Final Retail 4/14/2008 01:09:54 4352 bytes
      mpeg2data.ax: 6.05.2600.5512 English Final Retail 4/14/2008 05:00:00 118272 bytes
      msvidctl.dll: 6.05.2600.5512 English Final Retail 4/14/2008 05:00:00 1428992 bytes
        vbisurf.ax: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 30208 bytes
         msyuv.dll: 5.03.2600.5908 English Final Retail 11/27/2009 10:11:44 17920 bytes
      wstdecod.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:00:00 50688 bytes
      DirectShow Filters
      DirectShow Filters:
      WMAudio Decoder DMO,0x00800800,1,1,,
      WMAPro over S/PDIF DMO,0x00600800,1,1,,
      WMA Voice Decoder DMO,0x00600800,1,1,,
      WMVideo Advanced Decoder DMO,0x00800001,1,1,,
      Mpeg4s Decoder DMO,0x00800001,1,1,,
      WMV Screen decoder DMO,0x00800001,1,1,,
      WMVideo Decoder DMO,0x00800001,1,1,,
      Mpeg43 Decoder DMO,0x00800001,1,1,,
      Mpeg4 Decoder DMO,0x00800001,1,1,,
      WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
      Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.5933
      WMT VIH2 Fix,0x00200000,1,1,WLXVAFilt.dll,14.00.8051.1204
      Record Queue,0x00200000,1,1,WLXVAFilt.dll,14.00.8051.1204
      WMT Switch Filter,0x00200000,1,1,WLXVAFilt.dll,14.00.8051.1204
      WMT Virtual Renderer,0x00200000,1,0,WLXVAFilt.dll,14.00.8051.1204
      WMT DV Extract,0x00200000,1,1,WLXVAFilt.dll,14.00.8051.1204
      WMT Virtual Source,0x00200000,0,1,WLXVAFilt.dll,14.00.8051.1204
      WMT Sample Information Filter,0x00200000,1,1,WLXVAFilt.dll,14.00.8051.1204
      CyberLink MPEG Video Encoder,0x00200000,1,1,P2GVidEnc.ax,6.00.0001.2226
      CyberLink MP3/WAV Wrapper,0x00200000,1,1,P2GMP3Wrap.ax,3.07.0000.1314
      DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.5512
      CyberLink AudioCD Filter,0x00200000,0,1,P2GAudioCD.ax,5.00.0000.1321
      Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.5933
      WM ASF Reader,0x00400000,0,0,qasf.dll,11.00.5721.5145
      Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,11.00.5721.5145
      AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.5933
      WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
      VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.5933
      Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
      CyberLink Editing Service 3.0 (Source),0x00200000,0,2,P2GEdtKrn.dll,3.00.0000.2911
      CyberLink AudioCD Filter (PDVD7),0x00600000,0,1,CLAudioCD.ax,5.00.0000.4417
      Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
      AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.5512
      CyberLink Audio Decoder (PDVD7),0x00601000,1,1,CLAud.ax,6.01.0000.4227
      WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
      StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.6076
      WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
      MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5933
      CyberLink Audio Effect (PDVD7),0x00200000,1,1,CLAudFx.ax,6.00.0000.4111
      Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
      WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
      Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
      MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.5933
      SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.5933
      P2G Video Decoder,0x00200000,2,3,P2GVSD.ax,6.00.0000.2310
      MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.06.0000.0052
      MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.5512
      ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
      CyberLink Video/SP Decoder(PDVD7 HomeNetwork),0x00200000,2,3,CLVSD.ax,6.00.0000.3313
      Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.5933
      CyberLink Video Regulator,0x00200000,1,1,P2GRGL.ax,2.00.0000.3328
      P2G Audio Decoder,0x00200000,1,1,P2GAud.ax,6.01.0000.3601
      MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.5933
      File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,11.00.5721.5145
      WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
      DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.5512
      Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
      Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
      Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,
      Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
      CyberLink Video Effect,0x00200000,1,1,P2GVidFx.ax,1.00.0000.2030
      CyberLink Demux (PDVD7),0x00602000,1,0,CLDemuxer.ax,1.00.0000.4528
      CyberLink MPEG Splitter,0x00200000,1,2,CLSplter.ax,3.01.0000.3022
      WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
      Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
      CyberLink Line21 Decoder (PDVD7),0x00200000,0,2,CLLine21.ax,4.00.0000.7602
      CyberLink Audio Noise Reduction,0x00200000,1,1,P2GAuNRWrapper.ax,2.00.0000.1017
      CyberLink Load Image Filter,0x00200000,0,1,CLImage.ax,3.00.0000.2307
      CyberLink MPEG-2 Splitter,0x00200000,1,2,P2Gm2spliter.ax,2.04.0000.2301
      Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
      ASX file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
      ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
