Hi Everybody,
I would like to make some kind of interactive 3D model in flash.
In the image below you see a 3D model. It's just an example to explain what I have in mind.
You see a red disc 1, a blue disc 2 and a pushbutton. The idea is that the blue disc rotates (for example 45 degrees) compared to the red disc when you push the button.
Is that possible in a 3D model that you also can turn around with your mouse?
I can make the models in Rhinoceros 4.0, that's no problem. Importing the model into flash is also no problem (papervision).
But how can I add some interactives to the 3D model like a pushbutton and a slidecard?
I have really no idea how to do that.
take a look at those examples with source code, that should answer your question:
http://papervision2.com/basic-mouse-interaction-v2/
