3 Replies Latest reply on Nov 7, 2011 8:10 AM by mitz11
    Fading glow on button press
    mitz11
      I am trying to get a glow filter (sparks) to appear instantly when you press a button, and then slowly fade away, regardless of where you move the cursor, or if you press other buttons, etc.  The way I have it, it works only until you move the mouse cursor off of the button, at which point the transition is interrupted and stops.  Here's the code:
      <fx:Declarations>
                          <s:GlowFilter id="glowFilter" color="#FFFFFF" strength="4"/>
                </fx:Declarations>
                <s:transitions>
                          <s:Transition fromState="down" toState="*" interruptionBehavior="stop">
                                    <s:AnimateFilter target="{fill}" bitmapFilter="{glowFilter}" duration="1000">
                                              <s:SimpleMotionPath property="alpha" valueFrom="1" valueTo="0"/>
                                    </s:AnimateFilter>
                          </s:Transition>
                </s:transitions>
                <s:Rect id="fill" left="1" right="1" top="1" bottom="1" radiusX="3">
                               <s:fill>
                                              <s:LinearGradient rotation="45" rotation.down="225">
                                                        <s:GradientEntry id="fillGradient1" color="0x003896"
        color.down="0x001948"
        alpha="0.85" />
                                                        <s:GradientEntry id="fillGradient2" color="0x1a75cf"
        color.down="0x003896"
        alpha="0.85" />
                                              </s:LinearGradient>
                               </s:fill>
                               <s:filters>
                                         <s:BevelFilter excludeFrom="down, disabled"/>
                               </s:filters>
                </s:Rect>
      There are other layers and stuff going on in the skin, but I don't think it's important.
        • 1. Re: Fading glow on button press
          mitz11 Level 1
          ignore the  interruptionBehavior="stop" part, I've tried with and without it.
          • 2. Re: Fading glow on button press
            Shongrunden Adobe Employee
            You'll want to use interruptionBehavior="stop" and also define a transition for the over to up state, for example:
            <s:SparkButtonSkin xmlns:fx="http://ns.adobe.com/mxml/2009"
                         alpha.disabled="0.5">
                <fx:Metadata>
                    <![CDATA[
                        [HostComponent("spark.components.Button")]
                </fx:Metadata>
                <s:states>
                    <s:State name="up" />
                    <s:State name="over" />
                    <s:State name="down" />
                    <s:State name="disabled" />
                </s:states>
                <s:transitions>
                        <s:Fade target="{downFilter}" />
                    </s:Transition>
                    <s:Transition fromState="over" toState="up" interruptionBehavior="stop">
                    </s:Transition>
                </s:transitions>
                <s:Rect id="rect" left="0" right="0" top="0" bottom="0" radiusX="2">
                    <s:fill>
                        <s:SolidColor color="red" />
                    </s:fill>
                    <s:filters>
                        <s:GlowFilter id="downFilter" alpha.down="1" alpha="0" color="0x0000ff" strength="5" />
                    </s:filters>
                </s:Rect>
                <s:Label id="labelDisplay"
                         textAlign="center"
                         maxDisplayedLines="1"
                         horizontalCenter="0" verticalCenter="1" verticalAlign="middle"
                         left="10" right="10" top="2" bottom="2">
                </s:Label>
            </s:SparkButtonSkin>
            • 3. Re: Fading glow on button press
              mitz11 Level 1
              Thanks!  That works.