      NSC file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
      CyberLink Audio VolumeBooster,0x00200000,1,1,P2GVB.ax,1.00.0000.1008
      ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.5933
      Windows Media source filter,0x00600000,0,2,wmpasf.dll,11.00.5721.5145
      Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.5933
      Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
      MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.6076
      Cyberlink Dump Dispatch Filter,0x00200000,1,0,P2GDumpDispatch.ax,1.02.0001.2412
      Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.5512
      Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.5933
      CyberLink Push-Mode CLStream (PDVD7),0x00200000,0,1,CLStream(PushMode).ax,1.00.0000.1627
      CyberLink Audio Decoder (PDVD7 UPnP),0x00200000,1,1,CLAud.ax,6.01.0000.3816
      WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.5512
      Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.5933
      CyberLink Audio Resampler,0x00200000,1,1,P2GAuRsmpl.ax,1.00.0000.2625
      CyberLink Audio Spectrum Analyzer (PDVD7),0x00200000,1,1,CLAudSpa.ax,1.00.0000.0924
      File Writer,0x00200000,1,0,WLXVAFilt.dll,14.00.8051.1204
      WM ASF Writer,0x00400000,0,0,qasf.dll,11.00.5721.5145
      CyberLink MPEG-1 Splitter,0x00200000,1,2,P2Gm1spliter.ax,2.04.0000.2301
      WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
      VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.5512
      Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4504
      File writer,0x00200000,1,0,qcap.dll,6.05.2600.5512
      CyberLink Video/SP Decoder (PDVD7),0x00602000,2,3,CLVsd.ax,8.00.0000.1918
      Cyberlink File Reader (Async.),0x00200000,0,1,P2GReader.ax,3.00.0000.3016
      CyberLink M2V Writer,0x00200000,1,0,P2GM2VWriter.ax,1.03.0000.2017
      WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
      WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
      Cyberlink Dump Filter,0x00200000,1,0,P2GDump.ax,3.00.0000.7122
      CyberLink Video Stabilizer,0x00200000,1,1,P2GVideoStabilizer.ax,1.00.0000.1017
      CyberLink PCM Wrapper,0x00200000,1,1,P2GPCMEnc.ax,1.01.0000.0321
      DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.5512
      CyberLink DVD Navigator (PDVD7),0x00600000,0,3,CLNavX.ax,7.00.0000.3112
      CyberLink TimeStretch Filter (PDVD7),0x00200000,1,1,clauts.ax,1.00.0000.5423
      Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.5512
      Cyberlink SubTitle Importor (PDVD7),0x00200000,1,1,CLSubTitle.ax,1.00.0000.1604
      Cutlist File Source,0x00200000,0,1,qcut.dll,5.01.0051.0207
      AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.5933
      .RAM file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
      WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
      G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
      MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.5512
      DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.5512
      Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
      CyberLink MPEG-4 Splitter (PDVD7),0x00600000,1,2,clm4splt.ax,1.00.0000.3229
      ASF DIB Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
      ASF ACM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
      ASF ICM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
      ASF URL Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
      ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
      ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
      ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
      9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
      WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
      Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
      SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.5512
      Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.5512
      WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
      WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
      StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.6076
      CyberLink TimeStretch Filter (CES),0x00200000,1,1,P2Gauts.ax,1.00.0000.2212
      Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.5512
      Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.5512
      CyberLink TL MPEG Splitter,0x00200000,1,2,P2GTLMSplter.ax,3.02.0000.2219
      AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5933
      CyberLink MPEG Muxer,0x00200000,2,1,P2GMpgMux.ax,5.01.0000.1723
      Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
      AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.5933
      QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.5933
      Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.5933
      MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.5933
      Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.5933
      File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.5933
      XML Playlist,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
      AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.5512
      Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.5933
