5 Replies Latest reply on Aug 23, 2012 12:21 PM by Peter Spier
    InBooklet SE.4x.pln.framework is this creates problem?
    Prithivi_Prepress
      Hi All,
      I am using the ID CS5 in mac 10.6.7. I know that the "InBooklet SE.4x.pln.framework" is now changed to "PrintBooklet”. But in my document  while I do the package I get the notification for the external plugin "InBooklet SE.4x.pln.framework". One of my customer says that this is the reason they cant able to open the same file on their end. But it works fine with us.
      Can any one help me and answer for the following questions.
      1. Is there still "InBooklet SE.4x.pln.framework" availabale?
      2. If "InBooklet SE.4x.pln.framework"' is not with from CS5, then how and where it come from?
      3. Where should I need to disable this from CS5?
      4. Really is this cause problem?
      Note: For the immediate remedy I have export the document as IDML and sent the same to my customer and it works fine.
      Below the line I have pasted the [ackage report for references.
      Prithivirajan
      __________________________________________________________________________________________ __________________________________________________________________________________________ ___________________________________________________
      Adobe InDesign Package Report
      PUBLICATION NAME: Sample.indd
      PACKAGE DATE: 11/2/11 8:20 PM
      Creation Date: 11/1/11
      Modification Date: 11/1/11
      SUMMARY
      (Show Data for Hidden and Non-Printing Layers)
      Fonts: 40 Fonts Used; 0 Missing, 2 Embedded, 0 Incomplete, 0 Protected
      Links and Images: 11 Links Found; 0 Modified, 0 Missing, 0 Inaccessible
      Images: 0 Embedded, 0 use RGB color space
      Colors and Inks: 4 Process Inks; 0 Spot Inks
      CMS is ON
      External Plug-ins 1
      Non Opaque Objects :On Page1, 113, 116, 125
      FONTS
      - Name: AGaramondPro-Bold; Type: OpenType Type 1, Status: OK
      Filename: Imac:Applications:Adobe InDesign CS5:Fonts:REA fonts:AGaramondPro-Bold.otf
      Full Name: Adobe Garamond Pro Bold
      First Used on Page: 142
      Protected: No
      - Name: AGaramondPro-Italic; Type: OpenType Type 1, Status: OK
      Filename: Imac:Applications:Adobe InDesign CS5:Fonts:REA fonts:AGaramondPro-Italic.otf
      Full Name: Adobe Garamond Pro Italic
      First Used on Page: 3
      Protected: No
      - Name: AGaramondPro-Regular; Type: OpenType Type 1, Status: OK
      Filename: Imac:Applications:Adobe InDesign CS5:Fonts:REA fonts:AGaramondPro-Regular.otf
      First Used on Page: 2
      Protected: No
      - Name: AGaramondPro-Semibold; Type: OpenType Type 1, Status: OK
      Filename: Imac:Applications:Adobe InDesign CS5:Fonts:Lynch_107061_OT_Fonts:Adobe Garamond Pro:AGaramondPro-Semibold.otf
      Full Name: Adobe Garamond Pro Semibold
      First Used on Page: 120
      Protected: No
      - Name: FrutigerLTStd-Bold; Type: OpenType Type 1, Status: OK
      Filename: Imac:Applications:Adobe InDesign CS5:Fonts:Turnbull_Fonts:Frutiger LT Std:FrutigerLTStd-Bold.otf
      Full Name: Frutiger LT Std 65 Bold
      Protected: No
      - Name: FrutigerLTStd-BoldCn; Type: OpenType Type 1, Status: OK
      Filename: Imac:Applications:Adobe InDesign CS5:Fonts:Turnbull_Fonts:Frutiger LT Std:FrutigerLTStd-BoldCn.otf
      Full Name: Frutiger LT Std 67 Bold Condensed
      Protected: No
      - Name: FrutigerLTStd-Cn; Type: OpenType Type 1, Status: OK
      Filename: Imac:Applications:Adobe InDesign CS5:Fonts:Turnbull_Fonts:Frutiger LT Std:FrutigerLTStd-Cn.otf
      Full Name: Frutiger LT Std 57 Condensed
      Protected: No
      - Name: FuturaStd-Bold; Type: OpenType Type 1, Status: OK
      Filename: Imac:Applications:Adobe InDesign CS5:Fonts:REA fonts:FuturaStd-Bold.otf
      Full Name: Futura Std Bold
      First Used on Page: 116
      Protected: No
      - Name: FuturaStd-Book; Type: OpenType Type 1, Status: OK
      Filename: Imac:Applications:Adobe InDesign CS5:Fonts:REA fonts:FuturaStd-Book.otf
      Full Name: Futura Std Book
      First Used on Page: 114
      Protected: No
      - Name: FuturaStd-Condensed; Type: OpenType Type 1, Status: OK
