0 Replies Latest reply on Nov 2, 2011 12:40 AM by David1024Mac
    Help with XMP Panels in Adobe BRidge
    David1024Mac
      Hi All
      I'm trying to create a XMP Panel for Adobe Bridge, and I'm having a weird problem I'm hoping someone can answer.
      The Panel is created, and works, I can change a metadata field and the metadta field gets saved correctly.
      However, I need to change one of the metadata fields in code, and although it's changing thee text within the field, when I close the panel it doesn't update the metadata.
      Here's a code sippet:
      First the form Items:
      <fi:XMPFormItem
                                    id="ftitle"
                                    label="$$$/xmp/sdk/custompanels/Dave3/Title=Document Title:"
                                    labelTooltip="$$$/xmp/sdk/custompanels/Dave3/TitleToolTip=The title of the document, or the name given to the resource. Typically, it will be a name by which the resource is formally known.">
        <fi:XMPTextInput id="docTitle"
        xmpPath="dc:title"
        xmpType="Localized"
        change="changeMe(event)"/>
        </fi:XMPFormItem>
        <mx:FormItem label="Change Title">
                          <mx:Button label="Digital"
                                                 click="updateTitle(url.text)"
        </mx:FormItem>
      And here's the function that changes the text:
                                    private function updateTitle(url: String):void
                                              var st: String = "Hello Folks";
                                              docTitle.text = st;
                                              docTitle.enabled = true;
      As expected, the text in the docTitle field changes, but when I close the FIleInfo panel the changed text is not written to the file.
      Any Ideas?
      Thanks in advance
      David