      File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.5933
      File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.5933
      WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
      P2G Video Regulator,0x00200000,1,1,P2GResample.ax,2.05.0000.1818
      P2G Audio Encoder,0x00200000,2,0,P2GAudEnc.ax,2.00.0000.4815
      CyberLink Demux (PDVD7 UPnP),0x00200000,1,0,CLDemuxer.ax,1.00.0000.4513
      WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
      WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
      Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
      Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.5512
      CyberLink Streamming Filter (PDVD7),0x00200000,0,1,CLStream.ax,1.01.0000.2902
      QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5933
      MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.5933
      CyberLink MPEG Decoder,0x00200000,2,3,P2GMVD.ax,5.00.0000.0929
      Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
      TrueMotion 2.0 Decompressor,0x00600001,1,1,tm20dec.ax,1.00.0000.0000
      Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
      WDM Streaming Data Transforms:
      Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
      Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.5512
      Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.5512
      Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.5512
      Video Compressors:
      WMVideo8 Encoder DMO,0x00600800,1,1,,
      MSScreen encoder DMO,0x00600800,1,1,,
      WMVideo9 Encoder DMO,0x00600800,1,1,,
      MSScreen 9 encoder DMO,0x00600800,1,1,,
      DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.5512
      Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
      MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.5933
      Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.5512
      Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.5512
      Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.5512
      Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.5512
      Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.5512
      Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
      Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
      Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
      Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.5512
      Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.5512
      Audio Compressors:
      WMA Voice Encoder DMO,0x00600800,1,1,,
      WM Speech Encoder DMO,0x00600800,1,1,,
      WMAudio Encoder DMO,0x00600800,1,1,,
      IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.5933
      Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.5933
      ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.5933
      DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.5933
      Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.5933
      Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.5933
      GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.5933
      Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.05.2600.5933
      Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.5933
      CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.5933
      CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.5933
      MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.5933
      Audio Capture Sources:
      Realtek HD Audio Input,0x00200000,0,0,qcap.dll,6.05.2600.5512
      Midi Renderers:
      Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.5933
      Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.5933
      WDM Streaming Capture Devices:
      Realtek HD Audio Input,0x00200000,1,1,,5.03.2600.5512
      WDM Streaming Rendering Devices:
      Realtek HD Audio output,0x00200000,2,1,,5.03.2600.5512
      WDM Streaming Mixer Devices:
      Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
      BDA CP/CA Filters:
      Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.6076
      Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.6076
      XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.6076
      Audio Renderers:
      Realtek HD Audio output,0x00200000,1,0,quartz.dll,6.05.2600.5933
      CyberLink Audio Renderer (PDVD7),0x00200000,1,0,cladr.ax,6.00.0000.3916
      Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.5933
      Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.5933
      DirectSound: Realtek HD Audio output,0x00200000,1,0,quartz.dll,6.05.2600.5933
      WDM Streaming System Devices:
      Realtek HD Audio Input,0x00200000,4,1,,5.03.2600.5512
      Realtek HD Audio output,0x00200000,13,1,,5.03.2600.5512
      i await your response. be forewarned, i'll have to start a whole new topic in order to respond, seeing as anytime i click on the "reply" button nothing happens. that is the same issue with trying to download the new flash player 11 from the download page. i click on the link, nothing happens. now, i'm having this problem on every website i go to, at least the ones that will come up and display instead of the blank white screen i keep getting everywhere.