      Filename: Imac:Applications:Adobe InDesign CS5:Fonts:Niles_108136_Fonts:Futura Std:FuturaStd-Condensed.otf
      Full Name: Futura Std Medium Condensed
      Protected: No
      - Name: FuturaStd-CondensedBold; Type: OpenType Type 1, Status: OK
      Filename: Imac:Applications:Adobe InDesign CS5:Fonts:REA fonts:FuturaStd-CondensedBold.otf
      Full Name: Futura Std Bold Condensed
      First Used on Page: 146
      Protected: No
      - Name: FuturaStd-CondensedLight; Type: OpenType Type 1, Status: OK
      Filename: Imac:Applications:Adobe InDesign CS5:Fonts:Niles_108136_Fonts:Futura Std:FuturaStd-CondensedLight.otf
      Full Name: Futura Std Light Condensed
      First Used on Page: 122
      Protected: No
      - Name: FuturaStd-CondensedLightObl; Type: OpenType Type 1, Status: OK
      Filename: Imac:Applications:Adobe InDesign CS5:Fonts:Niles_108136_Fonts:Futura Std:FuturaStd-CondensedLightObl.otf
      Full Name: Futura Std Light Condensed Oblique
      Protected: No
      - Name: FuturaStd-CondensedOblique; Type: OpenType Type 1, Status: OK
      Filename: Imac:Applications:Adobe InDesign CS5:Fonts:Niles_108136_Fonts:Futura Std:FuturaStd-CondensedOblique.otf
      Full Name: Futura Std Medium Condensed Oblique
      First Used on Page: 123
      Protected: No
      - Name: FuturaStd-ExtraBold; Type: OpenType Type 1, Status: OK
      Filename: Imac:Applications:Adobe InDesign CS5:Fonts:Niles_108136_Fonts:Futura Std:FuturaStd-ExtraBold.otf
      Full Name: Futura Std Extra Bold
      Protected: No
      - Name: FuturaStd-Heavy; Type: OpenType Type 1, Status: OK
      Filename: Imac:Applications:Adobe InDesign CS5:Fonts:REA fonts:FuturaStd-Heavy.otf
      Full Name: Futura Std Heavy
      Protected: No
      - Name: FuturaStd-Light; Type: OpenType Type 1, Status: OK
      Filename: Imac:Applications:Adobe InDesign CS5:Fonts:REA fonts:FuturaStd-Light.otf
      First Used on Page: 113
      Protected: No
      - Name: FuturaStd-Medium; Type: OpenType Type 1, Status: OK
      Filename: Imac:Applications:Adobe InDesign CS5:Fonts:REA fonts:FuturaStd-Medium.otf
      Protected: No
      - Name: GarageGothic-Bold; Type: Type 1, Status: OK
      Filename: Imac:Applications:Adobe InDesign CS5:Fonts:AP:Document fonts:GaragGotBol
      Full Name: GarageGothic-Bold
      Protected: No
      - Name: GarageGothic-Regular; Type: Type 1, Status: OK
      Filename: Imac:Applications:Adobe InDesign CS5:Fonts:AP:Document fonts:GaragGotReg
      Full Name: GarageGothic-Regular
      Protected: No
      - Name: Helvetica-Condensed-Bold; Type: Type 1, Status: OK
      Filename: Imac:Applications:Adobe InDesign CS5:Fonts:REA fonts:HelveConBol
      Full Name: Helvetica Condensed Bold
      First Used on Page: 115
      Protected: No
      - Name: HelveticaLTStd-Bold; Type: OpenType Type 1, Status: OK
      Filename: Imac:Applications:Adobe InDesign CS5:Fonts:Stevens_Smith_108258:Helvetica LT Std:HelveticaLTStd-Bold.otf
      Full Name: Helvetica LT Std Bold
      First Used on Page: 145
      Protected: No
      - Name: HelveticaLTStd-Light; Type: OpenType Type 1, Status: OK
      Filename: Imac:Applications:Adobe InDesign CS5:Fonts:Stevens_Smith_108258:Helvetica LT Std:HelveticaLTStd-Light.otf
      Full Name: Helvetica LT Std Light
      Protected: No
      - Name: HelveticaLTStd-Roman; Type: OpenType Type 1, Status: OK
      Filename: Imac:Applications:Adobe InDesign CS5:Fonts:Stevens_Smith_108258:Helvetica LT Std:HelveticaLTStd-Roman.otf
      Full Name: Helvetica LT Std Roman
      Protected: No
      - Name: HelveticaNeue-Bold; Type: Type 1, Status: OK
      Filename: Imac:Applications:Adobe InDesign CS5:Fonts:REA fonts:HelveNeuBol
      Full Name: Helvetica 75 Bold
      First Used on Page: NA
      Protected: No
      - Name: HelveticaNeue-Roman; Type: Type 1, Status: OK
      Filename: Imac:Applications:Adobe InDesign CS5:Fonts:AP:Document fonts_GL:HelveNeuRom
      Full Name: Helvetica 55 Roman
      First Used on Page: 136
      Protected: No
      - Name: HelveticaNeueLTStd-BdCn; Type: OpenType Type 1, Status: OK
