0 Replies Latest reply on Nov 1, 2011 12:46 PM by mar719
    Having a problem with adding data to database from Form...Hoping someone can help...Thanks!
    mar719
      Hello. I wondering if someone would be able to figure out a problem I am having with adding data to a database. I am fairly new to Flex programming with some PHP skills.  I have taken the bulk of the Flex training courses.
      Here is my problem;  I am using the Flex training examples to add, update, and delete records from a database table.  I can't seem to be able to ADD a record.  The examples I have followed are passing variables as int, and I need to add based on string...meaning the primary key of my table is a unique string, whereas the examples I followed used an int for the primary key.
      Please look at my code.  Thank you.
      This code represent the mysql table Projects.
      <?php
      * Represents an Projects entity..
      class Projects
           * @var string
          public $project_id;
           * @var string
          public $project_name;
           * @var string
          public $service_type;
           * @var string
          public $util_contact_name;
           * @var string
          public $util_contact_phone1;
           * @var string
          public $util_contact_phone2;
           * @var string
          public $util_contact_fax;
           * @var string
          public $util_contact_email;
           * @var string
          public $mgr_contact_name;
           * @var string
          public $mgr_contact_phone1;
           * @var string
          public $mgr_contact_phone2;
           * @var string
          public $mgr_contact_fax;
           * @var string
          public $mgr_contact_email;
      This is the Service code that calls createProject() to add a record:
      public function createProject (Projects $item)
              $stmt = mysqli_prepare($this->connection,
              "INSERT INTO projects (
              project_id,project_name,service_type,util_contact_name,util_contact_phone1,util_contact_p hone2,
                          util_contact_fax,util_contact_email,mgr_contact_name,mgr_contact_phone1,mgr_con tact_phone2,mgr_contact_fax,
                          mgr_contact_email)
      VALUES (?,?,?,?,?,?,?,?,?,?,?,?,?)");
              $this->throwExceptionOnError();
              mysqli_bind_param($stmt, $item->project_id,$item->project_name, $item->service_type,
              $item->util_contact_name, $item->util_contact_phone1, $item->util_contact_phone2,
              $item->util_contact_fax, $item->util_contact_email, $item->mgr_contact_name, $item->mgr_contact_phone1,
              $item->mgr_contact_phone2, $item->mgr_contact_fax, $item->mgr_contact_email);
              mysqli_stmt_execute($stmt);
              $autoid = mysqli_stmt_insert_id($stmt);
              mysqli_stmt_free_result($stmt);
              mysqli_close($this->connection);
              return $autoid;
      Procedures for createProjectResult:
      protected function button_clickHandler(event:MouseEvent):void
                                              projects.project_id = project_idTextInput.text;
                                              projects.project_name = project_nameTextInput.text;
                                              projects.service_type = service_typeTextInput.text;
                                              projects.util_contact_name = util_contact_nameTextInput.text;
                                              projects.util_contact_phone1 = util_contact_phone1TextInput.text;
                                              projects.util_contact_phone2 = util_contact_phone2TextInput.text;
                                              projects.util_contact_fax = util_contact_faxTextInput.text;
                                              projects.util_contact_email = util_contact_emailTextInput.text;
                                              projects.mgr_contact_name = mgr_contact_nameTextInput.text;
                                              projects.mgr_contact_phone1 = mgr_contact_phone1TextInput.text;
                                              projects.mgr_contact_phone2 = mgr_contact_phone2TextInput.text;
                                              projects.mgr_contact_fax = mgr_contact_faxTextInput.text;
                                              projects.mgr_contact_email = mgr_contact_emailTextInput.text;
                                              createProjectResult.token = projectsService.createProject(projects);
                                    protected function createProjectResult_resultHandler(event:ResultEvent):void
                                              currentState="ProjectDetails";
                                              projects.project_id=event.result as String;
                                              projectDg.dataProvider.addItem(projects);
      Lastly the Declarations:
      <fx:Declarations>
                          <s:CallResponder id="getProjectsResult"
        result="projects = getProjectsResult.lastResult[0] as Projects;
        projects = getProjectsResult.lastResult[0] as Projects"/>
                          <projectsservice:ProjectsService id="projectsService"
        fault="Alert.show(event.fault.faultString + '\n' + event.fault.faultDetail)"
        showBusyCursor="true"/>
                          <valueObjects:Projects id="projects"/>
                          <s:CallResponder id="createProjectResult"
        result="createProjectResult_resultHandler(event)"/>
                </fx:Declarations>
      Any help would be appreciated, thank you.
