4 Replies Latest reply on Nov 4, 2011 3:04 AM by Jakoub2
    Disable click on the second tab
    Jakoub2
      Hi, I created mobile app with some Views (tabs). On first View (first tab)I have required text fiels.  I would like
      disable click on second view (second tab) - enable false?? - , if this text fiels will be empty.
      How I can do it? I created in header on first tab function
      focusOut="view1_focusOutHandler(event)">
      and there  I put my code for validating text fiels. If false, I call function
      navigator.pushView(myFirstTab);
      but it isn't ok, I can see second tab and after screen move on first view.
      Can anybody say me, how I can do it better?
      Regards
        • 1. Re: Disable click on the second tab
          Jason Szeto Level 3
          You can toggle the enabled property of the second ViewNavigator. Setting it to false will make the tab disabled.
          • 2. Re: Disable click on the second tab
            Jakoub2 Level 1
            Hi Jason,
            thank you for your help me, but I didn't find, how I can obtain access from first tab to the second tab.
            If I tryed mySecondTab + dot  , I didn't see enable property, if  I tryed
            var mySecondTab:MySecondTab = new MySecondTab();
            mySecondTab.enable = false;
            this code works fine, but without any result in my live tab (it is ok, I created new instance of my tab, it doesn't work with my  "live" tab).
            Next I tryed obtain object from
            navigator.getChildByName("mySecondTab");
               //name mySecondTab is a name in id properties
            or
            navigator.getChildByName("MySecondTab");
            //name MySecondTab is a name of component in a project
            but both function returns null.
            Thank you
            • 3. Re: Disable click on the second tab
              Jason Szeto Level 3
              This was my hacky way of getting to the second ViewNavigator
              In my View:
              var navTwo:ViewNavigator = TabbedViewNavigatorApplication(FlexGlobals.topLevelApplication).navigators[1] as ViewNavigator;
              navTwo.enabled = !navTwo.enabled;
              <s:navigators>
                  <s:ViewNavigator id="navOne" label="One" firstView="views.SecondView"/>
                  <s:ViewNavigator id="navTwo" label="Two" firstView="views.SPUCHomeView" enabled="false"/>
              </s:navigators>
              • 4. Re: Disable click on the second tab
                Jakoub2 Level 1
                Hi, thank you for your code. It works perfect.
