0 Replies Latest reply on Oct 31, 2011 8:08 PM by KGBMICHEL
    Problems with datagrid from FXP, I did something, but I got problems with mysql...
    KGBMICHEL Level 1
      Good night My name is Michel.
      Right!, I have a challenge to myself. that is to relearn flash builder, I have a few years without touching it or anything.
      But I still have the ease of get these new things added.
      Going straight to the point, as I am Brazilian, some things from the file will be in Portuguese, I hope you can help me! I appreciate it. Well, I'm creating a Datagrid, this Datagrid was done in FXP, and imported into the FB, I did some workarounds and got where I wanted, only that there are problems.
      the scheme is this:
      MySQL database = NoticiasService
      Connected by Zend / PHP.
      Everything right until here.
      I have the file main.mxml> DatalistSinspebNoticias.mxml> DatalistSinspebNoticiasRepeatedItemSkin.mxml - just here.
      I will not make a closed file (FXP), because my file is just a mess and only I understand the way it was organized.
      The problem is:
      The datagrid is infinite, I want to limit it to eight items repeated.
      The link does not work with "TextConverter" to "HTML"
      FB lives showing me glitches.
      then I will initiate an implementation of other applications, such as adding data to the DB, and Update DB. Thanks Folks!
      Main.mxml ------------------------------------------------------------------------->
      <?xml version='1.0' encoding='UTF-8'?>
      <s:Application xmlns:ATE="http://ns.adobe.com/ate/2009"
                                       xmlns:ai="http://ns.adobe.com/ai/2009"
                                       xmlns:fc="http://ns.adobe.com/flashcatalyst/2009"
                                       xmlns:d="http://ns.adobe.com/fxg/2008/dt"
                                       xmlns:fx="http://ns.adobe.com/mxml/2009"
                                       xmlns:lib="assets.graphics.caixa_feed_sinspeb.*"
                                       xmlns:flm="http://ns.adobe.com/flame/2008"
                                       xmlns:noticiasservice="services.noticiasservice.*"
                                       width="100%" height="100%" backgroundColor="#FFFFFF" preloaderChromeColor="#FFFFFF"
                                       fc:previewHeight="380" fc:previewWidth="430">
                <fx:Style source="Main.css"/>
                <fx:Script>
                          <![CDATA[
                                    import mx.events.FlexEvent;
                                    protected function list1_creationCompleteHandler(event:FlexEvent):void
                                              getAllNoticiasResult.token = noticiasService.getAllNoticias();
                </fx:Script>
                <fx:Declarations>
                          <s:CallResponder id="getAllNoticiasResult"/>
                          <noticiasservice:NoticiasService id="noticiasService" showBusyCursor="true"/>
                </fx:Declarations>
                <fx:DesignLayer d:id="2" d:userLabel="Layer 1">
                          <s:List id="list1" x="10" y="8"
                                              creationComplete="list1_creationCompleteHandler(event)"
                                              skinClass="components.DataListSinspebNoticias" labelField="conteudo_nt">
                                    <s:AsyncListView list="{getAllNoticiasResult.lastResult}"/>
                          </s:List>
                </fx:DesignLayer>
      </s:Application>
      DatalistSinspebNoticias.mxml ------------------------------------------------------------------------->
      <s:Skin xmlns:s="library://ns.adobe.com/flex/spark"
                          width="407" height="374">
                <fx:Metadata>[HostComponent("spark.components.List")]</fx:Metadata>
                <s:states>
                          <s:State name="normal"/>
                          <s:State name="disabled"/>
                </s:states>
                <s:DataGroup id="dataGroup" x="0" y="0" width="407" height="353" clipAndEnableScrolling="true"
                                               itemRenderer="components.DataListSinspebNoticiasRepeatedItemSkin"
                                               height.normal="374" buttonMode.normal="true">
                          <s:layout>
                                    <s:VerticalLayout gap="1"/>
                          </s:layout>
                </s:DataGroup>
      </s:Skin>