      Filename: Imac:Applications:Adobe InDesign CS5:Fonts:parkay_fonts:Helvetica Neue LT Std:HelveticaNeueLTStd-BdCn.otf
      Full Name: Helvetica Neue LT Std 77 Bold Condensed
      Protected: No
      - Name: HelveticaNeueLTStd-LtCn; Type: OpenType Type 1, Status: OK
      Filename: Imac:Applications:Adobe InDesign CS5:Fonts:parkay_fonts:Helvetica Neue LT Std:HelveticaNeueLTStd-LtCn.otf
      Full Name: Helvetica Neue LT Std 47 Light Condensed
      Protected: No
      - Name: HelveticaNeueLTStd-Roman; Type: OpenType Type 1, Status: OK
      Filename: Imac:Applications:Adobe InDesign CS5:Fonts:Thill fonts:HelveticaNeueLTStd-Roman.otf
      Full Name: Helvetica Neue LT Std 55 Roman
      Protected: No
      - Name: ITCFranklinGothicStd-Med; Type: OpenType Type 1, Status: OK
      Filename: Imac:Applications:Adobe InDesign CS5:Fonts:Solomon fonts:ITC Franklin Gothic Std:ITCFranklinGothicStd-Med.otf
      Full Name: ITC Franklin Gothic Std Medium
      First Used on Page: 118
      Protected: No
      - Name: Times-Roman; Type: Type 1, Status: OK
      Filename: Imac:Applications:Adobe InDesign CS5:Fonts:parkay_fonts:TimesRom
      Full Name: Times Roman
      First Used on Page: 7
      Protected: No
      - Name: TimesLTStd-Italic; Type: OpenType Type 1, Status: OK
      Filename: Imac:Applications:Adobe InDesign CS5:Fonts:Times LT Std:TimesLTStd-Italic.otf
      Full Name: Times LT Std Italic
      First Used on Page: 129
      Protected: No
      - Name: TimesLTStd-Roman; Type: OpenType Type 1, Status: OK
      Filename: Imac:Applications:Adobe InDesign CS5:Fonts:Times LT Std:TimesLTStd-Roman.otf
      Full Name: Times LT Std Roman
      Protected: No
      - Name: TimesLTStd-Semibold; Type: OpenType Type 1, Status: OK
      Filename: Imac:Applications:Adobe InDesign CS5:Fonts:Times LT Std:TimesLTStd-Semibold.otf
      Full Name: Times LT Std Semibold
      First Used on Page: 134
      Protected: No
      - Name: TimesNewRomanPS; Type: Type 1, Status: OK
      Filename: Imac:Applications:Adobe InDesign CS5:Fonts:REA fonts:TimesNewRomPS
      Full Name: Times New Roman PS
      First Used on Page: 121
      Protected: No
      - Name: TimesNewRomanPS-Bold; Type: Type 1, Status: OK
      Filename: Imac:Applications:Adobe InDesign CS5:Fonts:REA fonts:TimesNewRomPSBol
      Full Name: Times New Roman PS Bold
      Protected: No
      - Name: Utopia-BoldItalic; Type: Type 1, Status: OK
      Filename: Imac:Applications:Adobe InDesign CS5:Fonts:NATH FONTS:UtopiBolIta
      Full Name: Utopia Bold Italic
      Protected: No
      - Name: ZapfDingbatsStd; Type: OpenType Type 1, Status: OK
      Filename: Imac:Applications:Adobe InDesign CS5:Fonts:Turnbull_Fonts:ITC Zapf Dingbats Std:ZapfDingbatsStd.otf
      Full Name: ITC Zapf Dingbats Std Medium
      Protected: No
      LINKS AND IMAGES
      Links and Images: 1 Links Found; 0 Modified, 0 Missing, 0 Inaccessible
      - Name: AP; Type: TIFF Grayscale; Status: Linked
      Filename: AP.tif
      Link Updated: Wed, Sep 14, 2011 10:44 PM
      File Last Modified:
      Actual ppi: 300x300   Effective ppi: 444x444
      Layer Overrides: N/A
      Complete Name: /Volumes/projects//Common Art/AP.tif
      Link Profile:   Embedded
      On Page 123
      COLORS AND INKS
      - Name and Type: Process Cyan; Angle: 71.565; Lines/Inch: 63.245
      - Name and Type: Process Magenta; Angle: 18.434; Lines/Inch: 63.245
      - Name and Type: Process Yellow; Angle: 0.000; Lines/Inch: 66.666
      - Name and Type: Process Black; Angle: 45.000; Lines/Inch: 70.710
      PRINT SETTINGS
      PPD: AdobePDF 8.0, (PostScript® File)
      Printing To: Virtual Printer
      Number of Copies: 1
      Reader Spreads: No
      Even/Odd Pages: Both
      Pages: All
      Proof: No
      Tiling: None
      Scale: 100%, 100%
      Page Position: Center
      Print Layers: Visible & Printable Layers
      Printer's Marks: Crops
      Bleed: 1p0, 0p0, 4p0, 1p0
      Color: Composite CMYK
      Trapping Mode: None
      Send Image Data: All
      OPI/DCS Image Replacement: No
      Page Size: Letter
      Paper Dimensions: 70p2 x 99p3
      Orientation: Portrait
      Negative: No
      Flip Mode: Off
