8 Replies Latest reply on Nov 2, 2011 2:28 PM by MatteoLegittimo
    getChildIndex Error
    MatteoLegittimo Level 1
      What's wrang with my code in  my flex mobile project?
      <s:View xmlns:fx="http://ns.adobe.com/mxml/2009"
              xmlns:s="library://ns.adobe.com/flex/spark" title="HomeView" xmlns:local="*">
          <fx:Script>
              <![CDATA[
                  protected function mouseDownListener(event:MouseEvent):void {
                      trace(brickContainer.getChildIndex(MovieClip(event.target)))
          </fx:Script>
          <fx:Declarations>
              <!-- Place non-visual elements (e.g., services, value objects) here -->
          </fx:Declarations>
          <s:Group id="brickContainer" mouseDown="mouseDownListener(event)">
              <s:layout>
                  <s:HorizontalLayout/>
              </s:layout>
              <local:BrickAsset/>
              <local:BrickAsset/>
              <local:BrickAsset/>
          </s:Group>
      </s:View>
      I get this error in mouseDownListener:
      Main Thread (Suspended: ArgumentError: Error #2025: The supplied DisplayObject must be a child of the caller.)
      Thanks a lot!
        • 1. Re: getChildIndex Error
          Flex harUI Adobe Employee
          Mouse targets in a container are not guaranteed to be parented by the container.  They can be buried deeper because of skins or because of hierarchy in the target component itself.
          • 2. Re: getChildIndex Error
            thanks for your replay!
            How can i do?
            thanks again!
            • 3. Re: getChildIndex Error
              Shongrunden Adobe Employee
              Does getElementIndex() work?
              • 4. Re: getChildIndex Error
                saisri2k2 Level 4
                Probably add mouseDown on all the children and remove the mouseDown on the parent, the same handler should be good.
                    <fx:Script>
                        <![CDATA[
                                trace(brickContainer.getChildIndex(event.target as BrickAsset))
                    </fx:Script>
                    <s:Group id="brickContainer" >
                        <s:layout>
                        </s:layout>
                        <local:BrickAsset mouseDown="mouseDownListener(event)"/>
                • 5. Re: getChildIndex Error
                  no!
                  not working
                  • 6. Re: getChildIndex Error
                    Like this it's working:
                        <fx:Script>
                            <![CDATA[
                                    trace(brickContainer.getElementIndex(BrickAsset(event.currentTarget)))
                        </fx:Script>
                        <fx:Declarations>
                        </fx:Declarations>
                        <s:Group id="brickContainer">
                            <s:layout>
                            </s:layout>
                        </s:Group>
                    </s:View>
                    I did mouseDownListener to the group because i would like to assign just one event handler, because the BrickAsset are added at runtime!
                    Any solution instead ?
                    Thanks!
                    • 7. Re: getChildIndex Error
                      saisri2k2 Level 4
                      You can add the listeners at run time, I see no issue with it.
                      • 8. Re: getChildIndex Error
                        I did like this in creationCompleteEvent:
                        protected function view1_creationCompleteHandler(event:FlexEvent):void {
                                        var currentAsset:BrickAsset
                                        for (var i:int = 0; i < brickContainer.numChildren; i++)  {
                                            currentAsset = BrickAsset(brickContainer.getChildAt(i))
                                            currentAsset.addEventListener(MouseEvent.MOUSE_DOWN ,mouseDownListener)
                                            currentAsset.buttonMode = true