      DatalistSinspebNoticiasRepeatedItemSkin.mxml ------------------------------------------------------------------------->
      <s:ItemRenderer xmlns:s="library://ns.adobe.com/flex/spark"
                                              width="402" height="39" autoDrawBackground="false">
                <fx:Script>
                          <![CDATA[
                                    import flashx.textLayout.conversion.ConversionType;
                                    import flashx.textLayout.conversion.TextConverter;
                </fx:Script>
                <s:states>
                          <s:State name="hovered"/>
                          <s:State name="selected"/>
                </s:states>
                <s:Rect x="5" y="3" width="78" height="32">
                          <s:fill>
                                    <s:SolidColor color="#01557C"/>
                          </s:fill>
                          <s:stroke.hovered>
                                    <s:SolidColorStroke caps="none" color="#96F2FF" joints="miter" miterLimit="4" weight="2"/>
                          </s:stroke.hovered>
                </s:Rect>
                <s:Rect d:id="3" x="85.5" y="0.5" width="315" height="37" flm:variant="1"
                                    x.hovered="86" y.hovered="1">
                          <s:fill>
                                    <s:LinearGradient x="157.5" y="0" scaleX="32" rotation="90">
                                              <s:GradientEntry ratio="0" color="#FFFFFF"/>
                                              <s:GradientEntry ratio="0.488676" color="#E0EEF9"/>
                                              <s:GradientEntry ratio="1" color="#D6E9F7"/>
                                    </s:LinearGradient>
                          </s:fill>
                          <s:stroke>
                                    <s:SolidColorStroke caps="none" color="#666666" joints="miter" miterLimit="4" weight="1"
        color.hovered="#999999" weight.hovered="2"
        color.selected="#0065FF"/>
                          </s:stroke>
                </s:Rect>
                <s:Rect d:userLabel="Item Highlight Rectangle" x="5" y="0" width="396" height="33" alpha="0">
                          <s:fill>
                                    <s:SolidColor color="0xCED7EE"/>
                          </s:fill>
                </s:Rect>
                <s:RichText  x="20" y="12" width="48" height="14" ai:aa="2"
                                              color="#FFFFFF" columnCount="1" fontFamily="Myriad Pro" fontSize="14" kerning="on"
                                              tabStops="S0" text="{data.datada_nt}" flm:variant="2" whiteSpaceCollapse="preserve"/>
                <s:RichText x="89.95" y="8" width="309" height="24" ai:aa="2" color="#000000" columnCount="1"
                                              fontFamily="Arial Narrow" fontSize="11" kerning="on"
                                              tabStops="S0 S50 S100 S150 S200 S250 S300"
                                              textFlow="{TextConverter.importToFlow(data.conteudo_nt, TextConverter.TEXT_FIELD_HTML_FORMAT)}"
                                              trackingRight="16%"
                                              flm:variant="3" whiteSpaceCollapse="preserve"
                                              buttonMode.normal="false" lineThrough.normal="false">
                          <s:filters>
                                    <s:GlowFilter alpha="1.0" blurX="0" blurY="0" color="#000000" inner="false"
        knockout="false" quality="2" strength="1"/>
                          </s:filters>
                </s:RichText>
                <s:Path includeIn="hovered" x="0.35" y="12.35" data="M 12.40 7.15 L 0.03 14.29 0.03 0.01 Z ">
                          <s:stroke>
                                    <s:SolidColorStroke caps="none" color="#666666" joints="miter" miterLimit="4" weight="1"/>
                          </s:stroke>
                          <s:fill>
                                    <s:LinearGradient rotation="90">
                                              <s:GradientEntry color="#FFFFFF" ratio="0"/>
                                              <s:GradientEntry color="#E0EEF9" ratio="0.488676"/>
                                              <s:GradientEntry color="#D6E9F7" ratio="1"/>
                                    </s:LinearGradient>
                          </s:fill>
                </s:Path>
      </s:ItemRenderer>
